    MMM-SunnyPortal not reading data - more then one plants not showing any values on MM2
    14 Posts 2 Posters 3.2k Views 2 Watching
    • F
      frits.erasmus
      I have two PV systems on my account.
      The one is redundant as I have upgraded dramatically in the past (Feb 2020)
      The two are:-
      Frits Midlands Estate - redundant
      Frits Erasmus - active
      I can create a guest account for you if you need access to figure out how to resolve this.
      Regards
      Frits Erasmus
      email is My name . My Surname at gmail
      Any takers or suggestions on how to resolve this?
        sdetweil @frits.erasmus
        @frits-erasmus did you do the npm install
        • F
          frits.erasmus
          Hi sdetwell,
          Yes, I did, but to play it safe I ran it again and paid close attention to feedback (blush) have not done that before.
          I got this feedback:
          up to date, audited 58 packages in 6s
          2 packages are looking for funding
            run `npm fund` for details
          2 moderate severity vulnerabilities
          Some issues need review, and may require choosing
          a different dependency
          Run `npm audit` for details.
          So I ran this:
          npm fund
          mmm-sunnyportal@1.4.0
          +-- https://github.com/sponsors/feross
          |   `-- safe-buffer@5.2.1
          `-- https://github.com/sponsors/epoberezkin
              `-- ajv@6.12.6](link url
          AND
          npm audit
          # npm audit report
          request  *
          Severity: moderate
          Server-Side Request Forgery in Request - https://github.com/advisories/GHSA-p8p7-x288-28g6
          Depends on vulnerable versions of tough-cookie
          No fix available
          node_modules/request
          tough-cookie  <4.1.3
          Severity: moderate
          tough-cookie Prototype Pollution vulnerability - https://github.com/advisories/GHSA-72xf-g2v4-qvf3
          No fix available
          node_modules/tough-cookie
          a different dependency.
          I have to admit - MOST of this went right over my head
          Can you please help me here?
            @frits-erasmus thx. those other commands do t help w info.
            now, show the output from starting MagicMirror, where you do npm start
            F 3 Replies Last reply
            • F
              frits.erasmus @sdetweil
              @sdetweil Not 100% sure what you meant:
              This:
              frits@raspberrypi:~/MagicMirror/modules/MMM-SunnyPortal $ npm install
              OR this:-
              • F
                npm install
                frits@raspberrypi:~/MagicMirror/modules/MMM-SunnyPortal $ ^C
                frits@raspberrypi:~/MagicMirror/modules/MMM-SunnyPortal $ npm fund
                    `-- ajv@6.12.6
                frits@raspberrypi:~/MagicMirror/modules/MMM-SunnyPortal $ npm audit
                # npm audit report
                request  *
                Severity: moderate
                No fix available
                tough-cookie  <4.1.3
                Severity: moderate
                No fix available
                • F
                  frits@raspberrypi:~/MagicMirror/config $ pm2 start mm
                  [PM2] Applying action restartProcessId on app [mm](ids: [ 0 ])
                  [PM2] mm ✓
                  [PM2] Process successfully started
                  │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                  │ 0 │ mm │ fork │ 3 │ online │ 0% │ 2.8mb │
                    @frits-erasmus no. how do you start MagicMirror?
                    if at boot w pm2, then do
                    pm2 stop all
                    then
                     cd ~/MagicMirror
                    npm start
                    see if there are any messages relative to this module
                    to stop MagicMirror
                    press ctrl-q
                    to restart as on boot
                    do
                    pm2 status
                    pm2 restart  xxx
                    where xxx is the number on the line or name on the line of the app you want to start (I have 10 apps on mine, with multiple copies of MagicMirror… so I have to use the number)
                    start and restart do the same when the app not running
                    F 1 Reply Last reply
                    • F
                      @sdetweil said in MMM-SunnyPortal not reading data - more then one plants not showing any values on MM2:
                      pm2 restart
                      [2024-05-10 15:27:39.078] [LOG] SocketNotification START_SUNNYPORTAL received for the first time…setting updateInterval to 900000ms
                      [2024-05-10 15:27:39.083] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing day data
                      [2024-05-10 15:27:39.260] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing month data
                      [2024-05-10 15:27:39.275] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing year data
                      [2024-05-10 15:27:39.293] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing total data
                      • F
                        frits.erasmus
                        frits@raspberrypi:~/MagicMirror $ npm start
                        magicmirror@2.27.0 start
                        DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                        [2024-05-10 16:13:26.448] [LOG] Starting MagicMirror: v2.27.0
                        [2024-05-10 16:13:26.523] [LOG] Loading config …
                        [2024-05-10 16:13:26.533] [LOG] config template file not exists, no envsubst
                        [2024-05-10 16:13:26.543] [LOG] Loading module helpers …
                        [2024-05-10 16:13:26.545] [LOG] No helper found for module: alert.
