    unexpected token error
    12 Posts 3 Posters 2.8k Views 3 Watching
    • G Offline
      Guku
      Hello, i ran update for MMM-OpenWeatherMapForecast module and once i restarted MM i get this error
      [ERROR] SyntaxError: Error parsing /home/lolo/MagicMirror/modules/MMM-OpenWeatherMapForecast/package.json: Unexpected token ‘]’, …“ast”,
      “ma”… is not valid JSON
      this is my config module
      			module: "MMM-OpenWeatherMapForecast",
      			header: "xxxx",
      			classes: "default everyone",
      			disabled: false,
      			  apikey: "xxxx",
      			  latitude: "xxx",
      			  longitude: "-xxx",
      			  iconset: "1c",
      			  concise: false,
      			  forecastLayout: "table",
      			  showDailyForecast: true,
      			  maxDailiesToShow: "6",
      			  useAnimatedIcons: true,
      			  animateMainIconOnly: false,
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @sdetweil
        There is a comma to much at the end of the keywords array: "Forecast",
        S G 2 Replies Last reply Reply Quote 0
          sdetweil @Guku
          @Guku said in unexpected token error:
          that file…
          not your config
          • G Offline
            Guku @sdetweil
            "name": "mmm-openweathermapforecast",
            "version": "1.0.0",
            "description": "MagicMirror² module that gets weather forecast data from OpenWeatherMap",
            "repository": {
                "type": "git",
                "url": "git+https://github.com/MarcLandis/MMM-OpenWeatherMapForecast"
            "keywords": [
                "MagicMirror",
                "MagicMirror²",
                "Weather",
                "OpenWeatherMap",
                "Forecast",
            "main": "MMM-OpenWeatherMapForecast.js",
            "scripts": {
                "test": "echo \"Error: no test specified\" && exit 1"
            "author": "Jeff Clarke",
            "license": "MIT",
            "dependencies": {
                "moment": "^2.28.0",
                "needle": "^2.5.2"
            • G Offline
              Guku @sdetweil
              sorry,
              "version": "1.0.0",
              "repository": {
                  "type": "git",
              "keywords": [
                  "MagicMirror",
                  "MagicMirror²",
                  "Weather",
                  "OpenWeatherMap",
                  "Forecast",
              "scripts": {
              "license": "MIT",
              "dependencies": {
                  "needle": "^2.5.2"
                sdetweil @Guku
                @Guku its missing the leading { as first line
                G KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                • G Offline
                  Guku @sdetweil
                  its there, i copied it wrong
                  “name”: “mmm-openweathermapforecast”,
                  “version”: “1.0.0”,
                  “description”: “MagicMirror² module that gets weather forecast data from OpenWeatherMap”,
                  “repository”: {
                  “type”: “git”,
                  “url”: “git+https://github.com/MarcLandis/MMM-OpenWeatherMapForecast”
                  “keywords”: [
                  “MagicMirror”,
                  “MagicMirror²”,
                  “Weather”,
                  “OpenWeatherMap”,
                  “Forecast”,
                  “main”: “MMM-OpenWeatherMapForecast.js”,
                  “scripts”: {
                  “test”: “echo "Error: no test specified" && exit 1”
                  “author”: “Jeff Clarke”,
                  “license”: “MIT”,
                  “dependencies”: {
                  “moment”: “^2.28.0”,
                  “needle”: “^2.5.2”
                      sdetweil @KristjanESPERANTO
                      @KristjanESPERANTO said in unexpected token error:
                      There is a comma to much at the end of the keywords array: “Forecast”,
                      javascript is very accepting of TOO MANY commas…
                      and NOT accepting of not enough .
                      but I don’t understand what MM is complaining about the package.json
                      unless its the enhancement to updateNotification…
                      • G Offline
                        Guku @KristjanESPERANTO
                        @KristjanESPERANTO
                        that was it! thank you so much!
                        it loads now.
                          @sdetweil said in unexpected token error:
                          That’s right about JavaScript. But trailing commas are a syntax error in JSON files.
                            never mind… I didn’t catch that it was in json file…
                            but the user shouldn’t be editing the file… so its the authors error…
                            as the author just updated it I think
                            but how did he npm install??
                            unless he did a git pull and didn’t npm install
                            I see this latest is the case, as you opened issue.
                            I updated to point the way …
                            KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
                              My Pull Request has been merged :-)
                              Users have to update the module, then the problem should be solved.
