    Difficulty getting MMM-Transitfeed working
    31 Posts 2 Posters 6.4k Views 2 Watching
      sdetweil @UncleRoger
      @UncleRoger run npm rebuild in the module folder
      this module has a binary that has to match the electron version.
      the distributed version does not.
        @UncleRoger or
        better
        npm install @electron/rebuild
        cd modules/MMM-Transitfeed
        …/…/node_modules/.bin/electron-rebuild
        and restart MagicMirror however  you do that
        UncleRogerU 1 Reply Last reply Reply Quote 0
        • UncleRogerU Offline
          UncleRoger @sdetweil
          I gave that a bash and am still getting the same error. I even wiped the system and started from scratch just in case I’d done something to make things worse.
            @UncleRoger hm… I installed, did the npm install gtfs
            ran, failed as version mismatch
            I then did the
            ../../node_modules/.bin/electron-rebuild
            ✔ Rebuild Complete
            restart mm and no problems, using the default config
              I appreciate the help, as always… I wiped the system again, reinstalled the OS and MM, did the rebuild. Still the same error except the version numbers are different:
              [2024-06-21 15:30:32.001] [ERROR] (node:53456) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/node_modules/better-sqlite3/build/Release/better_sqlite3.node'
              was compiled against a different Node.js version using
              NODE_MODULE_VERSION 127. This version of Node.js requires
              NODE_MODULE_VERSION 121. Please try re-compiling or re-installing
              the module (for instance, using `npm rebuild` or `npm install`).
              I should mention that this is on a Pi4 (probably 2gb) with no other modules installed.
              Maybe it’s just not meant to be.
                @UncleRoger what folder are you in when you do the electron-rebuild?
                  The MMM-transitfeed module directory:
                    cd ~/MagicMirror/modules/MMM-transitfeed
                  I basically copy-and-pasted that.
                    @UncleRoger and when the electron-rebuild ran it should have said
                    something about sqllite
                    and rebuild complete, like mine above
                      Nothing about sqlite but it did say “Rebuild Complete”:
                      pi@MagicMirrorDev:~/MagicMirror $ {
                      added 81 packages in 11s
                      253 packages are looking for funding
                        run `npm fund` for details
                      ✔ Rebuild Complete
                      This time around, I didn’t do the sqlite update:
                        rm -r node_modules/better-sqlite3/
                        npm install better-sqlite3 --build-from-source --runtime=electron --target=26.4.3 --dist-url=https://electronjs.org/headers --force
                      But I don’t think it worked any better when I did. I’ll try that and then do the rebuild.
                        @UncleRoger don’t install sql again, else you have to rebuild again
                          Oops. I did the rebuild again. Still doesn’t say anything about the sqlite3 but it does say rebuild complete.
                            @UncleRoger and? does it run.
                              Sadly, no. Same error.
                                UncleRoger @UncleRoger
                                Could it be hardware related? I’m not sure I have another Pi4 I can test with but I’ve got a Pi Zero 2 I could try. Would that be of any use?
                                  @UncleRoger its not hardware, but another try wouldn’t hurt
                                  UncleRogerU 2 Replies Last reply Reply Quote 0
                                    There is no joy in mudville.
                                    Here’s what I did with a fresh install of PiOS (Raspberry Pi 4 2gb):
                                    pi@MagicMirrorDev:~/MagicMirror $ history
                                        1  {   sudo apt update;   sudo apt full-upgrade; }
                                        2  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                        3  sudo nmtui
                                        4  sudo shutdown -r now
                                        5  sudo nmtui
                                        6  sudu shutdown -r now
                                        7  sudo shutdown -r now
                                        8  {   cd ~/MagicMirror/modules;   git clone https://github.com/bnitkin/MMM-transitfeed.git; }
                                        9  cd ..
