    MagicMirror not in fullscreen after PIR detection
    3 Posts 2 Posters 972 Views 2 Watching
      soldatino
      Hi all,
      I’m running MagicMirror on a Raspberry Pi 4. Display Samsung Smart Signage Display DB22D-T LED.
      I don’t start MagicMirror via PM2. It is started via webhook on my cell phone. This script executes the 2 commands:
      cd ~/MagicMirror && export ELECTRON_DISABLE_GPU=1
      cd ~/MagicMirror && DISPLAY=:0 npm start
      A PIR service is also running.
      If movement is detected, then sending the “on” command over HDMI-CEC:
      echo ‘on 0’ | cec-client -s -d 1
      After a certain time without movement, then sending the “standby” command over HDMI-CEC:
      echo ‘standby 0’ | cec-client -s -d 1
      If movement is detected again after that, the screen turns on, but MagicMirror runs in a window, i.e. not full screen, see image below.
      What am I doing wrong?
      bugsounetB 1 Reply Last reply
      • bugsounetB
        bugsounet Banned @soldatino
        Hi, try to enable auto hide task bar option
          soldatino @bugsounet
          Hi @bugsounet
          Thank you for the tip.
          I had to do a bit of research first because the taskbar can no longer be hidden so easily in Bookworm.
          After that I only had a blue line on the side because of the background image, but I replaced this with a black one and now everything works perfectly.
          you are A magician ;-)
          • S soldatino has marked this topic as solved on
