    Difficulty getting MMM-Transitfeed working
    31 Posts 2 Posters 2.9k Views 2 Watching
      sdetweil @UncleRoger
      @UncleRoger run npm rebuild in the module folder
      this module has a binary that has to match the electron version.
      the distributed version does not.
        @UncleRoger or
        better
        npm install @electron/rebuild
        cd modules/MMM-Transitfeed
        …/…/node_modules/.bin/electron-rebuild
        and restart MagicMirror however  you do that
        UncleRogerU 1 Reply Last reply Reply Quote 0
        • UncleRogerU Offline
          UncleRoger @sdetweil
          I gave that a bash and am still getting the same error. I even wiped the system and started from scratch just in case I’d done something to make things worse.
            @UncleRoger hm… I installed, did the npm install gtfs
            ran, failed as version mismatch
            I then did the
            ../../node_modules/.bin/electron-rebuild
            ✔ Rebuild Complete
            restart mm and no problems, using the default config
              I appreciate the help, as always… I wiped the system again, reinstalled the OS and MM, did the rebuild. Still the same error except the version numbers are different:
              [2024-06-21 15:30:32.001] [ERROR] (node:53456) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/node_modules/better-sqlite3/build/Release/better_sqlite3.node'
              was compiled against a different Node.js version using
              NODE_MODULE_VERSION 127. This version of Node.js requires
              NODE_MODULE_VERSION 121. Please try re-compiling or re-installing
              the module (for instance, using `npm rebuild` or `npm install`).
              I should mention that this is on a Pi4 (probably 2gb) with no other modules installed.
              Maybe it’s just not meant to be.
                @UncleRoger what folder are you in when you do the electron-rebuild?
                  The MMM-transitfeed module directory:
                    cd ~/MagicMirror/modules/MMM-transitfeed
                  I basically copy-and-pasted that.
                    @UncleRoger and when the electron-rebuild ran it should have said
                    something about sqllite
                    and rebuild complete, like mine above
                      Nothing about sqlite but it did say “Rebuild Complete”:
                      pi@MagicMirrorDev:~/MagicMirror $ {
                      added 81 packages in 11s
                      253 packages are looking for funding
                        run `npm fund` for details
                      ✔ Rebuild Complete
                      This time around, I didn’t do the sqlite update:
                        rm -r node_modules/better-sqlite3/
                        npm install better-sqlite3 --build-from-source --runtime=electron --target=26.4.3 --dist-url=https://electronjs.org/headers --force
                      But I don’t think it worked any better when I did. I’ll try that and then do the rebuild.
                        @UncleRoger don’t install sql again, else you have to rebuild again
                        • 1 / 4
