    MMM-Rugby
    Scheduled Pinned Locked Moved Sport
    22 Posts 2 Posters 9.6k Views 2 Watching
    • M
      manu85340
      Re: MMM-Rugby
      @mumblebaj Hello, I hope you are well, I restarted the rugby module and for the top 14 I do not have the matches or the ranking up to date do you know why? thanks for your help
      M 1 Reply Last reply
      • M
        manu85340 @manu85340
        @manu85340 said in MMM-Rugby:
        Re: MMM-Rugby
        @mumblebaj Hello, I hope you are well, I restarted the rugby module and for the “top 14” I do not have the matches or the ranking up to date do you know why? thanks for your help
        mumblebajM 2 Replies Last reply
        • mumblebajM
          mumblebaj Module Developer @manu85340
          @manu85340 Please can you share you config with me?
          • mumblebajM
            @manu85340 Just checking api-sport Tope 14 ended in June 2024. The module is setup to only show data from x amount of days previous, apiSportDaysPast:. Could be that because the league is finished that there is no data coming through.
              "leagueId": 16,
              "leagueName": "Top 14",
              "leagueType": "League",
              "leagueFlag": "https://media.api-sports.io/rugby/leagues/16.png",
              "leagueCountryId": 7,
              "leagueCountryName": "France",
              "leagueCountryCode": "FR",
              "leagueCountryFlag": "https://media.api-sports.io/flags/fr.svg",
              "currentSeasons": [
                  "season": 2023,
                  "current": true,
                  "start": "2023-08-18",
                  "end": "2024-06-08"
            The League standings will continue to show data as this is built differently but match results will no longer show because of the dayspast config.
            • M
              manu85340 @mumblebaj
              @mumblebaj ok indeed the top 14 ended in june 2024, I’m waiting for your news, thank you
              • M
                @mumblebaj Do you think it’s possible to update it?
                mumblebajM 1 Reply Last reply
                • mumblebajM
                  @manu85340 To update what?
                  • M
                    @mumblebaj Update dates! if I change the dates in league_data.json will it work? if I put:
                    "season": 2024,
                    "current": true,
                    "start": "2024-08-18",
                    "end": "2025-06-08"
                    • mumblebajM
                      @manu85340 No. That is not how it works. The module looks at the date of each game and does calculations based on your apiSportDaysPast and apiSportsDaysFuture configs to work out if there is games data to display.
                      If I change the apiSportDaysPast config to 124 days then I get data displayed. But after a few days that will disappear again.
                      Until a new league season starts you will not have data again. Unless you follow an active league.
                      • M
                        @mumblebaj I don’t know if I understood what you said, but does that mean that I can no longer have the scores and rankings for the top 14 for this season?
                        • mumblebajM
                          @manu85340 You can have the rankings but not the scores. As they are out of date, they will not be displayed unless you set the apiSportDaysPast value to say 365 then they will display again.
                          • M
                            @mumblebaj yes but the championship will not be up to date, the ranking is that of the last season 2023/2024, and the matches if I put:
                            apiSportDaysPast: 365,
                            I would not have the scores of the last meetings, the top 14 started on September 7, 2024 and ends on June 7, 2025
                            • mumblebajM
                              @manu85340 I have now looked at the API and it looks like the data has changed. I need to have a look at it a little more. Will advise when I have an update available.
                              • M
                                @mumblebaj ok, thanks for your work
                                • mumblebajM
                                  @manu85340 Hi. I have updated the module. You can now do a gitpull and test if all is working ok. There seem to have been an issue with the call that refreshes the league data. Should be working fine now.
                                  • M
                                    @mumblebaj hi, i did a git pull but nothing changes
                                    • mumblebajM
                                      @manu85340 Apologies, please redo the git pull.
                                      • M
                                        @mumblebaj It’s ok, you’re the best, will we have to do this manipulation every year?
                                        • mumblebajM
                                          @manu85340 You should not have to repeat it again.
                                          • M
                                            @mumblebaj perfect, thank you
