    No Web UI with MMM-FastNotes
    20 Posts 3 Posters 1.4k Views 3 Watching
      sdetweil @rvnbrg
      @rvnbrg ok, looking at the code, it looks like there is a python script that provides that UI
      so, in the module folder do
      python3 FastNotes.py --host 192.168.178.30 --port 5000 --debug
        rvnbrg @sdetweil
        @sdetweil That gives me this:
        xavier@raspberrypi:~/MagicMirror/modules/MMM-FastNotes $ python3 FastNotes.py --host 192.168.178.30 --port 5000 --debug
        Traceback (most recent call last):
        File “/home/xavier/MagicMirror/modules/MMM-FastNotes/FastNotes.py”, line 2, in
        from backend.fast_notes import start
        File “/home/xavier/MagicMirror/modules/MMM-FastNotes/backend/fast_notes.py”, line 1, in
        import flask
        File “/usr/local/lib/python3.11/dist-packages/flask/init.py”, line 14, in
        from jinja2 import escape
        ImportError: cannot import name ‘escape’ from ‘jinja2’ (/usr/lib/python3/dist-packages/jinja2/init.py)
        S mumblebajM 2 Replies Last reply Reply Quote 0
          sdetweil @rvnbrg
          @rvnbrg said in No Web UI with MMM-FastNotes:
          that explains the error
            rvnbrg @sdetweil
            @sdetweil how can I resolve that?
              sdetweil @rvnbrg
              @rvnbrg that I don’t know
                rvnbrg @sdetweil
                @sdetweil Thank you for your help so far
                  sdetweil @rvnbrg
                  @rvnbrg i would ask the author
                    rvnbrg @sdetweil
                    @sdetweil i did so but no response yet
                    • mumblebajM Offline
                      mumblebaj Module Developer @rvnbrg
                      @rvnbrg Jinja is a dependency of Flask and Flask V1.X.X uses the escape module from Jinja, however recently support for the escape module was dropped in newer versions of Jinja
                      To fix this issue, simply update to the newer version of Flask V2.X.X in your requirements.txt where Flask no longer uses the escape module from Jinja.
                      I see there is a requirements.txt where the version of Flask is specified. Maybe updating that to 2.1.1, which is the recommended version that no longer has a dependency on escape would resolve this.
                      This is all just guessing. Was trying to figure out how this module hangs together. 🫣
                        rvnbrg @mumblebaj
                        @mumblebaj YES! Got it working! Thank you very very much
