    No Web UI with MMM-FastNotes
    20 Posts 3 Posters 2.1k Views 3 Watching
      sdetweil @rvnbrg
      @rvnbrg said in No Web UI with MMM-FastNotes:
      192.168.178.30
      that is an odd home network address…
      if you do
      ip addr
      from a terminal window, is that the address you get?
        rvnbrg @sdetweil
        @sdetweil This is what I get
        xavier@raspberrypi:~ $ ip addr
        1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
        inet 127.0.0.1/8 scope host lo
        valid_lft forever preferred_lft forever
        inet6 ::1/128 scope host noprefixroute
        2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
        link/ether b8:27:eb:69:7b:37 brd ff:ff:ff:ff:ff:ff
        inet 192.168.178.30/24 brd 192.168.178.255 scope global noprefixroute wlan0
        inet6 fd48:42be:e531:6cb0:2d2a:6ab4:13e2:1d5a/64 scope global dynamic noprefixroute
        valid_lft 1624sec preferred_lft 1624sec
        inet6 fe80::56dd:2b5f:e33f:829e/64 scope link noprefixroute
          sdetweil @rvnbrg
          192.168.178.30
          ok, so you should be able to connect to MM using the port from config.js
          http://192.168.178.30:8080
            rvnbrg @sdetweil
            @sdetweil Yes that works to see the MM on my desktop web browser.
            Only the FastNotes WebUI does not load
              sdetweil @rvnbrg
              @rvnbrg ok, looking at the code, it looks like there is a python script that provides that UI
              so, in the module folder do
              python3 FastNotes.py --host 192.168.178.30 --port 5000 --debug
                rvnbrg @sdetweil
                @sdetweil That gives me this:
                xavier@raspberrypi:~/MagicMirror/modules/MMM-FastNotes $ python3 FastNotes.py --host 192.168.178.30 --port 5000 --debug
                File “/home/xavier/MagicMirror/modules/MMM-FastNotes/FastNotes.py”, line 2, in
                from backend.fast_notes import start
                File “/home/xavier/MagicMirror/modules/MMM-FastNotes/backend/fast_notes.py”, line 1, in
                import flask
                File “/usr/local/lib/python3.11/dist-packages/flask/init.py”, line 14, in
                from jinja2 import escape
                ImportError: cannot import name ‘escape’ from ‘jinja2’ (/usr/lib/python3/dist-packages/jinja2/init.py)
                S mumblebajM 2 Replies Last reply Reply Quote 0
                  sdetweil @rvnbrg
                  that explains the error
                    rvnbrg @sdetweil
                    @sdetweil how can I resolve that?
                      sdetweil @rvnbrg
                      @rvnbrg that I don’t know
                        rvnbrg @sdetweil
                        @sdetweil Thank you for your help so far
                          sdetweil @rvnbrg
                          @rvnbrg i would ask the author
                            rvnbrg @sdetweil
                            @sdetweil i did so but no response yet
                            • mumblebajM Offline
                              mumblebaj Module Developer @rvnbrg
                              @rvnbrg Jinja is a dependency of Flask and Flask V1.X.X uses the escape module from Jinja, however recently support for the escape module was dropped in newer versions of Jinja
                              To fix this issue, simply update to the newer version of Flask V2.X.X in your requirements.txt where Flask no longer uses the escape module from Jinja.
                              I see there is a requirements.txt where the version of Flask is specified. Maybe updating that to 2.1.1, which is the recommended version that no longer has a dependency on escape would resolve this.
                              This is all just guessing. Was trying to figure out how this module hangs together. 🫣
                                rvnbrg @mumblebaj
                                @mumblebaj YES! Got it working! Thank you very very much
