Solved MM loading all modules is taking 2-3 minutes.
I am still on 2.24 so I can use MMM-RTSPStream, also still on Jesse for the same reason.
Should I run this to remove swap file?
sudo swapoff -a -v
sudo rm /swapfile -
@plainbroke so, I would be carefull… newer code doesn’t run on jesse and gosh knows what you have now…
4 OS releases back (2017), stretch , buster, bullseye, now bookworm
https://en.wikipedia.org/wiki/Raspberry_Pi_OSso, you have an 8gig machine, but can only use 2gig (32bit OS)
Sorry it is buster, it is the last one that allows the rstp modules I like so much…
Linux MM 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l GNU/Linux -
Can I load the 64bit version without reloading all my MagicMirror modules ect?
I tried this :cd ~/MagicMirror export external_browser=midori export ELECTRON_DISABLE_GPU=1 DISPLAY=:0 npm start
@plainbroke you have to use my start script to make Midori work, after you install it
change the package json {“start” line to {“start1”
then add a new start line
{"start":"./run-start.sh"},
and download the run-start.sh from my script repo, and put it in the MagicMirror folder, mark it executable
chmod +x run-start.sh -
Which one of the package.json files the one before MagicMirror folder or the one in the MagicMirror folder? -
@plainbroke in the MagicMirror folder
there should not be one in the folder before
Well I removed the package.json and packagelock.json from the folder MagicMirror sets in and ran your upgrade script and my MM loaded a whole lot faster and only time will tell if it is totally fixed or not…
I appreciate your patients dealing with this issue.
I will definitely add it to my saved stuff.
I would like to try to use a different browser and see if it fixes a few other issues since I am using a 32 bit OS.
