    MMM-Pir issues since latest updates
    5 Posts 2 Posters 868 Views 2 Watching
    • E
      eyesallin
      Since installing the latest updates I am receiving the following error
      [2024-09-09 10:02:10.794] [ERROR] [MMM-Pir] [LIB] [PIR] Error: Cannot determine SOC peripheral base address
      [2024-09-09 10:02:10.836] [WARN] [MMM-Pir] [LIB] [PIR] [PYTHON] The exit code was: 0
      [2024-09-09 10:02:10.836] [WARN] [MMM-Pir] [LIB] [PIR] [PYTHON] The exit signal was: null
      The pir meter counts down but is not reset.
      Ive tried rebuilding the Pir program to no avail
      Any help would be appreciated.
      M 1 Reply Last reply
      • M
        MarcLandis Module Developer @eyesallin
        @eyesallin This has been quicly fixed in the python-gpiozero package and the workaround is not needed anymore.
        Reply Quote 1
        • M
          @eyesallin this is an issue with the latest RPi5 kernel. Until a fix is available a workaround is the following command:
          sudo ln -s /dev/gpiochip0 /dev/gpiochip4
          More info about it:
          https://raspberrypi.stackexchange.com/questions/148946/lgpio-can-not-open-gpiochip-lgpio-seems-unable-to-open-gpiochip-devices
          https://github.com/gpiozero/gpiozero/issues/1166
          E 1 Reply Last reply
          Reply Quote 1
          • E
            eyesallin @MarcLandis
            @MarcLandis
            Many thanks for the response, surprised others have not posted?
            • M
              Reply Quote 1
              • E
                eyesallin
                Thankyou just noted, problem solved.
