    CPU 100%. started too many instances of MM
    6 Posts 3 Posters 753 Views 3 Watching
    • C Offline
      capedbuffethero
      So I’m technical, but I don’t normally work with node.
      How do I clean up this mess I’ve made for myself?
      I started up node via npm and pm2 and noticed the system getting slower. Now, it’s unusable. I tried running htop to see what was running, and as I suspected, I started too many instances. Even after reboot, the instances seem keep running.
      The screenshots below show. multiple instances of npm start, Daemon.js, node serveronly, npm, npm start, node /home/thelows/MagicMirror/node_modules/.bin/pm2 -
      what’s a quick way to clean this all up, and … as a bonus, how should I start, stop, restart the MM process?
      Screenshot 2024-06-29 at 2.49.17 PM.png Screenshot 2024-06-29 at 2.49.33 PM.png
      • C Offline
        capedbuffethero
        I also noticed that pip and pip3 instances are hogging the CPU. That can’t be good either!
        I restarted, so I’m not sure why pip is running.
        asking for help here! I’m a java dev, but now in management roles, so I don’t do this stuff as much. I can be a good contributor to the community, I just need a little help with getting off the ground, promise!
          sdetweil @capedbuffethero
          @capedbuffethero you can’t start w both npm AND pm2… one or the other
          pm2 stop all
          only one can use the port at a time
          pip sounds like a module
          • C Offline
            capedbuffethero @sdetweil
            @sdetweil pip is the python package manager
            S evroomE 2 Replies Last reply Reply Quote 0
              @capedbuffethero I understand that. MagicMirror doesn’t use python.
              • evroomE Online
                evroom @capedbuffethero
                @capedbuffethero
                Hi there,
                Concerning pip you will need to find out what is calling it.
                Normally it is not a daemon process, meaning something else is calling it.
                Can you get the following output:
                ps aux | grep pip
                And then using the lowest PID found:
                pstree -a <PID>
                You can find the lowest PID using:
                ps aux | grep pid | awk '{print $2}' | sort -u
                You can also check if there is a cronjob running that is calling pip:
                crontab -l | egrep 'pip|python'
                From there we can Google ourselves to a solution :-)
                Best regards,
                E.J.
                MagicMirror version: 2.37.0
