    Tado is no longer displayed after update 2.28
    12 Posts 2 Posters 2.2k Views 2 Watching
    • J
      JoeFranz
      Hello,
      since the update to 2.28, MMM-Tado no longer works, nothing is displayed. There are no errors in the logs.
      Can anyone help?
        sdetweil @JoeFranz
        @JoeFranz let’s look this way
        pm2 stop all
        cd ~/MagicMirror
        npm start
        • J
          JoeFranz @sdetweil
          @sdetweil The same, Tado is not displayed :-(
            sdetweil @JoeFranz
            @JoeFranz but what are the messages from npm start
            • J
              JoeFranz @sdetweil
              > magicmirror@2.28.0 start
              [2024-07-01 12:56:47.307] [LOG]   Starting MagicMirror: v2.28.0
              [2024-07-01 12:56:47.381] [LOG]   Loading config ...
              [2024-07-01 12:56:47.387] [LOG]   config template file not exists, no envsubst
              [2024-07-01 12:56:51.040] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
              [2024-07-01 12:56:51.056] [LOG]   [Tools] MMM-Tools Version: 2.1.7
              [2024-07-01 12:56:51.066] [LOG]   Starting node_helper for module: MMM-PhilipsHue
              [2602:0701/125724.577098:ERROR:atom_cache.cc(229)] Add WM_CHANGE_STATE to kAtomsToCache
                sdetweil @JoeFranz
                @JoeFranz well that’s incredibly short
                J 2 Replies Last reply Reply Quote 0
                • J
                  JoeFranz @sdetweil
                  @sdetweil But everything else works, except Tado
                  • J
                    JoeFranz @sdetweil
                    @sdetweil I have now reinstalled Tado and am getting these messages
                    npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                    npm warn deprecated glob@7.2.0: Glob versions prior to v9 are no longer supported
                    added 100 packages, and audited 101 packages in 33s
                    22 packages are looking for funding
                      run `npm fund` for details
                    2 moderate severity vulnerabilities
                    To address all issues (including breaking changes), run:
                      npm audit fix --force
                    Run `npm audit` for details.
                      sdetweil @JoeFranz
                      @JoeFranz noise, ignore
                      does it work now?
                      • J
                        JoeFranz @sdetweil
                        @sdetweil No, it is not displayed
                        • J
                          JoeFranz @sdetweil
                          There was probably an error in the config regarding the position of the modules. Two modules had “top_right” and Tado had “right”. With “bottom_right” for Tado it is now displayed again. Strange that it worked like this before the update…
                          • J JoeFranz has marked this topic as solved on
                            sdetweil @JoeFranz
                            @JoeFranz ah, there should have been an error listed, as we added position checking to this release. used to cause a crash
