    Google Calendar issues
    17 Posts 3 Posters 6.3k Views 3 Watching
    • 1 Offline
      1lolo94
      New to the forum - please be nice :)
      I just started setting everything up last night and I cannot get my Google Calendar to show events. I have done many hours of research when it comes to the API, etc and everything is working. I can get the events to show up when I use the default calendar and just add the my google calendar public ics.
      But i would like to show the entire month along with the events - not just the events.
      Any help would be awesome. Below is my current code:
      /* MagicMirror² Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
       * You can use environment variables using a `config.js.template` file instead of `config.js`
       * which will be converted to `config.js` while starting. For more information
       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
      let config = {
      	address: "localhost",	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
      	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
      	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
      	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
      	language: "en",
      	locale: "en-US",
      	timeFormat: 12,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			module: "MMM-MonthlyCalendar",
      			//header: "US Holidays",
      			position: "bottom_bar",
      				mode: "currentMonth",
      						//symbol: "calendar-month",
      						url: "ttps://calendar.google.com/calendar/ical/xxxxxxx81%40gmail.com/private-9059ef2136e455aa1fb835f086a9a788/basic.ics",
      						//timeFormat: "relative",
      						//dateFormat: "MMM Do",
      						//url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
      			module: "weather",
      				type: "current",
      				locationID: "5172078", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				apiKey: "91e6add934ff2f210cd11c994ab94528",
      				roundTemp: true
      			module: "weather",
      			// header: "Weather Forecast",
      				type: "forecast",
      				fade: false,
      				roundTemp: true
        sdetweil @1lolo94
        @1lolo94 said in Google Calendar issues:
        url: "ttps://c
        needs to be
        url:"https://....."
        1 1 Reply Last reply Reply Quote 0
        • 1 Offline
          1lolo94 @sdetweil
          @sdetweil - Thanks for the reply - fixed it and same issue :(
            sdetweil @1lolo94
            @1lolo94 ok that’s not the default calendar, so I don’t know.
              @1lolo94 if you use the url in a browser does it download the ICS file?
              • 1 Offline
                1lolo94 @sdetweil
                @sdetweil Yes it does.
                  sdetweil @1lolo94
                  @1lolo94 can u show the messages were you start mm, npm start .
                  if you use pm2, then
                  pm2 logs --lines=50
                  1 2 Replies Last reply Reply Quote 0
                  • 1 Offline
                    1lolo94 @sdetweil
                    @sdetweil - can you explain more on what you’re requesting? Sorry!! I just started all this last night
                      sdetweil @1lolo94
                      @1lolo94 when MagicMirror starts, using the command npm start, the components that run on the server side output message to the terminal window.
                      if you used my script to install, and said yes to use pm2 to autostart,
                      then the pm2 command launches a little script, which issues the npm start command, and captures that output for display or review later.
                      then you can use the command
                      pm2 logs --lines=nnn
                      where nnn is a number of lines to display. default 15
                      one thing to know about Linux.
                      by convention, each command outputs it’s command parms when executed with --help
                      so
                      pm2 --help
                      • 1 Offline
                        1lolo94 @sdetweil
                        @sdetweil tried it and this is what i see
                        [28.01.2024 19:05.36.543] [INFO] updatenotification: You are not using pm2
                          sdetweil @1lolo94
                          @1lolo94 need more lines
                          • 1 Offline
                            1lolo94 @sdetweil
                            magicmirror@2.26.0 start
                            DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                            [28.01.2024 19:05.32.973] [LOG] Starting MagicMirror: v2.26.0
                            [28.01.2024 19:05.32.981] [LOG] Loading config …
                            [28.01.2024 19:05.32.986] [DEBUG] config template file not exists, no envsubst
                            [28.01.2024 19:05.32.993] [LOG] Loading module helpers …
                            [28.01.2024 19:05.32.996] [LOG] No helper found for module: alert.
                            [28.01.2024 19:05.33.066] [LOG] Initializing new module helper …
                            [28.01.2024 19:05.33.067] [LOG] Module helper loaded: updatenotification
                            [28.01.2024 19:05.33.069] [LOG] No helper found for module: clock.
                            [28.01.2024 19:05.33.070] [LOG] No helper found for module: MMM-MonthlyCalendar.
                            [28.01.2024 19:05.33.073] [LOG] No helper found for module: weather.
                            [28.01.2024 19:05.33.074] [LOG] All module helpers loaded.
                            [28.01.2024 19:05.33.091] [LOG] Starting server on port 8080 …
                            [28.01.2024 19:05.33.494] [LOG] Server started …
                            [28.01.2024 19:05.33.496] [LOG] Connecting socket for: updatenotification
                            [28.01.2024 19:05.33.498] [LOG] Starting module helper: updatenotification
                            [28.01.2024 19:05.33.499] [LOG] Sockets connected & modules started …
                            [28.01.2024 19:05.33.535] [LOG] Launching application.
                            [28.01.2024 19:05.36.493] [INFO] updatenotification: Updater Class Loaded!
                            [28.01.2024 19:05.36.494] [INFO] updatenotification: Checking PM2 using…
                            [28.01.2024 19:05.36.681] [INFO] Checking git for module: MMM-MonthlyCalendar
                            [28.01.2024 19:05.36.718] [INFO] Checking git for module: MagicMirror
                            [28.01.2024 19:05.40.617] [LOG] Shutting down server…
                            [28.01.2024 19:05.40.618] [LOG] Stopping module helper: updatenotification
                            [28.01.2024 19:05.40.619] [LOG] Node_helpers stopped …
                              sdetweil @1lolo94
                              MMM-MonthlyCalendar
                              ok, that is an add on calendar module
                              which appears to do all its operations in the browser side.
                              so on the running mm screen, press ctrl-shift-i ,
                              to open the developers window, and the select the console tab, and enter a unique part of the module name in the filter field, to show just the messages from that module , so month
                              • Z Offline
                                ZiggidyZ
                                I noticed that in the config file you included in a previous post that you do NOT have the default calendar module in there. My thoughts are that this MMM-MonthlyCalendar has some dependency on that the default module, and without it noted in the config you aren’t getting what you expect.
                                As a STARTING point I would recommending adding this to your config file. I’d suggest making sure THAT calendar is working. If it DOES show Holidays but your Google calendar is still NOT working, I would suggest removing the US Holiday link and replace it with your Google calendar link. Then try again.
                                Additionally, the config options for that module you are trying to use does NOT show url as a config option. That likely has to be called from the default module. A concern I am sure you are having is that you don’t want to SEE the default module. I HIGHLY recommend that you use it for the purposes of troubleshooting. Once you get to a point where the MMM-MonthlyCalendar starts working, simply remove or comment out the POSITION line for the default calendar module in your config.
                                Also, did you edit any of the files in the modules in any way? If so, you may want to remove them and install the module again.
                                						symbol: "calendar-check",
                                  sdetweil @ZiggidyZ
                                  @ZiggidyZ you do not have to install again
                                  each module installed (cloned) from GitHub includes the git source repository too.
                                  so
                                  git checkout filename
                                  will restore filename to its repo contents
                                  git status will tell you which files changed,and
                                  git diff will show you the changes
                                  Z 1 Reply Last reply Reply Quote 0
                                  • Z Offline
                                    ZiggidyZ @sdetweil
                                    Thank you!! Good to know! I am not very good with Linux, knowing only enough to really foul things up.
                                      sdetweil @ZiggidyZ
                                      @ZiggidyZ no problem
                                      we all learn as we go… I learn new stuff every day.
