    Notification customize
    10 Posts 2 Posters 2.3k Views 2 Watching
    • F
      fischi87
      Hello guys, i want to customize my notification but i dont know how. someone did it already?
      i want to show the notification in the bottom center. i want also that it looks like the alert frame. is this possible?
      thanks for ur time greedings
      M 1 Reply Last reply
      • M
        MMRIZE @fischi87
        @fischi87
        From WHERE are your notification origins? What kind of notification? And How/When is it triggered? Can you describe the use case in more detail?
        F 1 Reply Last reply
        • F
          fischi87 @MMRIZE
          @MMRIZE
          Hello, sorry, yes of course. i get a mqtt payload from the MMM-MQTTbridge module.
          for this i have this code snippet:
              commandId: "Finish",
              notiID: "SHOW_ALERT",
              notiPayload: { type: 'notification', message: 'Der Monitor ist eingeschaltet.'}
          i hope it will help! or do u need more informations?
          • M
            MMRIZE @fischi87
            @fischi87
            I don’t know well about MMM-MQTTbridge, but AFAIK, that module can emit custom notifications like your code snippet. When your codes work, a SHOW_ALERT notification will be delivered to the alert module, so you may be able to see the alert message itself.
            Therefore, What you want is just to take the alert module into the bottom_center area, right?
            • F
              fischi87 @MMRIZE
              @MMRIZE
              The Problem is, when i send just the Alert without the notification Type, the alert Display in Center with a other Looks Like. So i think this Are 2 different things. I want the different between notification and the alert.
              I work with notification from other modules?
              • M
                MMRIZE @fischi87
                @fischi87
                So, what you want is this kind? Instead of top position than bottom position?
                You can override most of presentation with css.
                Append this into your custom.css
                /* css/custom.css */
                .ns-box {
                  position: absolute;
                  left: 0;
                  right: 0;
                  bottom: 10px;
                .ns-effect-slide-center.ns-show {
                  animation: new-anim-slide-elastic-center 1s ease;
                @keyframes new-anim-slide-elastic-center {
                  0% {
                    opacity: 0;
                    transform: translateY(100%);
                  90% {
                    opacity: 1;
                    transform: translateY(-20px);
                  100% {
                    opacity: 1;
                    transform: translateY(0);
                You may need hiding animation. guess it by yourself. :)
                • F
                  fischi87 @MMRIZE
                  @MMRIZE
                  thanks that looks fine and this is a alert or alert with type notification? because i need the type notification. if i get more than one notification the alert displayed just the last one and the notification more than just one. u know what i mean?
                  M 2 Replies Last reply
                  • M
                    MMRIZE @fischi87
                    @fischi87
                    It is for type: 'notification'.
                    I used this;
                    this.sendNotification('SHOW_ALERT', {
                            title: 'Test Module',
                            message: 'I am a test notification',
                            timer: 10000,
                    • M
                      MMRIZE @fischi87
                      @fischi87
                      But what you want is a stackable something; it needs another CSS modification. (I thought only single notification case.)
                      • F
                        fischi87 @MMRIZE
                        @MMRIZE
                        i will give it a try later with ur css data and let u know if its work. thank man.
