    CSS Help with Two Small Items
    5 Posts 3 Posters 889 Views 3 Watching
      Splashed
      I finally have my wall calendar project essentially where I want it to be, but there are two small things that are driving me nuts and I cant figure out. If anyone can help with either, please let me know.
      #1 - In the yellow, the actual clock portion of my default clock module is so small. I have tried to enlarge it multiple times using the config and the css file, but each time it either changes nothing, or changes the clock as well as other things. I only want to enlarge the clock portion in yellow.
      #2 - Circled in red is the calendar module. I have changed the timing to display the time as relative. It works great, but my kids dont understand the 24 hour clock it uses. How can I change the timestamps in the red circle to use the 12 hour clock instead and to read “Today at 5:00pm” instead of “Today at 17:00”?
      Thanks everyone.
      S BKeyportB 2 Replies Last reply Reply Quote 0
        sdetweil @Splashed
        @Splashed use the developers window elements tab
        see
        https://forum.magicmirror.builders/post/90135
        • BKeyportB Offline
          BKeyport Module Developer @Splashed
          @Splashed Clock is easy. I blew mine up 5 times from the base font…
          /* Clock  */
          .clock .time {
          	font-size: 5rem;
          24 hour clock is likely in your dateFormat string, check the docs here: https://docs.magicmirror.builders/modules/calendar.html#configuration-options
          If you’re customizing, the “H” is 24 hour, “h” is 12 hour.
          see: https://momentjs.com/docs/#/parsing/string-format/ for more options to get it the exact way you want it - or teach your kids to subtract 12 (minus 10, minus 2 in new math) from the time to not be confused. 😉
            Splashed @BKeyport
            @BKeyport You advice worked perfect, after a little trial and error. Turns out I had a .clock .bright setting in my clock that was overriding the .clock .time setting.
            I also eventually found the calendar formatting setting I was after.
            Thanks a lot.
            • BKeyportB Offline
              @Splashed For future use -
              The most important part, read the documentation (No matter how bad it is, a lot of us aren’t native english speakers) before doing anything. There’s a lot of effort put in to make the project accessable to even the most basic of users, so it may not even need CSS!
              If you need to fix CSS:
              1. Look in directories of the module for CSS files - these will give you clues on what to look for. In the case of default modules, many of their settings are in main.css
              2. Make sure your mirror is able to be loaded on a remote computer thusly:
              var config = {
              	address: "0.0.0.0",
              	port: 8080,
              	ipWhitelist: [],
              1. Load your mirror on a work computer by going to “http://:8080” - then use the developer tools (typically ctrl-shift-i) to look through the styles and play with live output. You may need to insert a breakpoint to stop the constant refreshes.
              2. Once you find what you want, you can put the changes in custom.css
              Happy “hacking”
