    Difficulty getting MMM-Transitfeed working
    31 Posts 2 Posters 6.8k Views 2 Watching
    • UncleRogerU Offline
      UncleRoger @sdetweil
      I gave that a bash and am still getting the same error. I even wiped the system and started from scratch just in case I’d done something to make things worse.
        sdetweil @UncleRoger
        @UncleRoger hm… I installed, did the npm install gtfs
        ran, failed as version mismatch
        I then did the
        ../../node_modules/.bin/electron-rebuild
        ✔ Rebuild Complete
        restart mm and no problems, using the default config
        UncleRogerU 1 Reply Last reply Reply Quote 0
          I appreciate the help, as always… I wiped the system again, reinstalled the OS and MM, did the rebuild. Still the same error except the version numbers are different:
          [2024-06-21 15:30:32.001] [ERROR] (node:53456) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/node_modules/better-sqlite3/build/Release/better_sqlite3.node'
          was compiled against a different Node.js version using
          NODE_MODULE_VERSION 127. This version of Node.js requires
          NODE_MODULE_VERSION 121. Please try re-compiling or re-installing
          the module (for instance, using `npm rebuild` or `npm install`).
          I should mention that this is on a Pi4 (probably 2gb) with no other modules installed.
          Maybe it’s just not meant to be.
            @UncleRoger what folder are you in when you do the electron-rebuild?
              The MMM-transitfeed module directory:
                npm install @electron/rebuild
                cd ~/MagicMirror/modules/MMM-transitfeed
              I basically copy-and-pasted that.
                @UncleRoger and when the electron-rebuild ran it should have said
                something about sqllite
                and rebuild complete, like mine above
                  Nothing about sqlite but it did say “Rebuild Complete”:
                  pi@MagicMirrorDev:~/MagicMirror $ {
                  added 81 packages in 11s
                  253 packages are looking for funding
                    run `npm fund` for details
                  ✔ Rebuild Complete
                  This time around, I didn’t do the sqlite update:
                    rm -r node_modules/better-sqlite3/
                    npm install better-sqlite3 --build-from-source --runtime=electron --target=26.4.3 --dist-url=https://electronjs.org/headers --force
                  But I don’t think it worked any better when I did. I’ll try that and then do the rebuild.
                    @UncleRoger don’t install sql again, else you have to rebuild again
                      Oops. I did the rebuild again. Still doesn’t say anything about the sqlite3 but it does say rebuild complete.
                        @UncleRoger and? does it run.
                          Sadly, no. Same error.
                            UncleRoger @UncleRoger
                            Could it be hardware related? I’m not sure I have another Pi4 I can test with but I’ve got a Pi Zero 2 I could try. Would that be of any use?
                              @UncleRoger its not hardware, but another try wouldn’t hurt
                              UncleRogerU 2 Replies Last reply Reply Quote 0
                                There is no joy in mudville.
                                Here’s what I did with a fresh install of PiOS (Raspberry Pi 4 2gb):
                                pi@MagicMirrorDev:~/MagicMirror $ history
                                    1  {   sudo apt update;   sudo apt full-upgrade; }
                                    2  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                    3  sudo nmtui
                                    4  sudo shutdown -r now
                                    5  sudo nmtui
                                    6  sudu shutdown -r now
                                    7  sudo shutdown -r now
                                    8  {   cd ~/MagicMirror/modules;   git clone https://github.com/bnitkin/MMM-transitfeed.git; }
                                    9  cd ..
                                   10  {   cd ~/MagicMirror                     # Enter magicmirror project directory
                                           npm uninstall gtfs-realtime-bindings # Now part of gtfs
                                           npm install gtfs --save-dev          # Force update to latest version
                                   11  {   cd ~/MagicMirror                     # Enter magicmirror project directory
                                   12  {   sudo npm install -g n;   sudo n lts;   sudo n latest;   sudo n prune; }
                                   13  {   cd ~/MagicMirror                     # Enter magicmirror project directory
                                   14  cd $HOME/MagicMirror;
                                   15  DISPLAY=:0 npm start
                                   16  npm run config:check
                                   17  DISPLAY=:0 npm start
                                   18  npm run config:check
                                   19  DISPLAY=:0 npm start
                                   20  npm run config:check
                                   21  DISPLAY=:0 npm start
                                   22  {   cd ~/MagicMirror;   rm -r node_modules/better-sqlite3/;   npm install better-sqlite3 --build-from-source --runtime=electron --target=26.4.3 --dist-url=https://electronjs.org/headers --force; }
                                   23  {   cd ~/MagicMirror;   npm install @electron/rebuild; }
                                   24  {   cd ~/MagicMirror/modules/MMM-transitfeed;   ../../node_modules/.bin/electron-rebuild;   cd ~/MagicMirror; }
                                   25  DISPLAY=:0 npm start
                                   26  history
                                The nmtui stuff is to set the IP address (which I did wrong a couple of times) and then I mucked up the config.js putting in the transitfeed module stuff.