                        [2024-05-10 16:13:27.288] [LOG] Initializing new module helper …
                        [2024-05-10 16:13:27.289] [LOG] Module helper loaded: updatenotification
                        [2024-05-10 16:13:28.046] [LOG] Initializing new module helper …
                        [2024-05-10 16:13:28.048] [LOG] Module helper loaded: MMM-ImagesPhotos
                        [2024-05-10 16:13:28.196] [LOG] Initializing new module helper …
                        [2024-05-10 16:13:28.197] [LOG] Module helper loaded: MMM-OpenWeatherMapForecast
                        [2024-05-10 16:13:28.198] [LOG] No helper found for module: MMM-FlipClock.
                        [2024-05-10 16:13:29.120] [LOG] Initializing new module helper …
                        [2024-05-10 16:13:29.121] [LOG] Module helper loaded: MMM-SunnyPortal
                        [2024-05-10 16:13:29.848] [LOG] Initializing new module helper …
                        [2024-05-10 16:13:29.849] [LOG] Module helper loaded: MMM-MQTT
                        [2024-05-10 16:13:29.850] [LOG] All module helpers loaded.
                        [2024-05-10 16:13:29.875] [LOG] Starting server on port 8080 …
                        [2024-05-10 16:13:32.692] [LOG] Server started …
                        [2024-05-10 16:13:32.695] [LOG] Connecting socket for: updatenotification
                        [2024-05-10 16:13:32.698] [LOG] Starting module helper: updatenotification
                        [2024-05-10 16:13:32.699] [LOG] Connecting socket for: MMM-ImagesPhotos
                        [2024-05-10 16:13:32.701] [LOG] Starting node helper for: MMM-ImagesPhotos
                        [2024-05-10 16:13:32.703] [LOG] Connecting socket for: MMM-OpenWeatherMapForecast
                        [2024-05-10 16:13:32.706] [LOG] ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
                        [2024-05-10 16:13:32.710] [LOG] Connecting socket for: MMM-SunnyPortal
                        [2024-05-10 16:13:32.712] [LOG] Starting node helper for: MMM-SunnyPortal
                        [2024-05-10 16:13:32.714] [LOG] Connecting socket for: MMM-MQTT
                        [2024-05-10 16:13:32.717] [LOG] MMM-MQTT: Starting node helper
                        [2024-05-10 16:13:32.718] [LOG] Sockets connected & modules started …
                        [2024-05-10 16:13:33.281] [LOG] Launching application.
                        [2024-05-10 16:13:39.304] [INFO] System information:
                        SYSTEM: manufacturer: ; model: ; raspberry: undefined; virtual: false
                        OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.28+rpt-rpi-v8
                        VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 20.13.0; npm: 10.5.2; pm2: 5.3.1
                        OTHER: timeZone: Africa/Johannesburg; ELECTRON_ENABLE_GPU: undefined
                        [2024-05-10 16:13:40.158] [LOG] Config based debug=module_2_MMM-ImagesPhotos
                        [2024-05-10 16:13:40.166] [LOG] SocketNotification START_SUNNYPORTAL received for the first time…setting updateInterval to 900000ms
                        [2024-05-10 16:13:40.170] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing day data
                        [2024-05-10 16:13:40.329] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing month data
                        [2024-05-10 16:13:40.346] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing year data
                        [2024-05-10 16:13:40.360] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing total data
                        [2024-05-10 16:13:40.472] [INFO] updatenotification: Updater Class Loaded!
