    MM won't start up after upgrading to 2.27
    11 Posts 2 Posters 3.2k Views 2 Watching
    • N Offline
      nobbie35
      I just upgraded to 2.27. I have backed up my config, modules, css now my mirror isn’t running.
      I did the following
      git pull && npm run install-mm
      Upon completion of the install everything checked out and looked good
      changed 2 packages in 2m
      MagicMirror² installation finished successfully!
      I then went and restarted my magic mirror using my npm restart and it shows the following but its not running?
      [PM2] mm ✓
      │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
      │ 0 │ mm │ default │ 2.27.0 │ fork │ 2165 │ 0s │ 1 │ online │ 0% │ 3.0mb │ k │ disabled │
        sdetweil @nobbie35
        @nobbie35 do
        pm2 stop all
        cd~/MagicMirror
        npm start
        what happens
        in your pm2 output above the number after fork
        is the number of times the app has been. restarted since the last boot
        2165 is a lot…
        • N Offline
          nobbie35
          I have updated all of my custom changes back into this after the update ie config, css, modules
          I did an npm start and here is my output
          :~/Dashboard/MagicMirror $ npm start
          > magicmirror@2.27.0 start
          [2024-04-26 15:59:34.482] [LOG]   Starting MagicMirror: v2.27.0
          [2024-04-26 15:59:34.534] [LOG]   Loading config ...
          [2024-04-26 15:59:34.539] [LOG]   config template file not exists, no envsubst
          [2024-04-26 15:59:34.545] [LOG]   Loading module helpers ...
          [2024-04-26 15:59:34.644] [LOG]   Initializing new module helper ...
          [2024-04-26 15:59:34.646] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
          [2024-04-26 15:59:34.902] [LOG]   Initializing new module helper ...
          [2024-04-26 15:59:34.902] [LOG]   Module helper loaded: MMM-Wallpaper
          [2024-04-26 15:59:34.903] [LOG]   No helper found for module: clock.
          [2024-04-26 15:59:35.099] [LOG]   Initializing new module helper ...
          [2024-04-26 15:59:35.100] [LOG]   Module helper loaded: calendar
          [2024-04-26 15:59:35.101] [LOG]   No helper found for module: MMM-CalendarExt3.
          [2024-04-26 15:59:37.975] [LOG]   Initializing new module helper ...
          [2024-04-26 15:59:37.980] [LOG]   Module helper loaded: MMM-GoogleCalendar
          [2024-04-26 15:59:37.982] [LOG]   Initializing new module helper ...
          [2024-04-26 15:59:37.983] [LOG]   Module helper loaded: MMM-CustomMessage
          [2024-04-26 15:59:38.665] [ERROR] (node:2997) UnhandledPromiseRejectionWarning: Error: Cannot find module 'googleapis'
          Require stack:
          - /home/k/Dashboard/MagicMirror/modules/MMM-GoogleTasks/node_helper.js
          - /home/k/Dashboard/MagicMirror/js/app.js
          - /home/k/Dashboard/MagicMirror/js/electron.js
              at Module._resolveFilename (node:internal/modules/cjs/loader:1055:15)
              at s._resolveFilename (node:electron/js2c/browser_init:2:115476)
              at Module._resolveFilename (/home/k/Dashboard/MagicMirror/node_modules/module-alias/index.js:49:29)
              at Module._load (node:internal/modules/cjs/loader:908:27)
              at c._load (node:electron/js2c/node_init:2:13672)
              at Module.require (node:internal/modules/cjs/loader:1122:19)
              at require (node:internal/modules/helpers:130:18)
              at Object.<anonymous> (/home/k/Dashboard/MagicMirror/modules/MMM-GoogleTasks/node_helper.js:2:18)
              at Module._compile (node:internal/modules/cjs/loader:1256:14)
              at Module._extensions..js (node:internal/modules/cjs/loader:1311:10)
              at Module.load (node:internal/modules/cjs/loader:1098:32)
              at Module._load (node:internal/modules/cjs/loader:945:12)
              at loadModule (/home/k/Dashboard/MagicMirror/js/app.js:183:19)
          (Use `electron --trace-warnings ...` to show where the warning was created)
          [2024-04-26 15:59:38.667] [ERROR] (node:2997) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          [3112:0426/155940.054621:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
          [3112:0426/155940.055560:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
          • N nobbie35 has marked this topic as unsolved on
          • N Offline
            nobbie35 @sdetweil
            @sdetweil Just for extra context I have updated my config css and modules from my backup
            I also have rebooted and completed your steps above… here is the output
            Require stack:
              sdetweil @nobbie35
              @nobbie35 yes looks like you forgot to do npm install in one module folder
              • N Offline
                nobbie35 @sdetweil
                @sdetweil I didn’t realize that you have to reinstall all of the modules after an install I’ve been running MM for over a year and have upgraded before like this and never had to npm install each of the modules again… I’ll go back and reinstall all of them just incase and report back
                  sdetweil @nobbie35
                  @nobbie35 if you use my upgrade script I handle this for you
                  see
                    sdetweil @nobbie35
                    @nobbie35 yes, but what happens is always subject to change…
                    so looking at the messages tells you a module had trouble finding a library
                    which should lead you back to npm install for that module
                    • N Offline
                      nobbie35 @sdetweil
                      @sdetweil I npm installed the Google Tasks module and its still throwing the same error
                        sdetweil @nobbie35
                        @nobbie35 where did you do the npm install, what folder were you in?
                        I see the problem
                        the module doesn’t have a package.json file, so the loaded module is considered a security risk and is removed
                        do
                        npm init -y
                        then
                        npm install googleapis
                        • N Offline
                          nobbie35 @sdetweil
                          @sdetweil Thank you… that was the issue
                          • N nobbie35 has marked this topic as solved on
