    MMM-GoogleTasks errors out randomly
    7 Posts 3 Posters 1.4k Views 3 Watching
    • A
      angeliKITTYx
      It used to be about once a week, but now it’s happening much more frequently. If I restart MM, the error goes away and the module displays correctly until it errors out again. Does anyone know a solution to this? SS of the error (I blocked out my list ID)
      alt text
      KristjanESPERANTOK 1 Reply Last reply
      • KristjanESPERANTOK
        KristjanESPERANTO Module Developer @angeliKITTYx
        There are some forks of this module, which one do you use? According to my knowledge, the following is the most up-to-date: https://github.com/spydersoft-consulting/MMM-GoogleTasks
        Run git remote -v in the module’s directory to find out.
        A 1 Reply Last reply
        • A
          angeliKITTYx @KristjanESPERANTO
          @KristjanESPERANTO
          ~/MagicMirror/modules/MMM-GoogleTasks $ git remote -v
          origin	https://github.com/themox/MMM-GoogleTasks.git (fetch)
          origin	https://github.com/themox/MMM-GoogleTasks.git (push)
          How do I switch? Thank you so much for your help
            Got to the modules directory:
            cd ~/MagicMirror/modules
            Delete the “old” MMM-GoogleTasks directory:
            rm -r MMM-GoogleTasks
            Clone the fork:
            git clone https://github.com/spydersoft-consulting/MMM-GoogleTasks
            Change to the module directory:
            cd MMM-GoogleTasks
            Install dependencies:
            npm install
            • A
              @KristjanESPERANTO thank you!! I’m trying to set it up and I’m stuck on step 4 of Authentication Setup
              When I run the command, I get an error, and my token.js doesn’t provide any account names or list names to use in the [account] section of the config.
              node authenticate.mjs -c /home/xxxx/MagicMirror/modules/MMM-GoogleTasks/credentials.json -t /home/xxxx/MagicMirror/modules/MMM-GoogleTasks/token.json
              file:///home/burgess/MagicMirror/modules/MMM-GoogleTasks/authenticate.mjs:26
                  currentTokens.forEach(element => {
              TypeError: currentTokens.forEach is not a function
                  at file:///home/xxxx/MagicMirror/modules/MMM-GoogleTasks/authenticate.mjs:26:19
                  at FSReqCallback.readFileAfterClose [as oncomplete] (node:internal/fs/read/context:68:3)
              Node.js v20.10.0
              (replaced my account name with “xxxx”
              kayakbabeK 1 Reply Last reply
              • kayakbabeK
                kayakbabe @angeliKITTYx
                @angeliKITTYx I had a little trouble with the google calender stuff because at first I didn’t realize I had to get a google developer account and then I could setup the api’s. Every once in a while, especially if my mirror has been unplugged for 24 hours, I have to do the authorize again. Also I have to first delete the token file that gets created. The authorize script won’t over write the token. Maybe look at the instructions for the MMM-GoogleCalendar might help you? The two modules seem very similar.
                • A
                  angeliKITTYx @kayakbabe
                  @kayakbabe I have Google calendar and Google photos working on my MM just fine. Both used similar oauth api credential file instructions, but this one seems a little more complicated.
