    Difficulty getting MMM-Transitfeed working
    31 Posts 2 Posters 7.3k Views 2 Watching
    • UncleRogerU Offline
      UncleRoger @sdetweil
      There is no joy in mudville.
      Here’s what I did with a fresh install of PiOS (Raspberry Pi 4 2gb):
      pi@MagicMirrorDev:~/MagicMirror $ history
          1  {   sudo apt update;   sudo apt full-upgrade; }
          2  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
          3  sudo nmtui
          4  sudo shutdown -r now
          5  sudo nmtui
          6  sudu shutdown -r now
          7  sudo shutdown -r now
          8  {   cd ~/MagicMirror/modules;   git clone https://github.com/bnitkin/MMM-transitfeed.git; }
          9  cd ..
         10  {   cd ~/MagicMirror                     # Enter magicmirror project directory
                 npm uninstall gtfs-realtime-bindings # Now part of gtfs
                 npm install gtfs --save-dev          # Force update to latest version
         11  {   cd ~/MagicMirror                     # Enter magicmirror project directory
         12  {   sudo npm install -g n;   sudo n lts;   sudo n latest;   sudo n prune; }
         13  {   cd ~/MagicMirror                     # Enter magicmirror project directory
         14  cd $HOME/MagicMirror;
         15  DISPLAY=:0 npm start
         16  npm run config:check
         17  DISPLAY=:0 npm start
         18  npm run config:check
         19  DISPLAY=:0 npm start
         20  npm run config:check
         21  DISPLAY=:0 npm start
         22  {   cd ~/MagicMirror;   rm -r node_modules/better-sqlite3/;   npm install better-sqlite3 --build-from-source --runtime=electron --target=26.4.3 --dist-url=https://electronjs.org/headers --force; }
         23  {   cd ~/MagicMirror;   npm install @electron/rebuild; }
         24  {   cd ~/MagicMirror/modules/MMM-transitfeed;   ../../node_modules/.bin/electron-rebuild;   cd ~/MagicMirror; }
         25  DISPLAY=:0 npm start
         26  history
      The nmtui stuff is to set the IP address (which I did wrong a couple of times) and then I mucked up the config.js putting in the transitfeed module stuff.
      Here’s the log from trying to run it at the end (it’s basically the same):
      [2024-06-25 11:53:08.617] [LOG]   MMM-transitfeed: Importing with [object Object]
      [2024-06-25 11:53:08.649] [ERROR] (node:3464) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/node_modules/better-sqlite3/build/Release/better_sqlite3.node'
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 116. This version of Node.js requires
      NODE_MODULE_VERSION 121. Please try re-compiling or re-installing
      the module (for instance, using `npm rebuild` or `npm install`).
          at process.func [as dlopen] (node:electron/js2c/node_init:2:2214)
          at Module._extensions..node (node:internal/modules/cjs/loader:1343:18)
          at Object.func [as .node] (node:electron/js2c/node_init:2:2214)
          at Module.load (node:internal/modules/cjs/loader:1098:32)
          at Module._load (node:internal/modules/cjs/loader:945:12)
          at c._load (node:electron/js2c/node_init:2:13672)
          at Module.require (node:internal/modules/cjs/loader:1122:19)
          at require (node:internal/modules/helpers:130:18)
          at bindings (/home/pi/MagicMirror/node_modules/bindings/bindings.js:112:48)
          at new Database (/home/pi/MagicMirror/node_modules/better-sqlite3/lib/database.js:48:64)
          at setupDb (file:///home/pi/MagicMirror/node_modules/gtfs/lib/db.js:10:14)
          at openDb (file:///home/pi/MagicMirror/node_modules/gtfs/lib/db.js:31:12)
          at Module.importGtfs (file:///home/pi/MagicMirror/node_modules/gtfs/lib/import.js:676:16)
          at Class.startup (/home/pi/MagicMirror/modules/MMM-transitfeed/node_helper.js:48:29)
          at async Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-transitfeed/node_helper.js:33:52)
      (Use `electron --trace-warnings ...` to show where the warning was created)
      [2024-06-25 11:53:08.650] [ERROR] (node:3464) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 8)
      I’m thinking I might give it another go from scratch without worrying about the IP address and catching all the output from each command.
