    issues updating MMM-calendar EXT3
    19 Posts 4 Posters 4.9k Views 4 Watching
    • N Offline
      nschertz @sdetweil
      @sdetweil Correct. After executing “git reset package-lock.json”, I get the message “Unstaged changes after reset:
      M package-lock.json”
      I then run git pull and get
      pi@MagicMirror:~/MagicMirror/modules/MMM-CalendarExt3 $ git pull
      Updating e93534d…5f276d4
      error: Your local changes to the following files would be overwritten by merge:
      package-lock.json
      Please commit your changes or stash them before you merge.
      Aborting
        sdetweil @nschertz
        @nschertz sorry, oops… wrong command!
        git checkout package-lock.json
        fixed the prior posts with note edited
        • N Offline
          nschertz
          to clarify… execute “git checkout package.json” instead of " git reset package.json" or execute “git checkout package.json” and " git reset package.json"?
            sdetweil @nschertz
            @nschertz git checkout
            restores it from the local source repo
            git reset
            removes it from the staged to be submitted as a change
            I posted the checkout first, then a user posted reset and I blindly followed it…
            my mistake
            • N Offline
              nschertz
              oops meant to type
              to clarify… execute “git checkout package-lock.json” instead of " git reset package-lock.json" or execute “git checkout package-lock.json” and " git reset package-lock.json"?
              • N Offline
                nschertz
                Got it ! git checkout… worked! Thanks for the clarification on what git reset does verses git checkout.
                  sdetweil @nschertz
                  @nschertz awesome… sorry for the misdirection
                    in the git model
                    the files you see are called the working directory
                    and the repo is hidden in the .git folder
                    that is where the actual ‘state’/contents of each file exists
                    so checkout copies the contents from the repo to the working directory
                    if you were developing and had a change
                    git status would show changed files in the working directory
                    git diff will show WHAT changed on each file
                    to lock it down in the local copy of the repo
                    you git add it to a potential ‘commit’,
                    then git status shows it as ‘staged’
                    to REMOVE it from staged, use the git reset command
                    git commit puts it into the local repo as a change
                    then you ‘push’ your entire local repo to the parent (git remote -v)
                    and the changes (if accepted) are merged and that change is in the master for
                    all new ‘pulls’
                    • N Offline
                      nschertz @sdetweil
                      @sdetweil thank you ! This explanation is very helpful. I’m still a little new to the git environment.
