    Difficulty getting MMM-Transitfeed working
    31 Posts 2 Posters 7.3k Views 2 Watching
      sdetweil @UncleRoger
      @UncleRoger ok, simpler
      flash sd card with
      use my script to install MM (do nothing before, it does the update and adds whats needed for MM)
      npm start to prove MagicMirror is working
      clone the module
      cd to the module folder and do the npm install and npm install gtfs (in module folder NOT MM folder!!)
      npm install gtfs --save-dev
      now, need electron rebuild
      cd …/… # magicmirror folder
      npm install @electron/rebuild
      cd - # go back to module folder
      …/…/node_modules/.bin/electron-rebuild
      wait, should show sqlite
      rebuild complete
      cd - # back to MM folder
      add the config entry for the module
      npm start
      should work
      UncleRogerU 1 Reply Last reply Reply Quote 0
      • UncleRogerU Offline
        UncleRoger @sdetweil
        When you say “module folder”, you mean (in this case) ~/MagicMirror/modules/MMM-transitfeed not ~/MagicMirror/modules/ right? I’m pretty sure, but better safe than sorry.
        Thanks!
          @UncleRoger correct the module’s folder
            Still no luck. 8^(
            I was getting a bunch of errors during the MM install which some googling suggested might be due to insufficient power (which is odd because I was using a big power supply) so I switched to an RPi power supply and still got the same errors. So maybe they’re somehow related? The errors are:
            During MM Install:
            (node:27144) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
            During the Electron stuff:
            (node:42678) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
              @UncleRoger it’s an npm bug, nothing fatal
              did you see the rebuild messages?
                It said “Rebuild Complete” but nothing about sqlite3.
                  @UncleRoger ok, let see if we can clean up and try again
                  so we are going to reset the MM loaded libs and the module loaded libs
                  rm -rf node_modules
                  git checkout package.json
                  git checkout package-lock.json
                  npm run install-mm
                  when finished
                  now the module
                  cd modules/MMM-Transitfeed
                  rm -rf node_modules
                  npm install
                  when finished
                  npm install btfs
                  when finished
                  ../../node_modules/.bin/electron-rebuild
                    @sdetweil said in Difficulty getting MMM-Transitfeed working:
                    ok, let see if wee can clean up and try again
                    That worked! Yay!
                    Thank you so very much! I really appreciate all your help. You are truly amazing.
                    My next step is to figure out how to get to the same point with my actual dev system before making the same changes to the production system. That and how to get it to work with my local transit system’s feeds.
                      @UncleRoger said in Difficulty getting MMM-Transitfeed working:
                      well, you can follow the steps from
                      onward
                      or you can follow all those steps… won’t hurt anything
                        that I have no clue on…
                        is this closeable?
                          is this closeable?
                          Definitely. Thanks again!
                            @UncleRoger ok, another learning thing…
                            find the message that best articulates the solution, click the 3 dots to the lower right and select “Mark this post as the correct answer”
                            you open it, you close it…
                              How to get MMM-transitfeed working on a new installation of MagicMirror (based on @sdetweil’s assistance)
                              These are the steps I went through to get the module working after encountering version mismatch errors:
                              Note that I was starting with a clean install of Raspberry PiOS. I made no changes prior to the steps outlined below:
                              First, I installed MagicMirror using Sam Detweil’s script:
                              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                              Next, I installed the transitfeed module:
                                cd ~/MagicMirror/modules
                                git clone https://github.com/bnitkin/MMM-transitfeed.git
                              Then this reset the libraries:
                                rm -rf node_modules
                                npm run install-mm
                              I installed the electron rebuild package:
                              Next, I reset the module info:
                                cd ~/MagicMirror/modules/MMM-transitfeed
                                rm -rf node_modules
                                npm install
                              At this point, I installed gtfs:
                                npm install gtfs
                              And lastly, I rebuilt sqlite3:
                              Here I added the default config from the module’s github page to my config.js and started the mirror. It worked!
                              Many thanks to Sam for his patience, knowledge, and caring assistance.
                              • UncleRogerU UncleRoger has marked this topic as solved on