        Could you check that I’m doing things correctly? These are the commands I’m using to get from a fresh OS to MM with transitfeed:
        # Update system
          sudo apt update
        # Install MagicMirror
        # NOTICE ON INSTALL: npm install -g npm@10.8.1
        # update Node/NPM
          sudo n lts
          sudo n latest
          sudo n prune
        # Install transitfeed
        # Install gtfs
        # Update better-sqlite3
        # Rebuild Electron?
        Thanks so much for your help!
          sdetweil @UncleRoger
          @UncleRoger ok, simpler
          flash sd card with
          use my script to install MM (do nothing before, it does the update and adds whats needed for MM)
          npm start to prove MagicMirror is working
          clone the module
          cd to the module folder and do the npm install and npm install gtfs (in module folder NOT MM folder!!)
          now, need electron rebuild
          cd …/… # magicmirror folder
          cd - # go back to module folder
          …/…/node_modules/.bin/electron-rebuild
          wait, should show sqlite
          rebuild complete
          cd - # back to MM folder
          add the config entry for the module
          npm start
          should work
          UncleRogerU 1 Reply Last reply Reply Quote 0
            When you say “module folder”, you mean (in this case) ~/MagicMirror/modules/MMM-transitfeed not ~/MagicMirror/modules/ right? I’m pretty sure, but better safe than sorry.
            Thanks!
              @UncleRoger correct the module’s folder
                Still no luck. 8^(
                I was getting a bunch of errors during the MM install which some googling suggested might be due to insufficient power (which is odd because I was using a big power supply) so I switched to an RPi power supply and still got the same errors. So maybe they’re somehow related? The errors are:
                During MM Install:
                (node:27144) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
                During the Electron stuff:
                (node:42678) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
                  @UncleRoger it’s an npm bug, nothing fatal
                  did you see the rebuild messages?
                    It said “Rebuild Complete” but nothing about sqlite3.
                      @UncleRoger ok, let see if we can clean up and try again
                      so we are going to reset the MM loaded libs and the module loaded libs
                      rm -rf node_modules
                      git checkout package.json
                      git checkout package-lock.json
                      npm run install-mm
                      when finished
                      now the module
                      cd modules/MMM-Transitfeed
                      rm -rf node_modules
                      npm install
                      when finished
                      npm install btfs
                      when finished
                        @sdetweil said in Difficulty getting MMM-Transitfeed working:
                        ok, let see if wee can clean up and try again
                        That worked! Yay!
                        Thank you so very much! I really appreciate all your help. You are truly amazing.
                        My next step is to figure out how to get to the same point with my actual dev system before making the same changes to the production system. That and how to get it to work with my local transit system’s feeds.
                          @UncleRoger said in Difficulty getting MMM-Transitfeed working:
                          well, you can follow the steps from
                          onward
                          or you can follow all those steps… won’t hurt anything
                            that I have no clue on…
                            is this closeable?
                              is this closeable?
                              Definitely. Thanks again!
                                @UncleRoger ok, another learning thing…
                                find the message that best articulates the solution, click the 3 dots to the lower right and select “Mark this post as the correct answer”
                                you open it, you close it…
                                  How to get MMM-transitfeed working on a new installation of MagicMirror (based on @sdetweil’s assistance)
                                  These are the steps I went through to get the module working after encountering version mismatch errors:
                                  Note that I was starting with a clean install of Raspberry PiOS. I made no changes prior to the steps outlined below:
                                  First, I installed MagicMirror using Sam Detweil’s script:
                                  Next, I installed the transitfeed module:
                                  Then this reset the libraries:
                                    rm -rf node_modules
                                    npm run install-mm
                                  I installed the electron rebuild package:
                                  Next, I reset the module info:
                                    rm -rf node_modules
                                    npm install
                                  At this point, I installed gtfs:
                                    npm install gtfs
                                  And lastly, I rebuilt sqlite3:
                                  Here I added the default config from the module’s github page to my config.js and started the mirror. It worked!
                                  Many thanks to Sam for his patience, knowledge, and caring assistance.
                                  • UncleRogerU UncleRoger has marked this topic as solved on
