    CalendarExt3 Correct calendar not displayed
    4 Posts 3 Posters 923 Views 3 Watching
      DarrenO
      Re: MMM-CalendarExt3
      Great update over the Ext2 module and by far the best Calendar module available!
      I am having an issue with the Ext3 module though.
      I have the module configured correctly but it does not show the calendar that I specify.
      Instead, it shows another calendar that I have configured for the default Calendar module.
      I’m using the default Calendar module in the top-left position to display a combination of family member calendars and have the Ext3 module configured in the bottom_bar position to display to display the week ahead of a calendar for scheduled network upgrade events.
      Why would an unrelated calendar display in the Ext3 and how can I get the correct calendar to display?
      On a minor note, how do I hide/remove the “CW#” text that is displayed at the beginning of each week or is this “hard-coded” and cannot be hidden/removed?
        sdetweil @DarrenO
        @DarrenO EXT3 ONLY shows entrys broadcast from the default calendar module.
        EXT3 does NOT read the calendar itself, like ext2 did
          @sdetweil to hide the Current Week number you would use an entry in custom.css
          to make it not display
          .CX3 .cw {
          display: none;
            MMRIZE @sdetweil
            More specific code is needed.
            https://github.com/MMRIZE/MMM-CalendarExt3/wiki/Examples-%26-Tips
