    Can anyone revive AviationWX, PilotWX, or TAF
    36 Posts 3 Posters 13.6k Views 3 Watching
    • F
      FSAHD
      I am in the process of becoming a pilot and I would love to have the information these modules offer at a glance instead of having to look it up every time.
      I tried, with the help of AI to update the code as I believe they were using the request fuction which is deprecated. I even tried to create a module from scratch which right now is a failure lol.
      I am not the best at coding but if I can get a mentor I will definitely help keep the module up and running
        sdetweil @FSAHD
        @FSAHD sure, you can use my sample module
        at least it works.
        https://github.com/sdetweil/SampleModule
        where is the data you want to show and what api might be available to get that data
        • F
          FSAHD @sdetweil
          From what I have been able to tell I have 2 options however, I think https://aviationweather.gov/data/api/#/Data/dataMetars is going to be the better source (the other one is avwx.rest which needs users to sign up and create a token to use). I can send you a token for avwx if you need.
          FWIW I can also share the repository for the Module I was working on
            sdetweil @FSAHD
            @FSAHD is the problem just the use of request?
            that can be fixed w very little code change
            • F
              FSAHD @sdetweil
              @sdetweil that is what I believe it it, also what the AI helped me deduce.
              I attempted to solve that but was unsuccessful. I believe that was the problem with all 3 modules I mentioned.
              I tried using npm install request. that didnt work.
              Then I attempted to update the code to use axios
                sdetweil @FSAHD
                @FSAHD OK, let me look at them
                  sdetweil @FSAHD
                  @FSAHD well every url changed, and all the data
                  changed. some has to be calculated (avg airport delay) or that info display deleted.
                  too much work for me., given my avaliable time
                  • F
                    FSAHD @sdetweil
                    @sdetweil I appreciate you looking into this. ill take some time and see wat I can do!
                      sdetweil @FSAHD
                      @FSAHD I got the metar to work, then the faa data is all different not by airport request. and all the variable names have changed too
                      don’t know if the data is different for display
                      and the data is xml
                      • F
                        FSAHD @sdetweil
                        @sdetweil I know the airport delay item is last on the wish list.
                        I can take over and update variables and such. wherever you left off ill be happy to take over!
                          sdetweil @FSAHD
                          @FSAHD ok, let me finish the faa data . I was working on it this morning
                            sdetweil @FSAHD
                            @FSAHD ok, here is the partially updated MMM-aviationwx
                            https://github.com/sdetweil/MMM-aviationwx
                            there is a file of the output sent back from the node_helper( this morning) in formatted json (sample-data.txt)
                            so you can see the field names and values…
                            I marked in the MMM-aviationwx.js in getDom() where all this needs to be corrected with correct variable names and values…
                            as an example
                                  var icao = airport.id;
                            airport.id is now airport.station_id
                            “station_id”: “KSFO”,
                            • F
                              FSAHD @sdetweil
                              @sdetweil Thanks again for the help.
                              I think I have all the variables updated. Im c urrently working on trying to get the dependencies to install on my pi so I can test.
                              You were a big help and I see where I went wrong in a lot of places when I was trying to build from scratch. It was a lot of simple mistakes lol
                              S 2 Replies Last reply Reply Quote 1
                                sdetweil @FSAHD
                                @FSAHD great news.
                                dependencies?
                                package.json has them all for the module
                                so npm install will do all for the module
                                use my install script for mm
                                  sdetweil @FSAHD
                                  @FSAHD a lot of simple mistakes…
                                  computers do things fast. whatever we tell them… lol
                                  • F
                                    FSAHD @sdetweil
                                    @sdetweil I tried that after I cloned the git into the modules folder.
                                    I ended up getting this error.
                                    I also don’t remember if I used your script for this instance of mm or if I installed manually if that makes any difference
                                      sdetweil @FSAHD
                                      @FSAHD ok, let me look at it in a couple hours
                                      • mumblebajM
                                        mumblebaj Module Developer @sdetweil
                                        @sdetweil I think to resolve just do npm uninstall request and will remove request from the package,json. Else it will try to install it and you will run into the errors above.
                                          sdetweil @mumblebaj
                                          @mumblebaj but the code uses request…
                                          It downloads a now gz folder, with one xml file in it… I tried to use fetch and couldn’t get it to unzip the file in stream…
                                          2 days, gave up
                                          I installed ok on a pi4 after doing my script install
                                          warnings but no failures
                                          npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                                          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                          npm WARN deprecated joi@13.7.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
                                          added 66 packages, and audited 67 packages in 46s
                                          2 packages are looking for funding
                                            run `npm fund` for details
                                          6 vulnerabilities (2 moderate, 4 high)
                                          To address issues that do not require attention, run:
                                            npm audit fix
                                          To address all issues possible (including breaking changes), run:
                                            npm audit fix --force
                                          Some issues need review, and may require choosing
                                          a different dependency.
                                          Run `npm audit` for details.
                                          sam@raspberrypi4:~/MagicMirror/modules/MMM-aviationwx $
                                          mumblebajM 2 Replies Last reply Reply Quote 0
                                            sdetweil @FSAHD
                                            @FSAHD i just pushed a fix to package.json and a new postinstall script
                                            git pull to get the updates…(watch out that it doesn’t overwrite your code)
                                            then the postinstall script from the module folder
                                            ./postinstall
                                            it will be called by npm install as well…
