    Difficulty getting MMM-Transitfeed working
    31 Posts 2 Posters 4.2k Views 2 Watching
      sdetweil @UncleRoger
      @UncleRoger hm… I installed, did the npm install gtfs
      ran, failed as version mismatch
      I then did the
      ../../node_modules/.bin/electron-rebuild
      ✔ Rebuild Complete
      restart mm and no problems, using the default config
      UncleRogerU 1 Reply Last reply Reply Quote 0
      • UncleRogerU Offline
        UncleRoger @sdetweil
        I appreciate the help, as always… I wiped the system again, reinstalled the OS and MM, did the rebuild. Still the same error except the version numbers are different:
        [2024-06-21 15:30:32.001] [ERROR] (node:53456) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/node_modules/better-sqlite3/build/Release/better_sqlite3.node'
        was compiled against a different Node.js version using
        NODE_MODULE_VERSION 127. This version of Node.js requires
        NODE_MODULE_VERSION 121. Please try re-compiling or re-installing
        the module (for instance, using `npm rebuild` or `npm install`).
        I should mention that this is on a Pi4 (probably 2gb) with no other modules installed.
        Maybe it’s just not meant to be.
          @UncleRoger what folder are you in when you do the electron-rebuild?
            The MMM-transitfeed module directory:
              npm install @electron/rebuild
              cd ~/MagicMirror/modules/MMM-transitfeed
            I basically copy-and-pasted that.
              @UncleRoger and when the electron-rebuild ran it should have said
              something about sqllite
              and rebuild complete, like mine above
                Nothing about sqlite but it did say “Rebuild Complete”:
                pi@MagicMirrorDev:~/MagicMirror $ {
                added 81 packages in 11s
                253 packages are looking for funding
                  run `npm fund` for details
                ✔ Rebuild Complete
                This time around, I didn’t do the sqlite update:
                  rm -r node_modules/better-sqlite3/
                  npm install better-sqlite3 --build-from-source --runtime=electron --target=26.4.3 --dist-url=https://electronjs.org/headers --force
                But I don’t think it worked any better when I did. I’ll try that and then do the rebuild.
                  @UncleRoger don’t install sql again, else you have to rebuild again
                    Oops. I did the rebuild again. Still doesn’t say anything about the sqlite3 but it does say rebuild complete.
                      @UncleRoger and? does it run.
                        Sadly, no. Same error.
                        • 1 / 4
