Difficulty getting MMM-Transitfeed working
31 Posts 2 Posters 1.7k Views 2 Watching
  • U Offline
    UncleRoger
    Re: MMM-transitfeed - upcoming departure board for most transit agencies
    I tried to install this a while back but ran into problems. I had difficulty initially because when I tried to install it, I got a message back saying the gtfs stuff needed a newer node.js. I tried updating it and that went… badly. I managed to get things back the way they were and gave up for a bit. (Had a lot going on in my life at the time.)
    I’ve decided to try again (I want to get it working for my son who goes to school/work on public transit) and this time I set up a fresh install. New Raspberry PiOS, new MM install, nothing else done. Here’s what I’ve done so far:
    # Update system
    sudo apt update
    sudo apt full-upgrade
    # Install MagicMirror
    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
    # update Node/NPM
    sudo npm install -g n
    sudo n lts
    sudo n latest
    sudo n prune
    # Install transitfeed
    cd ~/MagicMirror/modules
    git clone https://github.com/bnitkin/MMM-transitfeed.git
    # Install gtfs
    cd ~/MagicMirror                     # Enter magicmirror project directory
    npm uninstall gtfs-realtime-bindings # Now part of gtfs
    npm install gtfs --save-dev          # Force update to latest version
    # Update better-sqlite3
    rm -r node_modules/better-sqlite3/
    npm install better-sqlite3 --build-from-source --runtime=electron --target=26.4.3 --dist-url=https://electronjs.org/headers --force
    And here’s the error I’m getting:
    [2024-06-21 11:14:44.933] [ERROR] (node:53839) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/node_modules/better-sqlite3/build/Release/better_sqlite3.node'
    was compiled against a different Node.js version using
    NODE_MODULE_VERSION 116. This version of Node.js requires
    NODE_MODULE_VERSION 121. Please try re-compiling or re-installing
    the module (for instance, using `npm rebuild` or `npm install`).
        at process.func [as dlopen] (node:electron/js2c/node_init:2:2214)
        at Module._extensions..node (node:internal/modules/cjs/loader:1343:18)
        at Object.func [as .node] (node:electron/js2c/node_init:2:2214)
        at Module.load (node:internal/modules/cjs/loader:1098:32)
        at Module._load (node:internal/modules/cjs/loader:945:12)
        at c._load (node:electron/js2c/node_init:2:13672)
        at Module.require (node:internal/modules/cjs/loader:1122:19)
        at require (node:internal/modules/helpers:130:18)
        at bindings (/home/pi/MagicMirror/node_modules/bindings/bindings.js:112:48)
        at new Database (/home/pi/MagicMirror/node_modules/better-sqlite3/lib/database.js:48:64)
        at setupDb (file:///home/pi/MagicMirror/node_modules/gtfs/lib/db.js:10:14)
        at openDb (file:///home/pi/MagicMirror/node_modules/gtfs/lib/db.js:31:12)
        at Module.importGtfs (file:///home/pi/MagicMirror/node_modules/gtfs/lib/import.js:676:16)
        at Class.startup (/home/pi/MagicMirror/modules/MMM-transitfeed/node_helper.js:48:29)
        at async Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-transitfeed/node_helper.js:33:52)
    (Use `electron --trace-warnings ...` to show where the warning was created)
    [2024-06-21 11:14:44.934] [ERROR] (node:53839) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 8)
    It seems like I need an even newer version of better_sqlite3? Or maybe an older version of node.js?
    S 1 Reply Last reply Jun 21, 2024, 6:38 PM Reply Quote 0
    • U Offline
      UncleRoger @sdetweil
      How to get MMM-transitfeed working on a new installation of MagicMirror (based on @sdetweil’s assistance)
      These are the steps I went through to get the module working after encountering version mismatch errors:
      Note that I was starting with a clean install of Raspberry PiOS. I made no changes prior to the steps outlined below:
      First, I installed MagicMirror using Sam Detweil’s script:
      Next, I installed the transitfeed module:
      Then this reset the libraries:
        rm -rf node_modules
        git checkout package.json
        git checkout package-lock.json
        npm run install-mm
      I installed the electron rebuild package:
      npm install @electron/rebuild
      Next, I reset the module info:
        cd ~/MagicMirror/modules/MMM-transitfeed
        rm -rf node_modules
        npm install
      At this point, I installed gtfs:
        npm install gtfs
      And lastly, I rebuilt sqlite3:
        ../../node_modules/.bin/electron-rebuild
      Here I added the default config from the module’s github page to my config.js and started the mirror. It worked!
      Many thanks to Sam for his patience, knowledge, and caring assistance.
        sdetweil @UncleRoger
        @UncleRoger run npm rebuild in the module folder
        this module has a binary that has to match the electron version.
        the distributed version does not.
        S 1 Reply Last reply Jun 21, 2024, 7:00 PM Reply Quote 0
          @UncleRoger or
          better
          cd modules/MMM-Transitfeed
          …/…/node_modules/.bin/electron-rebuild
          and restart MagicMirror however  you do that
          U 1 Reply Last reply Jun 21, 2024, 7:55 PM Reply Quote 0
          • U Offline
            I gave that a bash and am still getting the same error. I even wiped the system and started from scratch just in case I’d done something to make things worse.
            S 1 Reply Last reply Jun 21, 2024, 8:33 PM Reply Quote 0
              @UncleRoger hm… I installed, did the npm install gtfs
              ran, failed as version mismatch
              I then did the
              ✔ Rebuild Complete
              restart mm and no problems, using the default config
              U 1 Reply Last reply Jun 21, 2024, 10:39 PM Reply Quote 0
              • U Offline
                I appreciate the help, as always… I wiped the system again, reinstalled the OS and MM, did the rebuild. Still the same error except the version numbers are different:
                [2024-06-21 15:30:32.001] [ERROR] (node:53456) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/node_modules/better-sqlite3/build/Release/better_sqlite3.node'
                NODE_MODULE_VERSION 127. This version of Node.js requires
                I should mention that this is on a Pi4 (probably 2gb) with no other modules installed.
                Maybe it’s just not meant to be.
                S 1 Reply Last reply Jun 21, 2024, 11:21 PM Reply Quote 0
                  @UncleRoger what folder are you in when you do the electron-rebuild?
                  U 1 Reply Last reply Jun 21, 2024, 11:31 PM Reply Quote 0
                  • U Offline
                    The MMM-transitfeed module directory:
                    I basically copy-and-pasted that.
                    S 1 Reply Last reply Jun 21, 2024, 11:42 PM Reply Quote 0
                      @UncleRoger and when the electron-rebuild ran it should have said
                      something about sqllite
                      and rebuild complete, like mine above
                      U 1 Reply Last reply Jun 21, 2024, 11:51 PM Reply Quote 0
                      • U Offline
                        Nothing about sqlite but it did say “Rebuild Complete”:
                        pi@MagicMirrorDev:~/MagicMirror $ {
                        added 81 packages in 11s
                        253 packages are looking for funding
                          run `npm fund` for details
                        ✔ Rebuild Complete
                        This time around, I didn’t do the sqlite update:
                        But I don’t think it worked any better when I did. I’ll try that and then do the rebuild.
                        S 1 Reply Last reply Jun 22, 2024, 12:00 AM Reply Quote 0
                        • 1 / 4
                        1 / 4
