    Difficulty getting MMM-Transitfeed working
    31 Posts 2 Posters 7.3k Views 2 Watching
    • UncleRogerU Offline
      UncleRoger @sdetweil
      The MMM-transitfeed module directory:
        npm install @electron/rebuild
        cd ~/MagicMirror/modules/MMM-transitfeed
        ../../node_modules/.bin/electron-rebuild
      I basically copy-and-pasted that.
        sdetweil @UncleRoger
        @UncleRoger and when the electron-rebuild ran it should have said
        something about sqllite
        and rebuild complete, like mine above
        UncleRogerU 1 Reply Last reply Reply Quote 0
          Nothing about sqlite but it did say “Rebuild Complete”:
          pi@MagicMirrorDev:~/MagicMirror $ {
          added 81 packages in 11s
          253 packages are looking for funding
            run `npm fund` for details
          ✔ Rebuild Complete
          This time around, I didn’t do the sqlite update:
            rm -r node_modules/better-sqlite3/
            npm install better-sqlite3 --build-from-source --runtime=electron --target=26.4.3 --dist-url=https://electronjs.org/headers --force
          But I don’t think it worked any better when I did. I’ll try that and then do the rebuild.
            @UncleRoger don’t install sql again, else you have to rebuild again
              Oops. I did the rebuild again. Still doesn’t say anything about the sqlite3 but it does say rebuild complete.
                @UncleRoger and? does it run.
                  Sadly, no. Same error.
                    UncleRoger @UncleRoger
                    Could it be hardware related? I’m not sure I have another Pi4 I can test with but I’ve got a Pi Zero 2 I could try. Would that be of any use?
                      @UncleRoger its not hardware, but another try wouldn’t hurt
                      UncleRogerU 2 Replies Last reply Reply Quote 0
                        There is no joy in mudville.
                        Here’s what I did with a fresh install of PiOS (Raspberry Pi 4 2gb):
                        pi@MagicMirrorDev:~/MagicMirror $ history
                            1  {   sudo apt update;   sudo apt full-upgrade; }
                            2  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                            3  sudo nmtui
                            4  sudo shutdown -r now
                            5  sudo nmtui
                            6  sudu shutdown -r now
                            7  sudo shutdown -r now
                            8  {   cd ~/MagicMirror/modules;   git clone https://github.com/bnitkin/MMM-transitfeed.git; }
                            9  cd ..
                           10  {   cd ~/MagicMirror                     # Enter magicmirror project directory
                                   npm uninstall gtfs-realtime-bindings # Now part of gtfs
                                   npm install gtfs --save-dev          # Force update to latest version
                           11  {   cd ~/MagicMirror                     # Enter magicmirror project directory
                           12  {   sudo npm install -g n;   sudo n lts;   sudo n latest;   sudo n prune; }
                           13  {   cd ~/MagicMirror                     # Enter magicmirror project directory
                           14  cd $HOME/MagicMirror;
                           15  DISPLAY=:0 npm start
                           16  npm run config:check
                           17  DISPLAY=:0 npm start
                           18  npm run config:check
                           19  DISPLAY=:0 npm start
                           20  npm run config:check
                           21  DISPLAY=:0 npm start
                           22  {   cd ~/MagicMirror;   rm -r node_modules/better-sqlite3/;   npm install better-sqlite3 --build-from-source --runtime=electron --target=26.4.3 --dist-url=https://electronjs.org/headers --force; }
                           23  {   cd ~/MagicMirror;   npm install @electron/rebuild; }
                           24  {   cd ~/MagicMirror/modules/MMM-transitfeed;   ../../node_modules/.bin/electron-rebuild;   cd ~/MagicMirror; }
                           25  DISPLAY=:0 npm start
                           26  history
                        The nmtui stuff is to set the IP address (which I did wrong a couple of times) and then I mucked up the config.js putting in the transitfeed module stuff.
                        Here’s the log from trying to run it at the end (it’s basically the same):
                        [2024-06-25 11:53:08.617] [LOG]   MMM-transitfeed: Importing with [object Object]
                        [2024-06-25 11:53:08.649] [ERROR] (node:3464) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/node_modules/better-sqlite3/build/Release/better_sqlite3.node'
                        was compiled against a different Node.js version using
                        NODE_MODULE_VERSION 116. This version of Node.js requires
                        NODE_MODULE_VERSION 121. Please try re-compiling or re-installing
                        the module (for instance, using `npm rebuild` or `npm install`).
