    Best practice 'package-lock.json' for modules
    18 Posts 5 Posters 9.6k Views 5 Watching
    • KristjanESPERANTOK Offline
      KristjanESPERANTO Module Developer @sdetweil
      Wouldn’t that also be a good idea for the core? It would probably make sense to use the same strategy for the core as for the modules.
      @rejas @karsten13
        sdetweil @KristjanESPERANTO
        @KristjanESPERANTO well we use it to control the test platforms. but you can’t delete it for clone
          @KristjanESPERANTO i just did an npm ci in a module folder with no package-lock.json and it complained that it required package-lock.json
          pi@raspberrypi5:~/Documents/MagicMirror/modules/MMM-Soliscloud $ npm ci
          npm ERR! code EUSAGE
          npm ERR!
          npm ERR! The `npm ci` command can only install with an existing package-lock.json or
          npm ERR! npm-shrinkwrap.json with lockfileVersion >= 1. Run an install with npm@5 or
          npm ERR! later to generate a package-lock.json file, then try again.
          npm ERR!
            That’s the point of npm ci it takes the package-lock.json to install and it don’t change it.
              KristjanESPERANTO Module Developer @KristjanESPERANTO
              Can you show me where?
              S karsten13K 2 Replies Last reply Reply Quote 0
                @KristjanESPERANTO in the npm install on the different test instances. I don’t build those
                these are effectively docker images, build and execute, throw away
                • karsten13K Offline
                  karsten13 @KristjanESPERANTO
                  @KristjanESPERANTO said in Best practice 'package-lock.json' for modules:
                  we don’t use npm ci but I’m not sure what npm install does if package-lock.json is present.
                  I do the tests after building my docker images on my own and I always delete package-lock.json before running npm install to be sure getting the newest deps.
                    sdetweil @karsten13
                    @karsten13 package-lock is SUPPOSED to insure installing EXACTLY those versions every time
