    MMM-WeatherorNot Random Number at Bottom
    5 Posts 2 Posters 1.1k Views 2 Watching
      Splashed
      My Weatherornot module keeps displaying this random number code at the bottom of my module. From looking at others projects, it doesn’t seem like it belongs in the module.
      Can someone tell me how to get rid of it?
        sdetweil @Splashed
        @Splashed well, let’s find out where it came from
        open the developers window, ctrl-shift-i,
        select the elements tab, click the arrow in the top right corner…
        then move the mouse over the mm page so that number is highlighted.
        then that section of the page html will be highlighted.
        print screen that and post here
          Splashed @sdetweil
          I appreciate the direction. I am unable to highlight the number unfortunately. Someone on reddit suggested that what Im seeing in the epoch timestamp. If thats the case, I dont mind seeing it, but Id love to see it in a normal timestamp and perhaps a different color.
            sdetweil @Splashed
            @Splashed hmm… that would be the first time I’ve seen content on the page that didn’t come the mm app.
            if you open the mm url with the system browser, so you see the same results?
            http://localhost:8080
            if you set
            address:"0.0.0.0",
            ipWhitelist:[],
            in config.js and restart mm
            then you can access from your PC, laptop, phone
            http://pi_ip_address_or_hostname:8080
            is it still there
              sdetweil @Splashed
              @Splashed looks like it’s the timestamp of the iframe content
              from the code
              the author is not available, so someone would have to fork and provide a fix
              you could edit the .js file and remove that +…
              on line 82
