    No Web UI with MMM-FastNotes
    20 Posts 3 Posters 1.7k Views 3 Watching
      rvnbrg @sdetweil
      @sdetweil Yes, current setup in config is
      "address": "0.0.0.0",
      "ipWhitelist": [],
      "locale": "en-US",
      "logLevel": [
      	"INFO",
      	"LOG",
      	"WARN",
      	"ERROR"
        sdetweil @rvnbrg
        @rvnbrg the module config has this
           host: "192.168.1.1",  // address of raspberry pi in local network, need for access to WEB UI
            port: 5000,           // port on host where UI will be accessible via web browser
        I don’t know that that means…
        what url are you using?
          rvnbrg @sdetweil
          @sdetweil I have
          host: “192.168.78.30”, // address of raspberry pi in local network, need for access to WEB UI
          Where “192.168.178.30” is the ip adress of my raspberry
            rvnbrg @sdetweil
            So I try to access the Web UI with: 192.168.178.30:5000
              sdetweil @rvnbrg
              @rvnbrg said in No Web UI with MMM-FastNotes:
              192.168.178.30
              that is an odd home network address…
              if you do
              ip addr
              from a terminal window, is that the address you get?
                rvnbrg @sdetweil
                @sdetweil This is what I get
                xavier@raspberrypi:~ $ ip addr
                1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                inet 127.0.0.1/8 scope host lo
                valid_lft forever preferred_lft forever
                inet6 ::1/128 scope host noprefixroute
                2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                link/ether b8:27:eb:69:7b:37 brd ff:ff:ff:ff:ff:ff
                inet 192.168.178.30/24 brd 192.168.178.255 scope global noprefixroute wlan0
                inet6 fd48:42be:e531:6cb0:2d2a:6ab4:13e2:1d5a/64 scope global dynamic noprefixroute
                valid_lft 1624sec preferred_lft 1624sec
                inet6 fe80::56dd:2b5f:e33f:829e/64 scope link noprefixroute
                  sdetweil @rvnbrg
                  192.168.178.30
                  ok, so you should be able to connect to MM using the port from config.js
                  http://192.168.178.30:8080
                    rvnbrg @sdetweil
                    @sdetweil Yes that works to see the MM on my desktop web browser.
                    Only the FastNotes WebUI does not load
                      sdetweil @rvnbrg
                      @rvnbrg ok, looking at the code, it looks like there is a python script that provides that UI
                      so, in the module folder do
                      python3 FastNotes.py --host 192.168.178.30 --port 5000 --debug
                        rvnbrg @sdetweil
                        @sdetweil That gives me this:
                        xavier@raspberrypi:~/MagicMirror/modules/MMM-FastNotes $ python3 FastNotes.py --host 192.168.178.30 --port 5000 --debug
                        File “/home/xavier/MagicMirror/modules/MMM-FastNotes/FastNotes.py”, line 2, in
                        from backend.fast_notes import start
                        File “/home/xavier/MagicMirror/modules/MMM-FastNotes/backend/fast_notes.py”, line 1, in
                        import flask
                        File “/usr/local/lib/python3.11/dist-packages/flask/init.py”, line 14, in
                        from jinja2 import escape
                        ImportError: cannot import name ‘escape’ from ‘jinja2’ (/usr/lib/python3/dist-packages/jinja2/init.py)
                        S mumblebajM 2 Replies Last reply Reply Quote 0
                          sdetweil @rvnbrg
                          that explains the error
                            rvnbrg @sdetweil
                            @sdetweil how can I resolve that?
                              sdetweil @rvnbrg
                              @rvnbrg that I don’t know
                                rvnbrg @sdetweil
                                @sdetweil Thank you for your help so far
                                  sdetweil @rvnbrg
                                  @rvnbrg i would ask the author
                                    rvnbrg @sdetweil
                                    @sdetweil i did so but no response yet
                                    • mumblebajM Offline
                                      mumblebaj Module Developer @rvnbrg
                                      @rvnbrg Jinja is a dependency of Flask and Flask V1.X.X uses the escape module from Jinja, however recently support for the escape module was dropped in newer versions of Jinja
                                      To fix this issue, simply update to the newer version of Flask V2.X.X in your requirements.txt where Flask no longer uses the escape module from Jinja.
                                      I see there is a requirements.txt where the version of Flask is specified. Maybe updating that to 2.1.1, which is the recommended version that no longer has a dependency on escape would resolve this.
                                      This is all just guessing. Was trying to figure out how this module hangs together. 🫣
                                        rvnbrg @mumblebaj
                                        @mumblebaj YES! Got it working! Thank you very very much
