    No Web UI with MMM-FastNotes
    20 Posts 3 Posters 2.1k Views 3 Watching
      rvnbrg @sdetweil
      @sdetweil This is what I get
      xavier@raspberrypi:~ $ ip addr
      1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
      inet 127.0.0.1/8 scope host lo
      valid_lft forever preferred_lft forever
      inet6 ::1/128 scope host noprefixroute
      2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
      link/ether b8:27:eb:69:7b:37 brd ff:ff:ff:ff:ff:ff
      inet 192.168.178.30/24 brd 192.168.178.255 scope global noprefixroute wlan0
      inet6 fd48:42be:e531:6cb0:2d2a:6ab4:13e2:1d5a/64 scope global dynamic noprefixroute
      valid_lft 1624sec preferred_lft 1624sec
      inet6 fe80::56dd:2b5f:e33f:829e/64 scope link noprefixroute
        sdetweil @rvnbrg
        @rvnbrg said in No Web UI with MMM-FastNotes:
        192.168.178.30
        ok, so you should be able to connect to MM using the port from config.js
        http://192.168.178.30:8080
          rvnbrg @sdetweil
          @sdetweil Yes that works to see the MM on my desktop web browser.
          Only the FastNotes WebUI does not load
            sdetweil @rvnbrg
            @rvnbrg ok, looking at the code, it looks like there is a python script that provides that UI
            so, in the module folder do
            python3 FastNotes.py --host 192.168.178.30 --port 5000 --debug
              rvnbrg @sdetweil
              @sdetweil That gives me this:
              xavier@raspberrypi:~/MagicMirror/modules/MMM-FastNotes $ python3 FastNotes.py --host 192.168.178.30 --port 5000 --debug
              File “/home/xavier/MagicMirror/modules/MMM-FastNotes/FastNotes.py”, line 2, in
              from backend.fast_notes import start
              File “/home/xavier/MagicMirror/modules/MMM-FastNotes/backend/fast_notes.py”, line 1, in
              import flask
              File “/usr/local/lib/python3.11/dist-packages/flask/init.py”, line 14, in
              from jinja2 import escape
              ImportError: cannot import name ‘escape’ from ‘jinja2’ (/usr/lib/python3/dist-packages/jinja2/init.py)
              S mumblebajM 2 Replies Last reply Reply Quote 0
                sdetweil @rvnbrg
                that explains the error
                  rvnbrg @sdetweil
                  @sdetweil how can I resolve that?
                    sdetweil @rvnbrg
                    @rvnbrg that I don’t know
                      rvnbrg @sdetweil
                      @sdetweil Thank you for your help so far
                        sdetweil @rvnbrg
                        @rvnbrg i would ask the author
                          rvnbrg @sdetweil
                          @sdetweil i did so but no response yet
                          • mumblebajM Offline
                            mumblebaj Module Developer @rvnbrg
                            @rvnbrg Jinja is a dependency of Flask and Flask V1.X.X uses the escape module from Jinja, however recently support for the escape module was dropped in newer versions of Jinja
                            To fix this issue, simply update to the newer version of Flask V2.X.X in your requirements.txt where Flask no longer uses the escape module from Jinja.
                            I see there is a requirements.txt where the version of Flask is specified. Maybe updating that to 2.1.1, which is the recommended version that no longer has a dependency on escape would resolve this.
                            This is all just guessing. Was trying to figure out how this module hangs together. 🫣
                              rvnbrg @mumblebaj
                              @mumblebaj YES! Got it working! Thank you very very much
