    how alert trigger
    alertsmodulemqtt
    15 Posts 3 Posters 7.3k Views 3 Watching
    • F
      fischi87
      Hello guys, first of all sorry about my english 😅
      i want find a way th trigger a alert wehn my washmaschine is finish. im using iobroker for my homeassistent. i was thinking maybe is it possible to do this with the adapter simple-api where i get the state with a url ( true/false) but how can i trigger a alert when the state change.
      someone a idea? or maybe a other way, mqtt or something?
      thanks
      greedings
      wishmaster270W 1 Reply Last reply
      • wishmaster270W
        wishmaster270 Module Developer @fischi87
        @fischi87 Hi, you could i.e. connect the mirror to iobroker with my MMM-MQTTbridge module and send a notification to the alert module depending of the state change.
        F 1 Reply Last reply
        Reply Quote 2
        • F
          fischi87 @wishmaster270
          @wishmaster270
          Thanks for ur reply. I See this already but i dont know how to send the trigger u know what i mean? Maybe do u have a example for me?
          wishmaster270W S 3 Replies Last reply
          • wishmaster270W
            @fischi87 Hi and sorry. I use node red instead of iobroker and do not have a glue of it.
            You will need a MQTT integration in iobroker, a MQTT broker and the MQTT module in the mirror.
            If the device changes state iobroker gets notice of it and sends a message to a MQTT topic.
            You can subscribe to this topic with the MQTT module in the mirror and initiate a notification with it.
            The alert module can display the message in the notification in the result.
            • wishmaster270W
              @fischi87 Sorry, do not know where I read iobroker but Home Assistant has a MQTT integration, too.
                sdetweil @fischi87
                @fischi87 do you mean send notification? for send trigger?
                • F
                  @wishmaster270
                  iobroker have also a MQTT instance. so maybe I will give it a try. but the readme looks difficult :-)
                  • F
                    fischi87 @sdetweil
                    like I wrote I want see a alert in my mirror that shows me the Washer finished washing. the question is how I can trigger the alert or maybe a notification, is also a idea. when I think about. how can I do it, do u have a idea?
                      sdetweil @fischi87
                      @fischi87 @wishmaster270 gave you the answer with his MQTTBridge module
                      hears the mqtt message and can send a notification to the alert module.
                      you configure both
                      • F
                        fischi87 @sdetweil
                        hello again, I connected now this modul with my broker but how can I send a notification to the alert model? this I don’t understand right now. maybe u or someone else can help me in this topic please?
                        thanks
                          sdetweil @fischi87
                          @fischi87 yeh it’s a little bit of thinking, as it is two part
                          starting here
                          1. define the mqtt topic and an arbitrary ‘command’ word to execute when the topic is heard (mqttHook)
                          2. define the ‘command’ that has the notification and the payload (mqttNotiCommands)
                          and from the alert module doc, start here
                          F 2 Replies Last reply
                          • F
                            fischi87 @sdetweil
                            first of all thank u for ur time.
                            i dont understand where i have to write down the sendnotification. i mean i can see in my broker the examples from the mqtt module but how it works now. my understanding is to write something in the config to trigger the alarm.
                            for example i use the example from the brige modul how can i use this exemple to trigger a alert? i hope u can understand me.
                            thanks
                            • F
                              fischi87 @sdetweil
                              i have also a other idea. maybe it is easier to trigger the alert with the MMM-Api module? my broker have also a simple-api adapter.
                              but its still my question, how?
                                sdetweil @fischi87
                                @fischi87 YOU don’t do the sendnotification.
                                you take the data from it and configure the module to send it.
                                I was just showing you the doc for the alert.module that describes what it wants
                                a string for the notification value
                                and a object for the notification payload
                                these two things go in the command section
                                • F
                                  fischi87 @sdetweil
                                  im so sorry but I don’t understand it. like I wrote I can see the examples in my Mqtt broker.
                                  when I change in my broker the messages I can also see in the log from the mirror that it changed this values but how can I trigger with this a alert for example or a notification? what I have to configure? in the config.js file by the module: MMM-MQTT-Bridge? when yes what? I copy the examples already.
