    No Web UI with MMM-FastNotes
    20 Posts 3 Posters 2.0k Views 3 Watching
      rvnbrg
      Hello,
      I have the module MMM-FastNotes installed. I followed the installation instructions to the letter. But I just can’t get the web UI to work. I get a error message “This page is unreachable” from chrome. (Also tried with Microsoft Edge).
      https://github.com/polarbearjngl/MMM-FastNotes
      Can someone point me in the right direction?
      • mumblebajM Offline
        mumblebaj Module Developer @rvnbrg
        @rvnbrg Jinja is a dependency of Flask and Flask V1.X.X uses the escape module from Jinja, however recently support for the escape module was dropped in newer versions of Jinja
        To fix this issue, simply update to the newer version of Flask V2.X.X in your requirements.txt where Flask no longer uses the escape module from Jinja.
        I see there is a requirements.txt where the version of Flask is specified. Maybe updating that to 2.1.1, which is the recommended version that no longer has a dependency on escape would resolve this.
        This is all just guessing. Was trying to figure out how this module hangs together. 🫣
          sdetweil @rvnbrg
          @rvnbrg did you chnage the MM configuration to allow outside systems to access MM?
          in config.js
          address:"0.0.0.0",  // this means accept incomming connections on any network
          ipWhitelist:[],   // do not filter the source system requests
          by default, MM is built as a mirror on the wall, with NO access from outside
          address:"localhost",  // this means ONLY apps INSIDE the same system can connect
          ipWhitelist:["127.0.0.1"...].
            rvnbrg @sdetweil
            @sdetweil Yes, current setup in config is
            "address": "0.0.0.0",
            "ipWhitelist": [],
            "locale": "en-US",
            "logLevel": [
            	"INFO",
            	"LOG",
            	"WARN",
            	"ERROR"
              sdetweil @rvnbrg
              @rvnbrg the module config has this
                 host: "192.168.1.1",  // address of raspberry pi in local network, need for access to WEB UI
                  port: 5000,           // port on host where UI will be accessible via web browser
              I don’t know that that means…
              what url are you using?
              R 2 Replies Last reply Reply Quote 0
                rvnbrg @sdetweil
                @sdetweil I have
                host: “192.168.78.30”, // address of raspberry pi in local network, need for access to WEB UI
                Where “192.168.178.30” is the ip adress of my raspberry
                  rvnbrg @sdetweil
                  So I try to access the Web UI with: 192.168.178.30:5000
                    sdetweil @rvnbrg
                    @rvnbrg said in No Web UI with MMM-FastNotes:
                    192.168.178.30
                    that is an odd home network address…
                    if you do
                    ip addr
                    from a terminal window, is that the address you get?
                      rvnbrg @sdetweil
                      @sdetweil This is what I get
                      xavier@raspberrypi:~ $ ip addr
                      1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                      inet 127.0.0.1/8 scope host lo
                      valid_lft forever preferred_lft forever
                      inet6 ::1/128 scope host noprefixroute
                      2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                      link/ether b8:27:eb:69:7b:37 brd ff:ff:ff:ff:ff:ff
                      inet 192.168.178.30/24 brd 192.168.178.255 scope global noprefixroute wlan0
                      inet6 fd48:42be:e531:6cb0:2d2a:6ab4:13e2:1d5a/64 scope global dynamic noprefixroute
                      valid_lft 1624sec preferred_lft 1624sec
                      inet6 fe80::56dd:2b5f:e33f:829e/64 scope link noprefixroute
                        sdetweil @rvnbrg
                        192.168.178.30
                        ok, so you should be able to connect to MM using the port from config.js
                        http://192.168.178.30:8080
                          rvnbrg @sdetweil
                          @sdetweil Yes that works to see the MM on my desktop web browser.
                          Only the FastNotes WebUI does not load
                            sdetweil @rvnbrg
                            @rvnbrg ok, looking at the code, it looks like there is a python script that provides that UI
                            so, in the module folder do
                            python3 FastNotes.py --host 192.168.178.30 --port 5000 --debug
                              rvnbrg @sdetweil
                              @sdetweil That gives me this:
                              xavier@raspberrypi:~/MagicMirror/modules/MMM-FastNotes $ python3 FastNotes.py --host 192.168.178.30 --port 5000 --debug
                              Traceback (most recent call last):
                              File “/home/xavier/MagicMirror/modules/MMM-FastNotes/FastNotes.py”, line 2, in
                              from backend.fast_notes import start
                              File “/home/xavier/MagicMirror/modules/MMM-FastNotes/backend/fast_notes.py”, line 1, in
                              import flask
                              File “/usr/local/lib/python3.11/dist-packages/flask/init.py”, line 14, in
                              from jinja2 import escape
                              ImportError: cannot import name ‘escape’ from ‘jinja2’ (/usr/lib/python3/dist-packages/jinja2/init.py)
                              S mumblebajM 2 Replies Last reply Reply Quote 0
                                sdetweil @rvnbrg
                                that explains the error
                                  rvnbrg @sdetweil
                                  @sdetweil how can I resolve that?
                                    sdetweil @rvnbrg
                                    @rvnbrg that I don’t know
                                      rvnbrg @sdetweil
                                      @sdetweil Thank you for your help so far
                                        sdetweil @rvnbrg
                                        @rvnbrg i would ask the author
                                          rvnbrg @sdetweil
                                          @sdetweil i did so but no response yet
                                              rvnbrg @mumblebaj
                                              @mumblebaj YES! Got it working! Thank you very very much
