    MMM-Navigate cannot be installed
    26 Posts 2 Posters 4.5k Views 2 Watching
    • K Offline
      Klaleu
      Hello Sam,
      Thank you for continuing to try to solve the problem.
      I have carried out:
      cd ~/MagicMirror
      rm -rf node_modules
      npm run install-mm
      and after that:
      cd modules/MMM-Navigate
      ./postinstall
      without problems.
      Last I did:
      cd ~/MagicMirror
      npm start
      This is the result:
      klaus@raspberrypi:~ $ cd ~/MagicMirror
      klaus@raspberrypi:~/MagicMirror $ npm start
      magicmirror@2.27.0 start
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      [2024-06-17 11:35:52.232] [LOG] Starting MagicMirror: v2.27.0
      [2024-06-17 11:35:52.333] [LOG] Loading config …
      [2024-06-17 11:35:52.344] [LOG] config template file not exists, no envsubst
      [2024-06-17 11:35:52.354] [LOG] Loading module helpers …
      [2024-06-17 11:35:52.360] [LOG] No helper found for module: alert.
      [2024-06-17 11:35:53.076] [LOG] Initializing new module helper …
      [2024-06-17 11:35:53.078] [LOG] Module helper loaded: updatenotification
      [2024-06-17 11:35:53.080] [LOG] No helper found for module: MMM-pages.
      [2024-06-17 11:35:53.081] [LOG] No helper found for module: clock.
      [2024-06-17 11:35:53.466] [LOG] Initializing new module helper …
      [2024-06-17 11:35:53.472] [LOG] Module helper loaded: calendar
      [2024-06-17 11:35:54.236] [LOG] Initializing new module helper …
      [2024-06-17 11:35:54.241] [LOG] Module helper loaded: MMM-DWD-Pollen
      [2024-06-17 11:35:54.242] [LOG] No helper found for module: compliments.
      [2024-06-17 11:35:54.243] [LOG] No helper found for module: weather.
      [2024-06-17 11:35:54.275] [LOG] Initializing new module helper …
      [2024-06-17 11:35:54.275] [LOG] Module helper loaded: MMM-birthdays
      [2024-06-17 11:35:54.720] [LOG] Initializing new module helper …
      [2024-06-17 11:35:54.723] [LOG] Module helper loaded: MMM-Rest
      [2024-06-17 11:35:54.725] [LOG] No helper found for module: MMM-Globe.
      [2024-06-17 11:35:54.725] [LOG] No helper found for module: MMM-RAIN-MAP.
      [2024-06-17 11:35:54.893] [LOG] Initializing new module helper …
      [2024-06-17 11:35:54.893] [LOG] Module helper loaded: newsfeed
      [2024-06-17 11:35:54.893] [LOG] All module helpers loaded.
      [2024-06-17 11:35:54.909] [LOG] Starting server on port 8080 …
      [2024-06-17 11:35:57.767] [ERROR] Whoops! There was an uncaught exception…
      [2024-06-17 11:35:57.823] [ERROR] Error: listen EADDRINUSE: address already in use ::1:8080
      at Server.setupListenHandle [as _listen2] (node:net:1872:16)
      at listenInCluster (node:net:1920:12)
      at GetAddrInfoReqWrap.doListen [as callback] (node:net:2069:7)
      at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:109:8) {
      code: ‘EADDRINUSE’,
      errno: -98,
      syscall: ‘listen’,
      address: ‘::1’,
      port: 8080
      [2024-06-17 11:35:57.850] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2024-06-17 11:35:57.862] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
      [2024-06-17 11:36:07.657] [INFO] System information:
      SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.2; raspberry: [object Object]; virtual: false
      OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v8+
      VERSIONS: electron: 29.3.1; used node: 20.9.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.3.1
      OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
      The internet connection was stabile, it can’t be the reason for the problem.
      I hope you can interpret the result and have a suggestion on how to proceed.
      Greetings
      Klaus
        sdetweil @Klaleu
        @Klaleu sorry, I forgot to tell you to stop MagicMirror under pm2
        but as the postinstall ran
        do
        pm2 restart all
        • K Offline
          Klaleu
          Dear Sam,
          Thank you very much for your help.
          After I did the following:
          pm2 stop mm
          and
          pm2 restart all
          The new installation of MMM-Navigate ran without errors or problems.
          And after I added the code in the Modules array in the config/config.js, MMM-Navigate worked.
          Thank you again for your help and for the time you sacrificed.
          Klaus
            sdetweil @Klaleu
            @Klaleu fantastic!
            thanks for the feedback
            • K Offline
              Klaleu
              Dear Sam,
              That was my first contact in the MagicMirror Forum and thanks to your help it was a complete success.
              My problem is now solved. Who moves the point from unresolved to resolved?
              Greetings
              Klaus
                sdetweil @Klaleu
                @Klaleu you do. find the message which gives the best answer, click the 3 dots in the lower right and select the option
                Mark this post …
                • K Klaleu has marked this topic as solved on
