    issues updating MMM-calendar EXT3
    19 Posts 4 Posters 6.6k Views 4 Watching
      JMac @sdetweil
      @sdetweil so just to be clear its,
      git checkout package-lock.json
      git reset
      git pull
      npm install
      within the calendar ext3 module folder?
        sdetweil @JMac
        @JMac no
        edited
        # put package-lock.json back to last git clone state
        # update the module
        git pull
        # rerun npm install  with new code
        npm install
        all in the module folder
        # lines are comments and will be ignored if you copy paste that whole thing
        • N
          nschertz
          @sdetweil I just encountered the same problem and followed your instructions in your last post. This did not fix the problem. I continue to get the same error
          “your local changes to the following files would be overwritten by the merge: package-lock.json
          please commit them or stash them before you merge.
          Aborting.”
          Thoughts on what to do next?
          Norb
            sdetweil @nschertz
            @nschertz you ARE in the module folder, right?
            edited
            cd ~/MagicMirror/modules/MMM-CalendarExt3
            git pull
            npm install
            right?
            BKeyportB N 2 Replies Last reply
            • BKeyportB
              just for information, the real issue is the the lock file is included in the package, right?
                sdetweil @BKeyport
                @BKeyport and it gets updated by npm install
                You can do npm ci
                Which will ONLY install the EXACT versions listed in the lock file, even if it’s wrong for your system
                • N
                  nschertz @sdetweil
                  @sdetweil Correct. After executing “git reset package-lock.json”, I get the message “Unstaged changes after reset:
                  M package-lock.json”
                  I then run git pull and get
                  pi@MagicMirror:~/MagicMirror/modules/MMM-CalendarExt3 $ git pull
                  Updating e93534d…5f276d4
                  error: Your local changes to the following files would be overwritten by merge:
                  package-lock.json
                  Please commit your changes or stash them before you merge.
                  Aborting
                    sdetweil @nschertz
                    @nschertz sorry, oops… wrong command!
                    fixed the prior posts with note edited
                    • N
                      nschertz
                      to clarify… execute “git checkout package.json” instead of " git reset package.json" or execute “git checkout package.json” and " git reset package.json"?
                        sdetweil @nschertz
                        @nschertz git checkout
                        restores it from the local source repo
                        git reset
                        removes it from the staged to be submitted as a change
                        I posted the checkout first, then a user posted reset and I blindly followed it…
                        my mistake
                        • N
                          nschertz
                          oops meant to type
                          to clarify… execute “git checkout package-lock.json” instead of " git reset package-lock.json" or execute “git checkout package-lock.json” and " git reset package-lock.json"?
                          • N
                            nschertz
                            Got it ! git checkout… worked! Thanks for the clarification on what git reset does verses git checkout.
                              sdetweil @nschertz
                              @nschertz awesome… sorry for the misdirection
                                in the git model
                                the files you see are called the working directory
                                and the repo is hidden in the .git folder
                                that is where the actual ‘state’/contents of each file exists
                                so checkout copies the contents from the repo to the working directory
                                if you were developing and had a change
                                git status would show changed files in the working directory
                                git diff will show WHAT changed on each file
                                to lock it down in the local copy of the repo
                                you git add it to a potential ‘commit’,
                                then git status shows it as ‘staged’
                                to REMOVE it from staged, use the git reset command
                                git commit puts it into the local repo as a change
                                then you ‘push’ your entire local repo to the parent (git remote -v)
                                and the changes (if accepted) are merged and that change is in the master for
                                all new ‘pulls’
                                N 1 Reply Last reply
                                • N
                                  nschertz @sdetweil
                                  @sdetweil thank you ! This explanation is very helpful. I’m still a little new to the git environment.
