    calendar fetch goes wrong and gpu process error
    14 Posts 4 Posters 2.8k Views 4 Watching
      rotorax
      after upgrading to the second community release Im stuck with these errors:
      0|mm | [4143:0719/155732.710554:ERROR:gpu_process_host.cc(989)] GPU process exited unexpectedly: exit_code=512
      0|mm | [2024-07-19 15:58:46.475] [ERROR] Calendar Error. Could not fetch calendar: MY-iCLOUD-CALENDAR-ADRESS TypeError: fetch failed
      0|mm | at Object.fetch (node:internal/deps/undici/undici:12293:11)
      0|mm | at processTicksAndRejections (node:internal/process/task_queues:95:5)
      0|mm | at runNextTicks (node:internal/process/task_queues:64:3)
      0|mm | at process.processImmediate (node:internal/timers:449:9) {
      0|mm | cause: ConnectTimeoutError: Connect Timeout Error
      0|mm | at onConnectTimeout (node:internal/deps/undici/undici:7434:28)
      0|mm | at node:internal/deps/undici/undici:7390:50
      0|mm | at Immediate._onImmediate (node:internal/deps/undici/undici:7422:13)
      0|mm | at process.processImmediate (node:internal/timers:478:21) {
      0|mm | code: ‘UND_ERR_CONNECT_TIMEOUT’
      0|mm | }
      Im running on a raspberry pi 2B+ with the node version v21.7.3
      Any ideas or known problems? I don’t find any in combination of these two errors.
      Thanks in advance :)
      S karsten13K 2 Replies Last reply Reply Quote 0
        sdetweil @rotorax
        @rotorax how did you upgrade? manual or script?
        from what release?
        the newest releases disable GPU use by default to get rid of that
        the other calendar
        can you show the calendar entry … xxx out the private stuff on the URL …
        is this loading file from a local file?
          rotorax @sdetweil
          I updated from 2.27.0 to 2.28.0 by script.
          Sounds like 2.28.0 isn’t the newest release anymore? Or will it be fixed in the unreleased version?
          What do you mean with the calendar entry? The config?
          module: “calendar”,
          header: “Müllkalender”,
          position: “bottom_left”,
          customEvents: [{keyword: ‘bio’, symbol: ‘recycle’, color: ‘green’},{keyword: ‘müll’, symbol: ‘trash’, color: ‘Green’}],
          fetchInterval: 1200000,
          fadePoint: 0.75,
          symbol: “calendar-check”,
          maximumEntries: 3,
          url: “https://xxx”
          thank you!
            sdetweil @rotorax
            @rotorax 2.28 is the current release.
            don’t know.on the cal, we’ve seen multiple similar situations. no sure cause yet
            • karsten13K Offline
              karsten13 @rotorax
              @rotorax
              can we get the provided system informations from the logs?
              should look like
              [2024-07-19 19:18:05.141] [INFO]  System information:
              ### SYSTEM:   manufacturer: Microsoft; model: Docker Container; raspberry: undefined; virtual: true
              ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: x64; kernel: 5.15.153.1-microsoft-standard-WSL2
              ### VERSIONS: electron: undefined; used node: 22.4.1; installed node: 22.4.1; npm: 10.8.1; pm2:
              ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                rotorax @karsten13
                @karsten13
                here is the information:
                [2024-07-22 07:54:19.741] [INFO] System information:
                SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model A Plus Rev 1.0; raspberry: [object Object]; virtual: false
                OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+
                VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 21.7.3; npm: 10.5.0; pm2: 5.3.1
                  karsten13 @rotorax
                  @rotorax said in calendar fetch goes wrong and gpu process error:
                  this should be MagicMirror v2.28.0 which ships with electron version v31.1.0
                  ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model A Plus Rev 1.0; raspberry: [object Object]; virtual: false
                  ### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+
                  ### VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 21.7.3; npm: 10.5.0; pm2: 5.3.1
                  but your logs tell us that you are using electron v29.1.6
                  So how did you update? It seems you didn’t run the npm ... command (see documentation how to upgrade).
                  The calendar error should be fixed with the newer electron version.
                  bugsounetB 1 Reply Last reply Reply Quote 0
                  • bugsounetB Offline
                    bugsounet Banned @karsten13
                    @karsten13 maybe it’s related with node v21.x
                      karsten13 @bugsounet
                      @bugsounet said in calendar fetch goes wrong and gpu process error:
                      I think not because he is running with electron and so using node v20.9.0 at runtime
                      @rotorax I’m still interested if it works with the correct electron version v31.1.0
                      bugsounetB R 2 Replies Last reply Reply Quote 0
                        @karsten13 don’t forget: node_helper use node version installed on system ;)
                        and node v20.9.0 i used on module core
                        —> So: fetch calandar use node version installed on system (node v21.x)
                        we checked this on a github issue, 5-6 months ago
                          sdetweil @bugsounet
                          @bugsounet no… this is why we have the electron-rebuild problem…
                          in electron mode, we have the embedded node engine… (all the work is done from inside the electron binary)
                          		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
                          and need electron rebuild to match the binary level
                          in server only mode we need the npm rebuild to get to match the node version binary level
                          		"server": "node ./serveronly",
                          use on-off, or gpio… different compiles if they are different
                          this is a good reason to keep the the nodejs versions in sync
                          make them not syncd and switch between full and server only and you will see the binary level error
                          took my brain a while to see this
                            karsten13 @sdetweil
                            found the old discussion here
                            R 1 Reply Last reply Reply Quote 2
                              rotorax @karsten13
                              l@karsten13
                              hi, im running now in the recommended electron and a newer node version
                              VERSIONS: electron: 31.1.0; used node: 20.14.0; installed node: 22.5.1; npm: 10.8.2; pm2: 5.4.1
                              The MM now starts very fast and without rebooting the raspberry. I’ll keep you updated.
                              • R rotorax has marked this topic as solved on
                                rotorax @karsten13
                                @karsten13
                                thanks again. The magic mirror now runs smoothly and without any errors :)