                            at process.func [as dlopen] (node:electron/js2c/node_init:2:2214)
                            at Module._extensions..node (node:internal/modules/cjs/loader:1343:18)
                            at Object.func [as .node] (node:electron/js2c/node_init:2:2214)
                            at Module.load (node:internal/modules/cjs/loader:1098:32)
                            at Module._load (node:internal/modules/cjs/loader:945:12)
                            at c._load (node:electron/js2c/node_init:2:13672)
                            at Module.require (node:internal/modules/cjs/loader:1122:19)
                            at require (node:internal/modules/helpers:130:18)
                            at bindings (/home/pi/MagicMirror/node_modules/bindings/bindings.js:112:48)
                            at new Database (/home/pi/MagicMirror/node_modules/better-sqlite3/lib/database.js:48:64)
                            at setupDb (file:///home/pi/MagicMirror/node_modules/gtfs/lib/db.js:10:14)
                            at openDb (file:///home/pi/MagicMirror/node_modules/gtfs/lib/db.js:31:12)
                            at Module.importGtfs (file:///home/pi/MagicMirror/node_modules/gtfs/lib/import.js:676:16)
                            at Class.startup (/home/pi/MagicMirror/modules/MMM-transitfeed/node_helper.js:48:29)
                            at async Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-transitfeed/node_helper.js:33:52)
                        (Use `electron --trace-warnings ...` to show where the warning was created)
                        [2024-06-25 11:53:08.650] [ERROR] (node:3464) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 8)
                        I’m thinking I might give it another go from scratch without worrying about the IP address and catching all the output from each command.
                          Could you check that I’m doing things correctly? These are the commands I’m using to get from a fresh OS to MM with transitfeed:
                          # Update system
                            sudo apt update
                          # Install MagicMirror
                          # NOTICE ON INSTALL: npm install -g npm@10.8.1
                          # update Node/NPM
                            sudo n lts
                            sudo n latest
                            sudo n prune
                          # Install transitfeed
                          # Install gtfs
                          # Update better-sqlite3
                          # Rebuild Electron?
                          Thanks so much for your help!
                            @UncleRoger ok, simpler
                            flash sd card with
                            use my script to install MM (do nothing before, it does the update and adds whats needed for MM)
                            npm start to prove MagicMirror is working
                            clone the module
                            cd to the module folder and do the npm install and npm install gtfs (in module folder NOT MM folder!!)
                            now, need electron rebuild
                            cd …/… # magicmirror folder
                            cd - # go back to module folder
                            …/…/node_modules/.bin/electron-rebuild
                            wait, should show sqlite
                            rebuild complete
                            cd - # back to MM folder
                            add the config entry for the module
                            npm start
                            should work
                              When you say “module folder”, you mean (in this case) ~/MagicMirror/modules/MMM-transitfeed not ~/MagicMirror/modules/ right? I’m pretty sure, but better safe than sorry.
                              Thanks!
                                @UncleRoger correct the module’s folder
                                  Still no luck. 8^(
                                  I was getting a bunch of errors during the MM install which some googling suggested might be due to insufficient power (which is odd because I was using a big power supply) so I switched to an RPi power supply and still got the same errors. So maybe they’re somehow related? The errors are:
                                  During MM Install:
                                  (node:27144) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
                                  During the Electron stuff:
                                  (node:42678) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
                                    @UncleRoger it’s an npm bug, nothing fatal
                                    did you see the rebuild messages?
                                      It said “Rebuild Complete” but nothing about sqlite3.
                                        @UncleRoger ok, let see if we can clean up and try again
                                        so we are going to reset the MM loaded libs and the module loaded libs
                                        rm -rf node_modules
                                        git checkout package.json
                                        git checkout package-lock.json
                                        npm run install-mm
                                        when finished
                                        now the module
                                        cd modules/MMM-Transitfeed
                                        rm -rf node_modules
                                        npm install
                                        when finished
                                        npm install btfs
                                        when finished
                                          @sdetweil said in Difficulty getting MMM-Transitfeed working:
                                          ok, let see if wee can clean up and try again
                                          That worked! Yay!
                                          Thank you so very much! I really appreciate all your help. You are truly amazing.
                                          My next step is to figure out how to get to the same point with my actual dev system before making the same changes to the production system. That and how to get it to work with my local transit system’s feeds.
                                            @UncleRoger said in Difficulty getting MMM-Transitfeed working:
                                            well, you can follow the steps from
                                            onward
                                            or you can follow all those steps… won’t hurt anything
