    Blank screen after a couple of hours
    19 Posts 2 Posters 4.6k Views 3 Watching
      bradley1982
      Hi there,
      Getting a blank screen however can still see the mirror on the Remote Control module on my phone.
      I have ran a config check which is all clear however when i ran npm run server i get the following:
      magicmirror@2.26.0 server
      node ./serveronly
      [12.04.2024 18:14.50.872] [LOG] Starting MagicMirror: v2.26.0
      [12.04.2024 18:14.50.882] [LOG] Loading config …
      [12.04.2024 18:14.50.887] [DEBUG] config template file not exists, no envsubst
      [12.04.2024 18:14.50.909] [LOG] Loading module helpers …
      [12.04.2024 18:14.50.912] [LOG] No helper found for module: alert.
      [12.04.2024 18:14.50.983] [LOG] Initializing new module helper …
      [12.04.2024 18:14.50.986] [LOG] Module helper loaded: updatenotification
      [12.04.2024 18:14.50.989] [LOG] No helper found for module: clock.
      [12.04.2024 18:14.51.559] [LOG] Initializing new module helper …
      [12.04.2024 18:14.51.563] [LOG] Module helper loaded: calendar
      [12.04.2024 18:14.51.566] [LOG] No helper found for module: MMM-CalendarExt3.
      [12.04.2024 18:14.51.735] [LOG] Initializing new module helper …
      [12.04.2024 18:14.51.736] [LOG] Module helper loaded: MMM-OpenWeatherMapForecast
      [12.04.2024 18:14.51.761] [LOG] Initializing new module helper …
      [12.04.2024 18:14.51.762] [LOG] Module helper loaded: MMM-MyScoreboard
      [12.04.2024 18:14.52.200] [LOG] Initializing new module helper …
      [12.04.2024 18:14.52.201] [LOG] Module helper loaded: MMM-Remote-Control
      [12.04.2024 18:14.52.202] [LOG] No helper found for module: MMM-Carousel.
      [12.04.2024 18:14.53.227] [LOG] Initializing new module helper …
      [12.04.2024 18:14.53.229] [LOG] Module helper loaded: MMM-Todoist
      [12.04.2024 18:14.53.230] [LOG] No helper found for module: MMM-CountDown.
      [12.04.2024 18:14.54.066] [LOG] Initializing new module helper …
      [12.04.2024 18:14.54.067] [LOG] Module helper loaded: MMM-MovieListings
      [12.04.2024 18:14.54.250] [LOG] Initializing new module helper …
      [12.04.2024 18:14.54.251] [LOG] Module helper loaded: MMM-OnSpotify
      [12.04.2024 18:14.55.320] [LOG] Initializing new module helper …
      [12.04.2024 18:14.55.321] [LOG] Module helper loaded: MMM-NewsFeedTicker
      [12.04.2024 18:14.55.623] [LOG] Initializing new module helper …
      [12.04.2024 18:14.55.624] [LOG] Module helper loaded: newsfeed
      [12.04.2024 18:14.55.625] [LOG] All module helpers loaded.
      [12.04.2024 18:14.55.646] [LOG] Starting server on port 8080 …
      [12.04.2024 18:14.55.654] [WARN] You’re using a full whitelist configuration to allow for all IPs
      [12.04.2024 18:14.55.700] [ERROR] Whoops! There was an uncaught exception…
      [12.04.2024 18:14.55.729] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
      at Server.setupListenHandle [as _listen2] (node:net:1872:16)
      at listenInCluster (node:net:1920:12)
      at doListen (node:net:2069:7)
      at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
      code: ‘EADDRINUSE’,
      errno: -98,
      syscall: ‘listen’,
      address: ‘0.0.0.0’,
      port: 8080
      [12.04.2024 18:14.55.730] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [12.04.2024 18:14.55.731] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      Still really new to this any ideas how i can fix this?
      Many thanks in advance!
        sdetweil @bradley1982
        @bradley1982 that means another instance of mm is already running
          bradley1982 @sdetweil
          @sdetweil Hi Sam,
          how do i fix this?
            @bradley1982 how does magicmirror get started? pm2 at boot?
            if so , pm2 can do lots of things, from a terminal window do
            pm2 status
            pm2 stop all
            and then
            pm2 --help
            for a list of all the options available
              @sdetweil HI sam,
              it auto lauches when the pi reset.
              it seems to work for a couple of hours/day and then i get the blank screen with the cursor. I can see it on the remote control app and look ok but the screen is blank.
              When i reset the pi it works ok for the same period… and the blank screen?
              is there a log that i can run to figure out what is causing it?
              again really new to all this and need an idiot guide lol
                @bradley1982 i assume you use pm2 to autostart.
                if so, then
                pm2 logs --lines=xxxx
                where xxxx is a number of lines to display from the latest part of the logs.
                xxxx defaults to 15
                there are only 500 places where one needs a guide. lol.
                  @sdetweil lol!
                  cool i have ran that, presume that i check this later and see if i get an error message form one of the modules?
                  sorry for the stupid questions
                    @bradley1982 yes, you can empty the current (old) collection of log messages by
                    pm2 flush
                      @sdetweil got this initially when i ran it … (pm2 log)
                      /home/bradley/.pm2/logs/MagicMirror-error.log last 15 lines:
                      0|MagicMir | [12.04.2024 18:49.13.303] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                      0|MagicMir | [12.04.2024 18:49.18.690] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                      0|MagicMir | [12.04.2024 18:49.18.691] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                      0|MagicMir | [12.04.2024 18:49.18.692] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                      0|MagicMir | [12.04.2024 18:49.18.843] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                      0|MagicMir | [12.04.2024 18:49.18.868] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                      0|MagicMir | [12.04.2024 18:49.18.890] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                      0|MagicMir | Warning: vkCreateInstance: Found no drivers!
                      0|MagicMir | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                      0|MagicMir | at CheckVkSuccessImpl (…/…/third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                      0|MagicMir | at CreateVkInstance (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                      0|MagicMir | at Initialize (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                      0|MagicMir | at Create (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                      0|MagicMir | at operator() (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                      0|MagicMir |
                      many thanks
                      paul
                        @bradley1982 those are garbage error messages from electron. which we cant suppress. ignore them
