    Difficulty getting MMM-Transitfeed working
    31 Posts 2 Posters 6.4k Views 2 Watching
    • UncleRogerU Offline
      UncleRoger
      Re: MMM-transitfeed - upcoming departure board for most transit agencies
      I tried to install this a while back but ran into problems. I had difficulty initially because when I tried to install it, I got a message back saying the gtfs stuff needed a newer node.js. I tried updating it and that went… badly. I managed to get things back the way they were and gave up for a bit. (Had a lot going on in my life at the time.)
      I’ve decided to try again (I want to get it working for my son who goes to school/work on public transit) and this time I set up a fresh install. New Raspberry PiOS, new MM install, nothing else done. Here’s what I’ve done so far:
      # Update system
      sudo apt update
      sudo apt full-upgrade
      # Install MagicMirror
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
      # update Node/NPM
      sudo npm install -g n
      sudo n lts
      sudo n latest
      sudo n prune
      # Install transitfeed
      cd ~/MagicMirror/modules
      git clone https://github.com/bnitkin/MMM-transitfeed.git
      # Install gtfs
      cd ~/MagicMirror                     # Enter magicmirror project directory
      npm uninstall gtfs-realtime-bindings # Now part of gtfs
      npm install gtfs --save-dev          # Force update to latest version
      # Update better-sqlite3
      rm -r node_modules/better-sqlite3/
      npm install better-sqlite3 --build-from-source --runtime=electron --target=26.4.3 --dist-url=https://electronjs.org/headers --force
      And here’s the error I’m getting:
      [2024-06-21 11:14:44.933] [ERROR] (node:53839) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/node_modules/better-sqlite3/build/Release/better_sqlite3.node'
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 116. This version of Node.js requires
      NODE_MODULE_VERSION 121. Please try re-compiling or re-installing
      the module (for instance, using `npm rebuild` or `npm install`).
          at process.func [as dlopen] (node:electron/js2c/node_init:2:2214)
          at Module._extensions..node (node:internal/modules/cjs/loader:1343:18)
          at Object.func [as .node] (node:electron/js2c/node_init:2:2214)
          at Module.load (node:internal/modules/cjs/loader:1098:32)
          at Module._load (node:internal/modules/cjs/loader:945:12)
          at c._load (node:electron/js2c/node_init:2:13672)
          at Module.require (node:internal/modules/cjs/loader:1122:19)
          at require (node:internal/modules/helpers:130:18)
          at bindings (/home/pi/MagicMirror/node_modules/bindings/bindings.js:112:48)
          at new Database (/home/pi/MagicMirror/node_modules/better-sqlite3/lib/database.js:48:64)
          at setupDb (file:///home/pi/MagicMirror/node_modules/gtfs/lib/db.js:10:14)
          at openDb (file:///home/pi/MagicMirror/node_modules/gtfs/lib/db.js:31:12)
          at Module.importGtfs (file:///home/pi/MagicMirror/node_modules/gtfs/lib/import.js:676:16)
          at Class.startup (/home/pi/MagicMirror/modules/MMM-transitfeed/node_helper.js:48:29)
          at async Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-transitfeed/node_helper.js:33:52)
      (Use `electron --trace-warnings ...` to show where the warning was created)
      [2024-06-21 11:14:44.934] [ERROR] (node:53839) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 8)
      It seems like I need an even newer version of better_sqlite3? Or maybe an older version of node.js?
        UncleRoger @sdetweil
        How to get MMM-transitfeed working on a new installation of MagicMirror (based on @sdetweil’s assistance)
        These are the steps I went through to get the module working after encountering version mismatch errors:
        Note that I was starting with a clean install of Raspberry PiOS. I made no changes prior to the steps outlined below:
        First, I installed MagicMirror using Sam Detweil’s script:
        Next, I installed the transitfeed module:
        Then this reset the libraries:
          rm -rf node_modules
          git checkout package.json
          git checkout package-lock.json
          npm run install-mm
        I installed the electron rebuild package:
        npm install @electron/rebuild
        Next, I reset the module info:
          cd ~/MagicMirror/modules/MMM-transitfeed
          rm -rf node_modules
          npm install
        At this point, I installed gtfs:
          npm install gtfs
        And lastly, I rebuilt sqlite3:
          ../../node_modules/.bin/electron-rebuild
        Here I added the default config from the module’s github page to my config.js and started the mirror. It worked!
        Many thanks to Sam for his patience, knowledge, and caring assistance.
          sdetweil @UncleRoger
          @UncleRoger run npm rebuild in the module folder
          this module has a binary that has to match the electron version.
          the distributed version does not.
            @UncleRoger or
            better
            cd modules/MMM-Transitfeed
            …/…/node_modules/.bin/electron-rebuild
            and restart MagicMirror however  you do that
            UncleRogerU 1 Reply Last reply Reply Quote 0
              I gave that a bash and am still getting the same error. I even wiped the system and started from scratch just in case I’d done something to make things worse.
                @UncleRoger hm… I installed, did the npm install gtfs
                ran, failed as version mismatch
                I then did the
                ✔ Rebuild Complete
                restart mm and no problems, using the default config
                  I appreciate the help, as always… I wiped the system again, reinstalled the OS and MM, did the rebuild. Still the same error except the version numbers are different:
                  [2024-06-21 15:30:32.001] [ERROR] (node:53456) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/node_modules/better-sqlite3/build/Release/better_sqlite3.node'
                  NODE_MODULE_VERSION 127. This version of Node.js requires
                  I should mention that this is on a Pi4 (probably 2gb) with no other modules installed.
