    MMM-MealieMenu Fetch Error
    30 Posts 3 Posters 7.3k Views 3 Watching
    • zanixZ Offline
      zanix
      @sdetweil said in MMM-MealieMenu Fetch Error:
      @WallysWellies I am a mealie user too.
      code looks good. will have to setup and test.
      it does get the data frequently
      60 seconds by default…
      I should probably set the default to something higher. I had it set to 60 seconds while I was developing it.
      @WallysWellies ok… I’ll watch it running here at 15 min updates…
      well, I found it…
      in the node helper he sets a flag, to say request is active
      if the flag is set when the request comes from the module side
      he just returns… does nothing.
      on error he does not clear the flag
      (bad network, host, authorization… places where there is no recovery
      those make sense…)
            .catch((error) => {   //<--- had and error here ...
              this.sendSocketNotification("MEALIE_ERROR", {
                error: "FETCH_ERROR",
                details: error,
                identifier: config.identifier
            .finally(() => {
              this.outstandingRequest = false;   // < --- only clears flag on success
      one could examine the error and reset if its a potentially recoverable error…
      I thought finally() runs even after a catch(), dangit.
      @WallysWellies said in MMM-MealieMenu Fetch Error:
      @sdetweil I’m looking at the node_helper.js file and reading your comments and I’m a little unsure what you are suggesting.
      Are you saying I could edit this code block:
      .catch((error) => {
                details: error,
      to this:
      .catch((error) => {
                details: error,
      Sorry, I can fumble my way around code but I’m far from a programmer!
      I will get this fix added and set the default updateInterval to something a bit more sane soon. Thanks to all for troubleshooting!
      • W Offline
        WallysWellies @zanix
        @zanix Thanks for your input :)
        I made the change after posting and it certainly doesn’t break anything but I have been playing with some other modules too so have restarted the software several times meaning I haven’t given it a chance to error but based on my understanding it probably shouldn’t anymore. I don’t know why it was in the first place though - the Mealie container is on the Pi so it’s using localhost to retrieve data. Who knows.
        I did make one other change because I wanted to see the next week of meals, rather than the remaining meals this week. So I changed this line:
        const startOfWeek = this.getFirstDayOfWeek(config.weekStartsOnMonday);
        to this:
        const startOfWeek = moment();
        It’s pretty crude but if you’re taking suggestions it might be nice to have the option to show x number of days in the future rather than until the end of the week. I don’t believe that’s currently possible natively?
        Thanks for the module though, it’s great!
        zanixZ 1 Reply Last reply Reply Quote 0
        • zanixZ Offline
          zanix @WallysWellies
          Hopefully that fixes the issue, let me know otherwise.
          to this:
          Before now no, but I did just add the fetch fix, updateInterval default to 1 hour, and some additional meal entry options in version 1.5.0.
          The options are:
          • currentWeek: Only show meals for the current week.
          • dayLimit: How many days will be displayed after today.
          • entryLimit: How many entries from future days should be shown in total.
          Now you can just set currentWeek to false to get the same effect.
          I appreciate that, glad it’s useful!
          • W Offline
            WallysWellies
            @zanix The mealie module has been in an error since yesterday and I wonder if you might be able to help me troubleshoot?
            I have run the following command:
            tail -100 .pm2/logs/mm-error.log
            And at the end I see the following:
            [2024-05-31 16:47:51.577] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-05-31 17:47:51.580] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-05-31 18:47:51.581] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-05-31 19:47:51.590] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-05-31 20:47:51.571] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-05-31 21:47:51.575] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-05-31 22:47:51.582] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-05-31 23:47:51.574] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-06-01 00:47:51.604] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-06-01 01:47:51.601] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-06-01 02:47:51.576] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-06-01 03:47:51.576] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-06-01 04:47:51.577] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-06-01 05:47:51.575] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-06-01 06:47:51.580] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-06-01 07:47:51.571] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-06-01 08:47:51.577] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-06-01 09:47:51.572] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-06-01 10:47:51.577] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-06-01 11:47:51.576] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-06-01 12:47:51.568] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            [2024-06-01 13:47:51.580] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
            I have confirmed that the correct username / password is in my config.js file (and it has worked previously) - I can login via my laptop using http://raspberrypi:9925/ using these credentials.
            The config.js file is using the following line for the connection:
            host: "http://localhost:9925"
            I use browser / terminal / SSH etc. to access the Pi but if necessary I can connect a keyboard / mouse if that would aid in narrowing down the issue.
            Do you have any thoughts? I can probably just restart the mirror service but I haven’t yet in case that deletes any valuable information. Any advice would be appreciated.
            • W Offline
              WallysWellies
              • I have found the part of Mealie that allows creation of an API key so I could switch to that method for authentication.
              • I also see I am a couple of versions behind the Mealie master branch (I use version 1.5.1 - current version is 1.7.0). That looks drastic but it’s only 2 releases behind.
              I don’t think either of these things are causing my issue necessarily but it’s a couple of things I can change soon.
                sdetweil @WallysWellies
                @WallysWellies are you using watchtower to keep. your containers up to date?
                • W Offline
                  WallysWellies @sdetweil
                  @sdetweil Mealie is the first time I’ve used docker so it’s totally manual. I’ve never tried to update it - it was setup within the last couple of months.
                  I was planning to do the update based on the Mealie docs but I could look into watchtower.
                    @WallysWellies i have watchtower maintain all my docker stacks
                    • W Offline
                      @sdetweil I’ll look into it, thanks.
                      • zanixZ Offline
                        zanix
                        I normally use an API key but I just tried my username/password and it worked. I’m on Mealie 1.7.0.
                        Go ahead and restart MM and see if that works.
                        Are you on the latest MMM-MealieMenu (1.5.0)? I added an additional log when the auth token fetch fails.
                        • 2 / 3
