    MM loading all modules is taking 2-3 minutes.
    19 Posts 2 Posters 5.5k Views 2 Watching
      sdetweil @plainbroke
      @plainbroke always please use code block for formatting
      don’t ‘see’ anything…
      • plainbrokeP Offline
        plainbroke @sdetweil
        Ok this may be my problem : failed to open kms_swrast
        I have seen reference to this before but am either brain dead or my google search is failing me.
        0|mm | MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
        0|mm | failed to load driver: kms_swrast
        0|mm | MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
        0|mm | failed to load swrast driver
        0|mm | [875:0114/170050.541663:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
        0|mm | [875:0114/170113.661954:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
        0|mm | [875:0114/170115.296236:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
        0|mm | [778:0114/170757.084668:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.NetworkManager.GetDevices: object_path= /org/freedesktop/NetworkManager: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.NetworkManager was not provided by any .service files
          @plainbroke said in MM loading all modules is taking 2-3 minutes.:
          no… that is the GPU driver stuff… usually not enabled in /config.txt in 2.26 we disable using the gpu by default to turn off these messages (instead of leaving it on in 2.25 and prior)
            I am still on 2.24 so I can use MMM-RTSPStream, also still on Jesse for the same reason.
            Should I run this to remove swap file?
            sudo swapoff -a -v
            sudo rm /swapfile
            S plainbrokeP 2 Replies Last reply Reply Quote 0
              @plainbroke so, I would be carefull… newer code doesn’t run on jesse and gosh knows what you have now…
              4 OS releases back (2017), stretch , buster, bullseye, now bookworm
              https://en.wikipedia.org/wiki/Raspberry_Pi_OS
              so, you have an 8gig machine, but can only use 2gig (32bit OS)
                plainbroke @plainbroke
                Sorry it is buster, it is the last one that allows the rstp modules I like so much…
                Linux MM 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l GNU/Linux
                  armv7
                  32bit
                  aaarch64 is 64 bit
                    Can I load the 64bit version without reloading all my MagicMirror modules ect?
                    I tried this :
                    export external_browser=midori
                    export ELECTRON_DISABLE_GPU=1
                    DISPLAY=:0 npm start
                      @plainbroke you have to use my start script to make Midori work, after you install it
                      change the package json {“start” line to {“start1”
                      then add a new start line
                      {"start":"./run-start.sh"},
                      and download the run-start.sh from my script repo, and put it in the MagicMirror folder, mark it executable
                      chmod +x run-start.sh
                        Which one of the package.json files the one before MagicMirror folder or the one in the MagicMirror folder?
                          @plainbroke in the MagicMirror folder
                          there should not be one in the folder before
                            Well I removed the package.json and packagelock.json from the folder MagicMirror sets in and ran your upgrade script and my MM loaded a whole lot faster and only time will tell if it is totally fixed or not…
                            I appreciate your patients dealing with this issue.
                            I will definitely add it to my saved stuff.
                            I would like to try to use a different browser and see if it fixes a few other issues since I am using a 32 bit OS.
