    Difficulty getting MMM-Transitfeed working
    31 Posts 2 Posters 3.8k Views 2 Watching
      sdetweil @UncleRoger
      @UncleRoger correct the module’s folder
      UncleRogerU 1 Reply Last reply Reply Quote 0
      • UncleRogerU Offline
        UncleRoger @sdetweil
        Still no luck. 8^(
        I was getting a bunch of errors during the MM install which some googling suggested might be due to insufficient power (which is odd because I was using a big power supply) so I switched to an RPi power supply and still got the same errors. So maybe they’re somehow related? The errors are:
        During MM Install:
        (node:27144) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
        During the Electron stuff:
        (node:42678) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
          @UncleRoger it’s an npm bug, nothing fatal
          did you see the rebuild messages?
            It said “Rebuild Complete” but nothing about sqlite3.
              @UncleRoger ok, let see if we can clean up and try again
              so we are going to reset the MM loaded libs and the module loaded libs
              cd ~/MagicMirror
              rm -rf node_modules
              git checkout package.json
              git checkout package-lock.json
              npm run install-mm
              when finished
              npm install @electron/rebuild
              now the module
              cd modules/MMM-Transitfeed
              rm -rf node_modules
              npm install
              when finished
              npm install btfs
              when finished
              ../../node_modules/.bin/electron-rebuild
                @sdetweil said in Difficulty getting MMM-Transitfeed working:
                ok, let see if wee can clean up and try again
                That worked! Yay!
                Thank you so very much! I really appreciate all your help. You are truly amazing.
                My next step is to figure out how to get to the same point with my actual dev system before making the same changes to the production system. That and how to get it to work with my local transit system’s feeds.
                  @UncleRoger said in Difficulty getting MMM-Transitfeed working:
                  well, you can follow the steps from
                  onward
                  or you can follow all those steps… won’t hurt anything
                    that I have no clue on…
                    is this closeable?
                      is this closeable?
                      Definitely. Thanks again!
                        @UncleRoger ok, another learning thing…
                        find the message that best articulates the solution, click the 3 dots to the lower right and select “Mark this post as the correct answer”
                        you open it, you close it…
                        • 3 / 4