                  Maybe it’s just not meant to be.
                    @UncleRoger what folder are you in when you do the electron-rebuild?
                      The MMM-transitfeed module directory:
                      I basically copy-and-pasted that.
                        @UncleRoger and when the electron-rebuild ran it should have said
                        something about sqllite
                        and rebuild complete, like mine above
                          Nothing about sqlite but it did say “Rebuild Complete”:
                          pi@MagicMirrorDev:~/MagicMirror $ {
                          added 81 packages in 11s
                          253 packages are looking for funding
                            run `npm fund` for details
                          ✔ Rebuild Complete
                          This time around, I didn’t do the sqlite update:
                          But I don’t think it worked any better when I did. I’ll try that and then do the rebuild.
                            @UncleRoger don’t install sql again, else you have to rebuild again
                              Oops. I did the rebuild again. Still doesn’t say anything about the sqlite3 but it does say rebuild complete.
                                @UncleRoger and? does it run.
                                  Sadly, no. Same error.
                                    UncleRoger @UncleRoger
                                    Could it be hardware related? I’m not sure I have another Pi4 I can test with but I’ve got a Pi Zero 2 I could try. Would that be of any use?
                                      @UncleRoger its not hardware, but another try wouldn’t hurt
                                      UncleRogerU 2 Replies Last reply Reply Quote 0
                                        There is no joy in mudville.
                                        Here’s what I did with a fresh install of PiOS (Raspberry Pi 4 2gb):
                                        pi@MagicMirrorDev:~/MagicMirror $ history
                                            1  {   sudo apt update;   sudo apt full-upgrade; }
                                            2  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                            3  sudo nmtui
                                            4  sudo shutdown -r now
                                            5  sudo nmtui
                                            6  sudu shutdown -r now
                                            7  sudo shutdown -r now
                                            8  {   cd ~/MagicMirror/modules;   git clone https://github.com/bnitkin/MMM-transitfeed.git; }
                                            9  cd ..
                                           10  {   cd ~/MagicMirror                     # Enter magicmirror project directory
                                           11  {   cd ~/MagicMirror                     # Enter magicmirror project directory
                                           12  {   sudo npm install -g n;   sudo n lts;   sudo n latest;   sudo n prune; }
                                           13  {   cd ~/MagicMirror                     # Enter magicmirror project directory
                                           14  cd $HOME/MagicMirror;
                                           15  DISPLAY=:0 npm start
                                           16  npm run config:check
                                           17  DISPLAY=:0 npm start
                                           18  npm run config:check
                                           19  DISPLAY=:0 npm start
                                           20  npm run config:check
                                           21  DISPLAY=:0 npm start
                                           22  {   cd ~/MagicMirror;   rm -r node_modules/better-sqlite3/;   npm install better-sqlite3 --build-from-source --runtime=electron --target=26.4.3 --dist-url=https://electronjs.org/headers --force; }
                                           23  {   cd ~/MagicMirror;   npm install @electron/rebuild; }
                                           24  {   cd ~/MagicMirror/modules/MMM-transitfeed;   ../../node_modules/.bin/electron-rebuild;   cd ~/MagicMirror; }
                                           25  DISPLAY=:0 npm start
                                           26  history
                                        The nmtui stuff is to set the IP address (which I did wrong a couple of times) and then I mucked up the config.js putting in the transitfeed module stuff.
                                        Here’s the log from trying to run it at the end (it’s basically the same):
                                        [2024-06-25 11:53:08.617] [LOG]   MMM-transitfeed: Importing with [object Object]
                                        [2024-06-25 11:53:08.649] [ERROR] (node:3464) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/node_modules/better-sqlite3/build/Release/better_sqlite3.node'
                                        [2024-06-25 11:53:08.650] [ERROR] (node:3464) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 8)
                                        I’m thinking I might give it another go from scratch without worrying about the IP address and catching all the output from each command.
                                          Could you check that I’m doing things correctly? These are the commands I’m using to get from a fresh OS to MM with transitfeed:
                                          # Update system
                                            sudo apt update
                                          # NOTICE ON INSTALL: npm install -g npm@10.8.1
                                          # update Node/NPM
                                            sudo n lts
                                            sudo n latest
                                            sudo n prune
                                          # Install gtfs
                                          # Rebuild Electron?
                                          Thanks so much for your help!
                                            @UncleRoger ok, simpler
                                            flash sd card with
                                            use my script to install MM (do nothing before, it does the update and adds whats needed for MM)
                                            npm start to prove MagicMirror is working
                                            clone the module
                                            cd to the module folder and do the npm install and npm install gtfs (in module folder NOT MM folder!!)
                                            now, need electron rebuild
                                            cd …/… # magicmirror folder
                                            cd - # go back to module folder
                                            wait, should show sqlite
                                            rebuild complete
                                            cd - # back to MM folder
                                            add the config entry for the module
                                            npm start
                                            should work
                                              When you say “module folder”, you mean (in this case) ~/MagicMirror/modules/MMM-transitfeed not ~/MagicMirror/modules/ right? I’m pretty sure, but better safe than sorry.
                                              Thanks!
