    MMM-DateCounter
    6 Posts 2 Posters 647 Views 2 Watching
    • plainbrokeP Offline
      plainbroke
      I want to get rid of or Center the line under the HEADER. Even all the way across would be fine.
        @plainbroke
        try this
        .MMM-DateCounter hr {
           border-style: none;
        to discover this, I set the updateInterval on this module to 30 seconds (30*1000) so it wouldn’t update the content so fast
        and then used the developers window to view the content created by the module
        and selected the element that made the line, (using the pointer highlight mode)
        and tried different values in the box on the top right…
        plainbrokeP 1 Reply Last reply Reply Quote 0
          sdetweil @plainbroke
          @plainbroke you probably have to do that with css.
            plainbroke @sdetweil
            This is what I have in my css file.
            .date_counter header {
            border: 10px solid black;
              @plainbroke I would have to see all the elements and styles.
              You should be able to change it live in the developers window, so you know exactly what goes in custom.css
                @plainbroke
                try this
                   border-style: none;
                  Again, Thank you for the help.
                  • plainbrokeP plainbroke has marked this topic as solved on
