    MMM-OpenWeatherMapForecast - delete line
    5 Posts 2 Posters 749 Views 2 Watching
    • majsoftM Offline
      majsoft
      Good morning,
      please advise how to delete this line marked with a red arrow?
      I assume it will be a CSS edit, would someone be willing to write exactly what I should edit?
      Thank you very much in advance.
      • majsoftM Offline
        majsoft @sdetweil
        vše vyřešeno. Děkuji.
          sdetweil @majsoft
          @majsoft no, but ill teach you how to find it
          see the second link in my signature below, find the element that draws it
          and set it to
          display:none;
          where xxx is the selector for that element
          i use this cheatsheet to help me with the selector
          https://www.w3schools.com/cssref/css_selectors.php
          majsoftM 1 Reply Last reply Reply Quote 0
          • majsoftM Offline
            majsoft @sdetweil
            great tool, thank you very much
            i used like this:
            .MMM-OpenWeatherMapForecast .module-header {
            font-size: 35px;
            color: white;
            text-transform: none;
            border-bottom: 0px;
            padding-bottom: 5px;
            margin-bottom: 20px;
            can you advise how to move the text by a few pixels?
            I can’t use text-align center, the module is wide and the text would interfere with the map.
            I can’t figure it out. Thanks in advance
              sdetweil @majsoft
              @majsoft what is the styles for that? margin-left?
              you can try all kinds of things in the dev window . then when you get it, you can copy/paste that to custom.css
              the last row of the center window can give you the selector info
              • majsoftM Offline
                majsoft @sdetweil
