    MMM-WifiPassword, oudated ?
    25 Posts 2 Posters 3.3k Views 2 Watching
      sdetweil @Jben1969
      @Jben1969 did you get this resolved
      • J
        Jben1969
        Hello,
        today I have tried your suggestions and I have got an error about the WifiModule:
        [2024-09-22 14:05:39.718] [LOG] Loading module helpers …
        [2024-09-22 14:05:39.722] [WARN] No /home/raspberry/MagicMirror/js/…/modules/MMM-WiFiPassword/MMM-WiFiPassword.js found for module: MMM-WiFiPassword.
        [2024-09-22 14:05:39.723] [LOG] No helper found for module: MMM-WiFiPassword.
        [2024-09-22 14:05:39.726] [LOG] No helper found for module: alert.
        [2024-09-22 14:05:39.754] [LOG] Initializing new module helper …
        [2024-09-22 14:05:39.757] [LOG] Module helper loaded: updatenotification
        [2024-09-22 14:05:39.760] [LOG] No helper found for module: clock.
        [2024-09-22 14:05:40.214] [LOG] Initializing new module helper …
        [2024-09-22 14:05:40.215] [LOG] Module helper loaded: calendar
        [2024-09-22 14:05:40.217] [LOG] No helper found for module: weather.
        [2024-09-22 14:05:41.114] [LOG] Initializing new module helper …
        [2024-09-22 14:05:41.115] [LOG] Module helper loaded: MMM-Wallpaper
        [2024-09-22 14:05:41.117] [LOG] No helper found for module: MMM-CalendarExt3.
        [2024-09-22 14:05:41.118] [LOG] All module helpers loaded.
        [2024-09-22 14:05:41.135] [LOG] Starting server on port 8080 …
        [2024-09-22 14:05:41.177] [WARN] You’re using a full whitelist configuration to allow for all IPs
        [2024-09-22 14:05:46.656] [LOG] Server started …
        adress : localhost
        port: 8080
        ipWhitelist: []
        Jochen
          sdetweil @Jben1969
          @Jben1969
          this sounds like a permissions problem
          can you do
          cd ~/MagicMirror/modules
          ls MMM-WiFiPassword -laF
          • J
            Jben1969 @sdetweil
            Shame on me, the name of the folder was not right, the capital F of WiFi was a small f.
            Now everthing is allright, it shows a nice QR-Code of my Guest WiFi.
            Thank you so much.
            Jochen
            • J Jben1969 has marked this topic as solved on
              sdetweil @Jben1969
              @Jben1969 awesome
