    calendar fetch goes wrong and gpu process error
    14 Posts 4 Posters 2.2k Views 4 Watching
      sdetweil @bugsounet
      @bugsounet no… this is why we have the electron-rebuild problem…
      in electron mode, we have the embedded node engine… (all the work is done from inside the electron binary)
      		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
      and need electron rebuild to match the binary level
      in server only mode we need the npm rebuild to get to match the node version binary level
      		"server": "node ./serveronly",
      use on-off, or gpio… different compiles if they are different
      this is a good reason to keep the the nodejs versions in sync
      make them not syncd and switch between full and server only and you will see the binary level error
      took my brain a while to see this
      • karsten13K Offline
        karsten13 @sdetweil
        found the old discussion here
        R 1 Reply Last reply Reply Quote 2
          rotorax @karsten13
          l@karsten13
          hi, im running now in the recommended electron and a newer node version
          SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model A Plus Rev 1.0; raspberry: [object Object]; virtual: false
          OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+
          VERSIONS: electron: 31.1.0; used node: 20.14.0; installed node: 22.5.1; npm: 10.8.2; pm2: 5.4.1
          OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
          The MM now starts very fast and without rebooting the raspberry. I’ll keep you updated.
          Thanks in advance :)
          • R rotorax has marked this topic as solved on
            rotorax @karsten13
            @karsten13
            thanks again. The magic mirror now runs smoothly and without any errors :)