                        [2024-05-10 16:13:40.473] [INFO] updatenotification: Checking PM2 using…
                        [2024-05-10 16:13:40.478] [INFO] Checking git for module: MMM-ImagesPhotos
                        [2024-05-10 16:13:40.721] [INFO] updatenotification: [PM2] You are not using pm2
                        [2024-05-10 16:13:40.818] [INFO] Checking git for module: MMM-OpenWeatherMapForecast
                        [2024-05-10 16:13:40.881] [INFO] Checking git for module: MMM-FlipClock
                        [2024-05-10 16:13:40.950] [INFO] Checking git for module: MMM-SunnyPortal
                        [2024-05-10 16:13:41.071] [INFO] Checking git for module: MMM-MQTT
                        [2024-05-10 16:13:41.213] [INFO] Checking git for module: MagicMirror
                        [2024-05-10 16:13:41.406] [LOG] [MMM-OpenWeatherMapForecast] 10-May-24 16:13 ** ERROR ** null
                        [2024-05-10 16:13:41.643] [LOG] [_login] Cookie Value: BIGipServerPool_P_SunnyPortal=3053758656.20480.0000
                        [2024-05-10 16:13:41.647] [ERROR] Whoops! There was an uncaught exception…
                        [2024-05-10 16:13:41.656] [ERROR] TypeError: Cannot read properties of null (reading ‘1’)
                        at Request._callback (/home/frits/MagicMirror/modules/MMM-SunnyPortal/node_helper.js:86:103)
                        at self.callback (/home/frits/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:185:22)
                        at Request.emit (node:events:514:28)
                        at Request. (/home/frits/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:1154:10)
                        at IncomingMessage. (/home/frits/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:1076:12)
                        at Object.onceWrapper (node:events:628:28)
                        at IncomingMessage.emit (node:events:526:35)
                        at endReadableNT (node:internal/streams/readable:1408:12)
                        at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
                        [2024-05-10 16:13:41.657] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        [2024-05-10 16:13:41.659] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                        [2024-05-10 16:13:41.676] [LOG] [_login] Cookie Value: BIGipServerPool_P_SunnyPortal=3120867520.20480.0000
                        [2024-05-10 16:13:41.678] [ERROR] Whoops! There was an uncaught exception…
                        [2024-05-10 16:13:41.680] [ERROR] TypeError: Cannot read properties of null (reading ‘1’)
                        [2024-05-10 16:13:41.681] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        [2024-05-10 16:13:41.682] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                        [2024-05-10 16:13:41.696] [LOG] [_login] Cookie Value: BIGipServerPool_P_SunnyPortal=3120867520.20480.0000
                        [2024-05-10 16:13:41.698] [ERROR] Whoops! There was an uncaught exception…
                        [2024-05-10 16:13:41.700] [ERROR] TypeError: Cannot read properties of null (reading ‘1’)
                        [2024-05-10 16:13:41.701] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        [2024-05-10 16:13:41.702] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                        [2024-05-10 16:13:41.718] [LOG] [_login] Cookie Value: BIGipServerPool_P_SunnyPortal=3053758656.20480.0000
                        [2024-05-10 16:13:41.722] [ERROR] Whoops! There was an uncaught exception…
                        [2024-05-10 16:13:41.723] [ERROR] TypeError: Cannot read properties of null (reading ‘1’)
                        [2024-05-10 16:13:41.724] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        [2024-05-10 16:13:41.724] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                        [2024-05-10 16:13:42.376] [LOG] MMM-MQTT: Starting client for 192.168.1.23:1883 user erasmi
                        [2024-05-10 16:13:42.377] [LOG] MMM-MQTT: Connecting to mqtt://192.168.1.23:1883
                        [2024-05-10 16:13:42.598] [LOG] MMM-MQTT connected to mqtt://192.168.1.23:1883
                        [2024-05-10 16:13:42.600] [LOG] MMM-MQTT: subscribing to sbfspot/2130438237 Topic.PDC1
                          @frits-erasmus yep. either didn’t get data or api changed
                          • F
                            Sam,
                            I think it is because I have two plants registered and manually logging onto the site incurs another step where one has to select the correct plant. That step is not a usual step when you only have one plant registered. That, I think causes MMM-SunnyPoprtal to fail.
                            I also have two SunnyBow inverters that might contribute to this complexity.
                            I will then go the MQTT route until the SunnyPortal is resolved. I also left a message for the developer in Github.
                            I have an MQTT server running on my LAN and I have feeds of everything I would like to monitor, so that could potentially be the better route to take
                            To play save I am going to start fresh with an SSD /NVME - M.2 for stability
                            In your message starting with " no. how do you start MagicMirror?" I learned quite a lot.
                            Is that way of starting supposed to give no RED messages when I connect via SSH?
                            I saw several lines withRED text.
                            I suppose there should be no RED text when there are no errors?
                            I will also do a little more reading now that I have a basic understanding of how MM2 works
                            See you in my next post (Sorry for being such a nuisance)
                              @frits-erasmus yes the red is a fatal error on the module.
                              request is a li rare to get data (request it). many developers did not properly handle errors.
                              in this case it looks like the data is supposed to contain an array xxx[1] and that is not the case. oops…
                              I don’t know if it because of error, or api change , or multiple sources.
                              how MagicMirror works
                              the modulename.js runs in the browser (electron is a browser), but as such it cannot directly access the system it runs on for security (can’t read files, fiddle w hardware , reformat your disks…)
                              so the module has a helper, that runs o the server side which CAN do all that.
                              so the modulename.js sends a request to the helper to get data. the helper does it, and sends back. … the modilenane.js is waiting (loading… on the screen)
                              but if there is an error most helpers do not send back. so both sides are waiting…
                              helper gor another request modulename.js a response to last request…
                              stalemate…
                              • F
                                frits.erasmus
                                Thanks Sam for that info.
                                Although I do not understand it 100% it gives me an idea why there is an issue with that module.
                                I started from scratch and this time took it slow.
                                Used your script on your github page made the install so much cleaner.
                                THANKS for your effort there!!