                                Here’s the log from trying to run it at the end (it’s basically the same):
                                [2024-06-25 11:53:08.617] [LOG]   MMM-transitfeed: Importing with [object Object]
                                [2024-06-25 11:53:08.649] [ERROR] (node:3464) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/node_modules/better-sqlite3/build/Release/better_sqlite3.node'
                                NODE_MODULE_VERSION 116. This version of Node.js requires
                                    at process.func [as dlopen] (node:electron/js2c/node_init:2:2214)
                                    at Module._extensions..node (node:internal/modules/cjs/loader:1343:18)
                                    at Object.func [as .node] (node:electron/js2c/node_init:2:2214)
                                    at Module.load (node:internal/modules/cjs/loader:1098:32)
                                    at Module._load (node:internal/modules/cjs/loader:945:12)
                                    at c._load (node:electron/js2c/node_init:2:13672)
                                    at Module.require (node:internal/modules/cjs/loader:1122:19)
                                    at require (node:internal/modules/helpers:130:18)
                                    at bindings (/home/pi/MagicMirror/node_modules/bindings/bindings.js:112:48)
                                    at new Database (/home/pi/MagicMirror/node_modules/better-sqlite3/lib/database.js:48:64)
                                    at setupDb (file:///home/pi/MagicMirror/node_modules/gtfs/lib/db.js:10:14)
                                    at openDb (file:///home/pi/MagicMirror/node_modules/gtfs/lib/db.js:31:12)
                                    at Module.importGtfs (file:///home/pi/MagicMirror/node_modules/gtfs/lib/import.js:676:16)
                                    at Class.startup (/home/pi/MagicMirror/modules/MMM-transitfeed/node_helper.js:48:29)
                                    at async Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-transitfeed/node_helper.js:33:52)
                                (Use `electron --trace-warnings ...` to show where the warning was created)
                                [2024-06-25 11:53:08.650] [ERROR] (node:3464) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 8)
                                I’m thinking I might give it another go from scratch without worrying about the IP address and catching all the output from each command.
                                  Could you check that I’m doing things correctly? These are the commands I’m using to get from a fresh OS to MM with transitfeed:
                                  # Update system
                                    sudo apt update
                                  # Install MagicMirror
                                  # NOTICE ON INSTALL: npm install -g npm@10.8.1
                                  # update Node/NPM
                                    sudo n lts
                                    sudo n latest
                                    sudo n prune
                                  # Install transitfeed
                                  # Install gtfs
                                  # Update better-sqlite3
                                  # Rebuild Electron?
                                  Thanks so much for your help!
                                    @UncleRoger ok, simpler
                                    flash sd card with
                                    use my script to install MM (do nothing before, it does the update and adds whats needed for MM)
                                    npm start to prove MagicMirror is working
                                    clone the module
                                    cd to the module folder and do the npm install and npm install gtfs (in module folder NOT MM folder!!)
                                    now, need electron rebuild
                                    cd …/… # magicmirror folder
                                    cd - # go back to module folder
                                    …/…/node_modules/.bin/electron-rebuild
                                    wait, should show sqlite
                                    rebuild complete
                                    cd - # back to MM folder
                                    add the config entry for the module
                                    npm start
                                    should work
                                      When you say “module folder”, you mean (in this case) ~/MagicMirror/modules/MMM-transitfeed not ~/MagicMirror/modules/ right? I’m pretty sure, but better safe than sorry.
                                      Thanks!
                                        @UncleRoger correct the module’s folder
                                          Still no luck. 8^(
                                          I was getting a bunch of errors during the MM install which some googling suggested might be due to insufficient power (which is odd because I was using a big power supply) so I switched to an RPi power supply and still got the same errors. So maybe they’re somehow related? The errors are:
                                          During MM Install:
                                          (node:27144) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
                                          During the Electron stuff:
                                          (node:42678) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
                                            @UncleRoger it’s an npm bug, nothing fatal
                                            did you see the rebuild messages?
