    node_helper.js is not working?
    49 Posts 3 Posters 23.5k Views 3 Watching
      sdetweil @vandy2424
      @vandy2424 can you do
      cd  ~/Documents/MagicMirror/config
      ls -laF
      • V Offline
        vandy2424 @sdetweil
        @sdetweil Yes, here is the output:
        jackson@raspberrypi:~/Documents/MagicMirror/config $ ls -LaF
        ./  ../  config.js*  config.js.sample  .config.js.swp
          sdetweil @vandy2424
          @vandy2424 lower case L
          -laF
          • V Offline
            vandy2424 @sdetweil
            @sdetweil Apologies.
            jackson@raspberrypi:~/Documents/MagicMirror/config $ ls -laF
            total 20
            drwxr-xr-x  2 jackson jackson 4096 Feb  9 19:19 ./
            drwxr-xr-x 18 jackson jackson 4096 Feb  2 10:27 ../
            -rwxrwxrwx  1 root    root    1998 Feb  9 19:19 config.js*
            -rw-r--r--  1 jackson jackson 3534 Feb  2 10:27 config.js.sample
            -rw-r--r--  1 jackson jackson 1024 Feb  2 12:12 .config.js.swp
              sdetweil @vandy2424
              @vandy2424
              change the permissions owner and group
              exit the editor
              sudo chown jackson config.js
              sudo chgrp jackson config.js
              • V Offline
                vandy2424 @sdetweil
                @sdetweil Okay I ran both of those commands.
                  sdetweil @vandy2424
                  @vandy2424 and try starting mm again
                  • V Offline
                    vandy2424 @sdetweil
                    @sdetweil The calendar module still says loading… Everything else is the same as it was. Both logs show exactly the same as well.
                      sdetweil @vandy2424
                      @vandy2424 can you confirm the permissions change?
                      ls -laF
                      I can explain it
                      access to the file fails at startup time
                      fs.accessSync() js/app.js, line 117
                      so defaults is used… thats node helpers
                      file is loaded in the browser anyhow(index.html), and that controls module loading in browser
                      S V 2 Replies Last reply Reply Quote 0
                        @sdetweil I will test in the morning
                        • 4 / 5
