    No Web UI with MMM-FastNotes
    20 Posts 3 Posters 2.0k Views 3 Watching
      rvnbrg @sdetweil
      So I try to access the Web UI with: 192.168.178.30:5000
        sdetweil @rvnbrg
        @rvnbrg said in No Web UI with MMM-FastNotes:
        192.168.178.30
        that is an odd home network address…
        if you do
        ip addr
        from a terminal window, is that the address you get?
          rvnbrg @sdetweil
          @sdetweil This is what I get
          xavier@raspberrypi:~ $ ip addr
          1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
          link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
          inet 127.0.0.1/8 scope host lo
          valid_lft forever preferred_lft forever
          inet6 ::1/128 scope host noprefixroute
          2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
          link/ether b8:27:eb:69:7b:37 brd ff:ff:ff:ff:ff:ff
          inet 192.168.178.30/24 brd 192.168.178.255 scope global noprefixroute wlan0
          inet6 fd48:42be:e531:6cb0:2d2a:6ab4:13e2:1d5a/64 scope global dynamic noprefixroute
          valid_lft 1624sec preferred_lft 1624sec
          inet6 fe80::56dd:2b5f:e33f:829e/64 scope link noprefixroute
            sdetweil @rvnbrg
            192.168.178.30
            ok, so you should be able to connect to MM using the port from config.js
            http://192.168.178.30:8080
              rvnbrg @sdetweil
              @sdetweil Yes that works to see the MM on my desktop web browser.
              Only the FastNotes WebUI does not load
                sdetweil @rvnbrg
                @rvnbrg ok, looking at the code, it looks like there is a python script that provides that UI
                so, in the module folder do
                python3 FastNotes.py --host 192.168.178.30 --port 5000 --debug
                  rvnbrg @sdetweil
                  @sdetweil That gives me this:
                  xavier@raspberrypi:~/MagicMirror/modules/MMM-FastNotes $ python3 FastNotes.py --host 192.168.178.30 --port 5000 --debug
                  File “/home/xavier/MagicMirror/modules/MMM-FastNotes/FastNotes.py”, line 2, in
                  from backend.fast_notes import start
                  File “/home/xavier/MagicMirror/modules/MMM-FastNotes/backend/fast_notes.py”, line 1, in
                  import flask
                  File “/usr/local/lib/python3.11/dist-packages/flask/init.py”, line 14, in
                  from jinja2 import escape
                  ImportError: cannot import name ‘escape’ from ‘jinja2’ (/usr/lib/python3/dist-packages/jinja2/init.py)
                  S mumblebajM 2 Replies Last reply Reply Quote 0
                    sdetweil @rvnbrg
                    that explains the error
                      rvnbrg @sdetweil
                      @sdetweil how can I resolve that?
                        sdetweil @rvnbrg
                        @rvnbrg that I don’t know
                          rvnbrg @sdetweil
                          @sdetweil Thank you for your help so far
                            sdetweil @rvnbrg
                            @rvnbrg i would ask the author
                              rvnbrg @sdetweil
                              @sdetweil i did so but no response yet
                              • mumblebajM Offline
                                mumblebaj Module Developer @rvnbrg
                                @rvnbrg Jinja is a dependency of Flask and Flask V1.X.X uses the escape module from Jinja, however recently support for the escape module was dropped in newer versions of Jinja
                                To fix this issue, simply update to the newer version of Flask V2.X.X in your requirements.txt where Flask no longer uses the escape module from Jinja.
                                I see there is a requirements.txt where the version of Flask is specified. Maybe updating that to 2.1.1, which is the recommended version that no longer has a dependency on escape would resolve this.
                                This is all just guessing. Was trying to figure out how this module hangs together. 🫣
                                  rvnbrg @mumblebaj
                                  @mumblebaj YES! Got it working! Thank you very very much
