    Difficulty getting MMM-Transitfeed working
    31 Posts 2 Posters 7.3k Views 2 Watching
    • UncleRogerU Offline
      UncleRoger @sdetweil
      When you say “module folder”, you mean (in this case) ~/MagicMirror/modules/MMM-transitfeed not ~/MagicMirror/modules/ right? I’m pretty sure, but better safe than sorry.
      Thanks!
        sdetweil @UncleRoger
        @UncleRoger correct the module’s folder
        UncleRogerU 1 Reply Last reply Reply Quote 0
          Still no luck. 8^(
          I was getting a bunch of errors during the MM install which some googling suggested might be due to insufficient power (which is odd because I was using a big power supply) so I switched to an RPi power supply and still got the same errors. So maybe they’re somehow related? The errors are:
          During MM Install:
          (node:27144) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
          During the Electron stuff:
          (node:42678) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
            @UncleRoger it’s an npm bug, nothing fatal
            did you see the rebuild messages?
              It said “Rebuild Complete” but nothing about sqlite3.
                @UncleRoger ok, let see if we can clean up and try again
                so we are going to reset the MM loaded libs and the module loaded libs
                rm -rf node_modules
                git checkout package.json
                git checkout package-lock.json
                npm run install-mm
                when finished
                npm install @electron/rebuild
                now the module
                cd modules/MMM-Transitfeed
                rm -rf node_modules
                npm install
                when finished
                npm install btfs
                when finished
                ../../node_modules/.bin/electron-rebuild
                  @sdetweil said in Difficulty getting MMM-Transitfeed working:
                  ok, let see if wee can clean up and try again
                  That worked! Yay!
                  Thank you so very much! I really appreciate all your help. You are truly amazing.
                  My next step is to figure out how to get to the same point with my actual dev system before making the same changes to the production system. That and how to get it to work with my local transit system’s feeds.
                    @UncleRoger said in Difficulty getting MMM-Transitfeed working:
                    well, you can follow the steps from
                    onward
                    or you can follow all those steps… won’t hurt anything
                      that I have no clue on…
                      is this closeable?
                        is this closeable?
                        Definitely. Thanks again!
                          @UncleRoger ok, another learning thing…
                          find the message that best articulates the solution, click the 3 dots to the lower right and select “Mark this post as the correct answer”
                          you open it, you close it…
                            How to get MMM-transitfeed working on a new installation of MagicMirror (based on @sdetweil’s assistance)
                            These are the steps I went through to get the module working after encountering version mismatch errors:
                            Note that I was starting with a clean install of Raspberry PiOS. I made no changes prior to the steps outlined below:
                            First, I installed MagicMirror using Sam Detweil’s script:
                            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                            Next, I installed the transitfeed module:
                              cd ~/MagicMirror/modules
                              git clone https://github.com/bnitkin/MMM-transitfeed.git
                            Then this reset the libraries:
                              rm -rf node_modules
                              npm run install-mm
                            I installed the electron rebuild package:
                            Next, I reset the module info:
                              cd ~/MagicMirror/modules/MMM-transitfeed
                              rm -rf node_modules
                              npm install
                            At this point, I installed gtfs:
                              npm install gtfs
                            And lastly, I rebuilt sqlite3:
                            Here I added the default config from the module’s github page to my config.js and started the mirror. It worked!
                            Many thanks to Sam for his patience, knowledge, and caring assistance.
                            • UncleRogerU UncleRoger has marked this topic as solved on
