    MMM-CalendarExt3Agenda only showing a few days of items
    6 Posts 3 Posters 1.0k Views 3 Watching
    • C
      Como
      Hoping someone might be able to help. Similar to this post, I only have a few days worth of items showing with this module. Previous to today the module had worked great with a 7 day agenda, but is currently only showing 3 days out. I do have the module not ready message so I tried increasing the fetch wait time as suggested, but that did not fix the issue. We did have recent bad weather and power outages, but everything seemed fine when I initially rebooted after regaining power. Hoping someone may have a suggestion.
      M S 2 Replies Last reply Reply Quote 0
      • C
        Como @MMRIZE
        @MMRIZE Thanks, I’ll send along the config. I did find a copy of the MMM-CalendarExt3Agenda config file from a backup and switching out the config file got the module back up and working.
        • M
          MMRIZE @Como
          @Como
          Can you share me your ics file/url and your config with me(eouia0819@gmail.com)
          • C
            Como @MMRIZE
              schwarem @Como
              @Como What was the resolution to this? I too have used this module for a while and it worked great. I about a week ago, I noticed it was only showing events through the end of May and not anything in June. Now that it is June 1, it shows events for the next 7 days again. Did you have it cutoff displaying events at the end of the month?
              • M
                MMRIZE
                @Como @schwarem
                There was a bug from the previous update. It has some logic issues about out-of-current-month ranging. I fixed it in 1.4.5. Plz, Update module and try it again. Sorry for bothering you guys.
                • C
                  Como @MMRIZE
                  @MMRIZE Thanks for your work on this MMRIZE!
                  @schwarem , my temp solution was to use an older copy of the MMM-CalendarExt3Agenda config file I happened to have backed up.
                  For the sake of completeness (and those who may have to troubleshoot in the future) I just saw the notification of an update for the module today and installed it. Unfortunately, the module would not display at all. Luckily, I had also saved the module config file from when I initially had issues with the module updating (i.e. from a week ago when I first noticed issues). I replaced the very old module config file with this more recent config file and everything is working great!