                                       10  {   cd ~/MagicMirror                     # Enter magicmirror project directory
                                               npm uninstall gtfs-realtime-bindings # Now part of gtfs
                                               npm install gtfs --save-dev          # Force update to latest version
                                       11  {   cd ~/MagicMirror                     # Enter magicmirror project directory
                                       12  {   sudo npm install -g n;   sudo n lts;   sudo n latest;   sudo n prune; }
                                       13  {   cd ~/MagicMirror                     # Enter magicmirror project directory
                                       14  cd $HOME/MagicMirror;
                                       15  DISPLAY=:0 npm start
                                       16  npm run config:check
                                       17  DISPLAY=:0 npm start
                                       18  npm run config:check
                                       19  DISPLAY=:0 npm start
                                       20  npm run config:check
                                       21  DISPLAY=:0 npm start
                                       22  {   cd ~/MagicMirror;   rm -r node_modules/better-sqlite3/;   npm install better-sqlite3 --build-from-source --runtime=electron --target=26.4.3 --dist-url=https://electronjs.org/headers --force; }
                                       23  {   cd ~/MagicMirror;   npm install @electron/rebuild; }
                                       24  {   cd ~/MagicMirror/modules/MMM-transitfeed;   ../../node_modules/.bin/electron-rebuild;   cd ~/MagicMirror; }
                                       25  DISPLAY=:0 npm start
                                       26  history
                                    The nmtui stuff is to set the IP address (which I did wrong a couple of times) and then I mucked up the config.js putting in the transitfeed module stuff.
                                    Here’s the log from trying to run it at the end (it’s basically the same):
                                    [2024-06-25 11:53:08.617] [LOG]   MMM-transitfeed: Importing with [object Object]
                                    [2024-06-25 11:53:08.649] [ERROR] (node:3464) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/node_modules/better-sqlite3/build/Release/better_sqlite3.node'
                                    NODE_MODULE_VERSION 116. This version of Node.js requires
                                        at process.func [as dlopen] (node:electron/js2c/node_init:2:2214)
                                        at Module._extensions..node (node:internal/modules/cjs/loader:1343:18)
                                        at Object.func [as .node] (node:electron/js2c/node_init:2:2214)
                                        at Module.load (node:internal/modules/cjs/loader:1098:32)
                                        at Module._load (node:internal/modules/cjs/loader:945:12)
                                        at c._load (node:electron/js2c/node_init:2:13672)
                                        at Module.require (node:internal/modules/cjs/loader:1122:19)
                                        at require (node:internal/modules/helpers:130:18)
                                        at bindings (/home/pi/MagicMirror/node_modules/bindings/bindings.js:112:48)
                                        at new Database (/home/pi/MagicMirror/node_modules/better-sqlite3/lib/database.js:48:64)
                                        at setupDb (file:///home/pi/MagicMirror/node_modules/gtfs/lib/db.js:10:14)
                                        at openDb (file:///home/pi/MagicMirror/node_modules/gtfs/lib/db.js:31:12)
                                        at Module.importGtfs (file:///home/pi/MagicMirror/node_modules/gtfs/lib/import.js:676:16)
                                        at Class.startup (/home/pi/MagicMirror/modules/MMM-transitfeed/node_helper.js:48:29)
                                        at async Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-transitfeed/node_helper.js:33:52)
                                    (Use `electron --trace-warnings ...` to show where the warning was created)
                                    [2024-06-25 11:53:08.650] [ERROR] (node:3464) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 8)
                                    I’m thinking I might give it another go from scratch without worrying about the IP address and catching all the output from each command.
                                      Could you check that I’m doing things correctly? These are the commands I’m using to get from a fresh OS to MM with transitfeed:
                                      # Update system
                                        sudo apt update
                                      # Install MagicMirror
                                      # NOTICE ON INSTALL: npm install -g npm@10.8.1
                                      # update Node/NPM
                                        sudo n lts
                                        sudo n latest
                                        sudo n prune
                                      # Install transitfeed
                                      # Install gtfs
                                      # Update better-sqlite3
                                      # Rebuild Electron?
                                      Thanks so much for your help!
                                        @UncleRoger ok, simpler
                                        flash sd card with
                                        use my script to install MM (do nothing before, it does the update and adds whats needed for MM)
                                        npm start to prove MagicMirror is working
                                        clone the module
                                        cd to the module folder and do the npm install and npm install gtfs (in module folder NOT MM folder!!)
                                        now, need electron rebuild
                                        cd …/… # magicmirror folder
                                        cd - # go back to module folder
                                        wait, should show sqlite
                                        rebuild complete
                                        cd - # back to MM folder
                                        add the config entry for the module
                                        npm start
                                        should work
                                          When you say “module folder”, you mean (in this case) ~/MagicMirror/modules/MMM-transitfeed not ~/MagicMirror/modules/ right? I’m pretty sure, but better safe than sorry.
                                          Thanks!
                                            @UncleRoger correct the module’s folder
