    MM loading all modules is taking 2-3 minutes.
    19 Posts 2 Posters 4.5k Views 2 Watching
      sdetweil @plainbroke
      @plainbroke said in MM loading all modules is taking 2-3 minutes.:
      Mem: 7846 535 6374 230 936 6862
      Swap: 99 0 99
      but not used… size 99meg, free 99meg…
      so, its not a memory problem (6862 meg free)
      • plainbrokeP Offline
        plainbroke @sdetweil
        Do not know how to post the top part it keeps changing.
        Only lets me copy part of it.
         PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
          884 pi        20   0  494048 193120  87580 S  58.3   2.4  11:53.37 electron
          875 pi        20   0  745824 472024 434912 S  35.1   5.9   3:47.87 electron
          909 pi        20   0  345508 114484  78316 R  22.5   1.4   1:44.53 electron
          879 pi        20   0  298500  63208  49584 S  21.5   0.8   4:18.07 electron
          778 pi        20   0  731340 236804 108916 S  19.2   2.9   4:03.12 electron
         1034 pi        20   0  194140  29260  20112 S   6.3   0.4   0:42.24 omxplayer.bin
          590 root      20   0  124324  47660  32436 S   6.0   0.6   0:30.80 Xorg
          436 root      20   0       0      0      0 I   5.3   0.0   0:12.04 kworker/u8:3-ext4-rsv-conversion
         1393 root      20   0       0      0      0 I   4.6   0.0   0:06.66 kworker/u8:1-brcmf_wq/mmc1:0001:1
         1033 pi        20   0  194036  28920  20056 S   4.3   0.4   0:37.70 omxplayer.bin
           85 root      20   0       0      0      0 I   3.6   0.0   0:08.36 kworker/0:4-events
          250 root      -2   0       0      0      0 S   1.0   0.0   0:05.17 v3d_bin
          251 root      -2   0       0      0      0 S   1.0   0.0   0:04.87 v3d_render
           80 root       1 -19       0      0      0 S   0.7   0.0   0:04.30 vchiq-slot/0
         1345 pi        20   0   10444   3000   2572 R   0.7   0.0   0:11.28 top
            7 root      20   0       0      0      0 I   0.3   0.0   0:19.99 kworker/u8:0-brcmf_wq/mmc1:0001:1
           11 root      20   0       0      0      0 S   0.3   0.0   0:00.56 ksoftirqd/0
           12 root      20   0       0      0      0 I   0.3   0.0   0:02.51 rcu_sched
           89 root     -51   0       0      0      0 S   0.3   0.0   0:02.53 irq/47-mmc0
           94 root      20   0       0      0      0 S   0.3   0.0   0:01.11 jbd2/sda2-8
          252 root      -2   0       0      0      0 S   0.3   0.0   0:01.25 v3d_tfu
         1363 root      20   0       0      0      0 I   0.3   0.0   0:12.62 kworker/u8:4-brcmf_wq/mmc1:0001:1
         1377 root      20   0       0      0      0 I   0.3   0.0   0:00.70 kworker/3:1-events
         1392 root      20   0       0      0      0 I   0.3   0.0   0:00.09 kworker/1:3-events
         1408 root      20   0       0      0      0 I   0.3   0.0   0:00.41 kworker/0:2-events
            1 root      20   0   33708   8296   6680 S   0.0   0.1   0:05.23 systemd
            2 root      20   0       0      0      0 S   0.0   0.0   0:00.01 kthreadd
            3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
            4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
            6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/0:0H-events_highpri
            8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_percpu_wq
            9 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tasks_rude_
           10 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tasks_trace
           13 root      rt   0       0      0      0 S   0.0   0.0   0:00.01 migration/0
           14 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
           15 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
           16 root      rt   0       0      0      0 S   0.0   0.0   0:00.02 migration/1
           17 root      20   0       0      0      0 S   0.0   0.0   0:00.48 ksoftirqd/1
           19 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/1:0H-kblockd
           20 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/2
           21 root      rt   0       0      0      0 S   0.0   0.0   0:00.02 migration/2
           22 root      20   0       0      0      0 S   0.0   0.0   0:00.35 ksoftirqd/2
           24 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/2:0H-kblockd
           25 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/3
           26 root      rt   0       0      0      0 S   0.0   0.0   0:00.01 migration/3
          @plainbroke always please use code block for formatting
          don’t ‘see’ anything…
            Ok this may be my problem : failed to open kms_swrast
            I have seen reference to this before but am either brain dead or my google search is failing me.
            0|mm | MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
            0|mm | failed to load driver: kms_swrast
            0|mm | MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
            0|mm | failed to load swrast driver
            0|mm | [875:0114/170050.541663:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
            0|mm | [875:0114/170113.661954:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
            0|mm | [875:0114/170115.296236:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
            0|mm | [778:0114/170757.084668:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.NetworkManager.GetDevices: object_path= /org/freedesktop/NetworkManager: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.NetworkManager was not provided by any .service files
              no… that is the GPU driver stuff… usually not enabled in /config.txt in 2.26 we disable using the gpu by default to turn off these messages (instead of leaving it on in 2.25 and prior)
                I am still on 2.24 so I can use MMM-RTSPStream, also still on Jesse for the same reason.
                Should I run this to remove swap file?
                sudo swapoff -a -v
                sudo rm /swapfile
                S plainbrokeP 2 Replies Last reply Reply Quote 0
                  @plainbroke so, I would be carefull… newer code doesn’t run on jesse and gosh knows what you have now…
                  4 OS releases back (2017), stretch , buster, bullseye, now bookworm
                  https://en.wikipedia.org/wiki/Raspberry_Pi_OS
                  so, you have an 8gig machine, but can only use 2gig (32bit OS)
                    plainbroke @plainbroke
                    Sorry it is buster, it is the last one that allows the rstp modules I like so much…
                    Linux MM 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l GNU/Linux
                      armv7
                      32bit
                      aaarch64 is 64 bit
                        Can I load the 64bit version without reloading all my MagicMirror modules ect?
                        I tried this :
                        export external_browser=midori
                        export ELECTRON_DISABLE_GPU=1
                        DISPLAY=:0 npm start
