    Default language changed after update
    14 Posts 2 Posters 2.5k Views 2 Watching
    • M
      mrbaloo1337
      Hi!
      I updated my MM, after that I have some issues with the language. I prefer Swedish and used this config:
      language: “sv”,
      locale: “sv-SV”,
      Worked like a charm, but after update everything is Samian instead of Swedish. If I change to “en” it will be English.
      I tried to se if the code changed, but did not find a solution. Doe´s anyone have an idéa whats wrong?
      Regards Daniel
      • M
        mrbaloo1337
        Hi again, for some magical reason i solved it.
        I had a module MMM-jast. Wich is the last one I installed before upgrade. For test, I took a backup of the config without that module.
        Everything was in Swedish again, added my config for that module in the backupconfig file. Everything works as before.
        I can´t point what caused the error, but now it works again. Maybe the file ended up corrupt in the upgrade…
        Thanks for your response and time, have a good day!
          sdetweil @mrbaloo1337
          @mrbaloo1337 can you check the ~/MagicMirror/translations/sv.json file
          • M
            mrbaloo1337
            This is what that file contains. Seems to be the only thing that is correct translated. Anything else will be in Sami.
            If I check in the translation file the row for Swedish is: “sv: “translations/sv.json”, // Svenska”
            	"LOADING": "Laddar …",
            	"DAYBEFOREYESTERDAY": "",
            	"YESTERDAY": "I går",
            	"TODAY": "I dag",
            	"TOMORROW": "I morgon",
            	"DAYAFTERTOMORROW": "I övermorgon",
            	"RUNNING": "Slutar",
            	"EMPTY": "Inga kommande händelser.",
            	"WEEK": "Vecka {weekNumber}",
            	"N": "N",
            	"NNE": "NNO",
            	"NE": "NO",
            	"ENE": "ONO",
            	"E": "Ö",
            	"ESE": "OSO",
            	"SE": "SO",
            	"SSE": "SSO",
            	"S": "S",
            	"SSW": "SSV",
            	"SW": "SV",
            	"WSW": "VSV",
            	"W": "V",
            	"WNW": "VNV",
            	"NW": "NV",
            	"NNW": "NNV",
            	"FEELS": "Känns som {DEGREE}",
            	"UPDATE_NOTIFICATION": "MagicMirror² uppdatering finns tillgänglig.",
            	"UPDATE_NOTIFICATION_MODULE": "Uppdatering finns tillgänglig av {MODULE_NAME} modulen.",
            	"UPDATE_INFO_SINGLE": "Denna installation ligger {COMMIT_COUNT} commit steg bakom {BRANCH_NAME} grenen.",
            	"UPDATE_INFO_MULTIPLE": "Denna installation ligger {COMMIT_COUNT} commits steg bakom {BRANCH_NAME} grenen."
              @mrbaloo1337 sorry, I don’t understand your response.
              is the file good or bad?
              what mm version were you on?
              • M
                mrbaloo1337 @sdetweil
                Sorry, it looks good as far as I can see. I the texts in that file is the only workning translations. For example:
                “FEELS”: “Känns som {DEGREE}”,
                That´s a correct translation and works in Weather module, but weekdays is in Sami. See picture below.
                That´s the same problem for every module. Hope you understand what I mean :)
                I think that the connection to “sv” is broken and points to Sami instead of Swedish.
                • M
                  Sorry missed, it is version 2.28.0
                    @mrbaloo1337 I meant before this release.
                    • M
                      No issues before upgrade, is it possible to downgrade to previous version?
                        @mrbaloo1337 yes, but, I asked you to tell me what that version was.
                        I am out of the house for another hour
                        • M
                          I wrote that earlier, it is 2.28.0.
                          No worries, if you have any suggestions to my problem I will wait :)
                          On Saturday I leave for vacation so I hope it will be solved until that, otherwise I can´t sleep
                            @mrbaloo1337
                            2.28.0 is the current release number
                            I want to know what version you were running prior to this one
                            if you upgraded with my upgrade script, you can look in the log file
                            ~/MagicMirror/installers/upgrade.log
                            • M
                              mrbaloo1337
                              I was running on 2.27.0
                              As far as I found out Sami is listed as “SE” and Swedish is “SV” in the ISO list for language. If that is for any help?
                              This is the log file:
                              Upgrade started - Wed Jul  3 13:27:27 CEST 2024
                              system is Linux raspberrypi 6.6.31+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64 GNU/Linux
                              doing test run = true, NO updates will be applied!
                              the os is Distributor ID: Debian Description: Debian GNU/Linux 12 (bookworm) Release: 12 Codename: bookworm
                              Check current Node installation ...
                              Node currently installed. Checking version number.
                              Minimum Node version: v20.9.0
                              Installed Node version: v20.8.0
                              Node should be upgraded.
                              Node.js upgrade defered, doing test run
                              Check current NPM installation ...
                              NPM currently installed. Checking version number.
                              Minimum npm version: V10.1.0
                              Installed npm version: V10.1.0
                              No npm upgrade necessary.
                              saving custom.css
                              remote name = origin
                              upgrading from version 2.27.0 to 2.28.0
                              fetching latest revisions
                              git fetch rc=0
                              current branch = master
                              On branch master
                              Your branch is behind 'origin/master' by 1 commit, and can be fast-forwarded.
                                (use "git pull" to update your local branch)
                              Changes not staged for commit:
                                (use "git add <file>..." to update what will be committed)
                                (use "git restore <file>..." to discard changes in working directory)
                              	modified:   package-lock.json
                              Untracked files:
                                (use "git add <file>..." to include in what will be committed)
                              	icscalender/
                              	run-start.sh
                              no changes added to commit (use "git add" and/or "git commit -a")
                              there are 1 local files that are different than the master repo
                                 package-lock.json
                              save/restore files selection = n
                              restoring package-lock.json from repo
                              skipping restore for package-lock.json, doing test run
                              test merge result rc='' , if empty, no conflicts
                              skipping merge, only test run
                              Checking for modules with removed libraries
                              downloading dumpactivemodules script
                              updating dependencies for active modules with package.json files
                              	processing for module MMM-MQTT please wait
                              	skipped processing for MMM-MQTT, doing test run
                              	processing complete for module MMM-MQTT
                              	processing for module MMM-CalendarExt3 please wait
                              	skipped processing for MMM-CalendarExt3, doing test run
                              	processing complete for module MMM-CalendarExt3
                              restoring custom.css
                              removing git alias
                              Upgrade ended - Wed Jul  3 13:27:53 CEST 2024
                              • M
                                mrbaloo1337
                                  @mrbaloo1337 very interesting. we don’t touch the config file . I don’t copy/restore it.
